Idk what this means or if it can help but here is a kernel log from my phone....noticed something about pet_watchdog_work in here whats this,mean?
: x=552 y=324 p=33
<6>[14535.097694] Exiting as rconn_mohm is 0
<6>[14535.375459] [TOUCH] Press 0 : x=510 y=797 p=28
<6>[14535.989316] [TOUCH] Release 0 : x=532 y=211 p=44
<4>[14536.126047] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=350, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-527901, UUC=83100, RUC=1525101, VBATT=4345155, IBAT=-206300
<6>[14536.128702] [BMS_SOC_INFO] soc=100% vbatt=4338V temp=35 ibat=-201mA
<4>[14536.166364] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=350, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-527903, UUC=83100, RUC=1525103, VBATT=4338612, IBAT=-206300
<4>[14536.195755] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=350, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-527905, UUC=83100, RUC=1525105, VBATT=4339209, IBAT=-202300
<4>[14536.225757] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=350, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-527907, UUC=83100, RUC=1525107, VBATT=4338909, IBAT=-198900
<4>[14536.266563] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=350, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-527909, UUC=83100, RUC=1525109, VBATT=4338909, IBAT=-206300
<4>[14536.295740] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=350, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-527911, UUC=83100, RUC=1525111, VBATT=4339209, IBAT=-201700
<6>[14537.541277] [TOUCH] Press 0 : x=569 y=748 p=31
<6>[14538.139629] [TOUCH] Release 0 : x=535 y=240 p=25
<4>[14541.946709] >>>pet_watchdog_work [system rev: 10][raw ver: 4]
<6>[14545.098273] Exiting as rconn_mohm is 0
<6>[14545.437782] [TOUCH] Press 0 : x=530 y=828 p=23
<6>[14546.084722] [TOUCH] Release 0 : x=570 y=379 p=48
<4>[14546.127085] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528444, UUC=83100, RUC=1525644, VBATT=4329096, IBAT=-198900
<6>[14546.130015] [BMS_SOC_INFO] soc=100% vbatt=4338V temp=35 ibat=-187mA
<4>[14546.155743] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528446, UUC=83100, RUC=1525646, VBATT=4339209, IBAT=-187500
<4>[14546.186630] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528448, UUC=83100, RUC=1525648, VBATT=4339506, IBAT=-193200
<4>[14546.215929] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528449, UUC=83100, RUC=1525649, VBATT=4338018, IBAT=-195500
<4>[14546.255789] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528451, UUC=83100, RUC=1525651, VBATT=4338612, IBAT=-205700
<4>[14546.285821] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528453, UUC=83100, RUC=1525653, VBATT=4338612, IBAT=-204600
<6>[14547.573323] [TOUCH] Press 0 : x=548 y=872 p=26
<6>[14548.152844] [TOUCH] Release 0 : x=577 y=375 p=27
<6>[14549.014403] [TOUCH] Press 0 : x=605 y=826 p=35
<6>[14549.612084] [TOUCH] Release 0 : x=609 y=294 p=44
<6>[14551.278283] [PM] BATT TEMP NORMAL : NORMAL ---> NORMAL , TEMP=35 , VOLT=4339
<4>[14551.305751] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528718, UUC=83100, RUC=1525918, VBATT=4339506, IBAT=-204000
<4>[14551.335722] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528720, UUC=83100, RUC=1525920, VBATT=4338612, IBAT=-200600
<4>[14551.365723] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528721, UUC=83100, RUC=1525921, VBATT=4338018, IBAT=-202300
<4>[14551.398258] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528723, UUC=83100, RUC=1525923, VBATT=4338315, IBAT=-192700
<4>[14551.435768] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=352, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528725, UUC=83100, RUC=1525925, VBATT=4337424, IBAT=-196000
<4>[14551.945702] >>>pet_watchdog_work [system rev: 10][raw ver: 4]
<4>[14552.561512] [qcoin_power_set] Motor Level is 0
<4>[14552.563556] [qcoin_power_set] Motor Level is 24
<4>[14552.603660] [qcoin_power_set] Motor Level is 0
<6>[14553.473521] [TOUCH] Press 0 : x=110 y=884 p=33
<6>[14553.583364] [TOUCH] Release 0 : x=109 y=886 p=29
<6>[14555.099860] Exiting as rconn_mohm is 0
<4>[14556.127390] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528960, UUC=83100, RUC=1526160, VBATT=4338612, IBAT=-196000
<6>[14556.131022] [BMS_SOC_INFO] soc=100% vbatt=4339V temp=35 ibat=-197mA
<4>[14556.165754] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528963, UUC=83100, RUC=1526163, VBATT=4338909, IBAT=-201700
<4>[14556.196396] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528964, UUC=83100, RUC=1526164, VBATT=4338909, IBAT=-196000
<4>[14556.225635] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528966, UUC=83100, RUC=1526166, VBATT=4340100, IBAT=-198900
<4>[14556.255636] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528968, UUC=83100, RUC=1526168, VBATT=4339506, IBAT=-195500
<6>[14556.265891] [TOUCH] Press 0 : x=493 y=781 p=37
<4>[14556.268852] [qcoin_power_set] Motor Level is 0
<4>[14556.269645] [qcoin_power_set] Motor Level is 24
<4>[14556.285668] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-528969, UUC=83100, RUC=1526169, VBATT=4340100, IBAT=-203500
<4>[14556.309810] [qcoin_power_set] Motor Level is 0
<6>[14556.410619] [TOUCH] Release 0 : x=496 y=775 p=28
<3>[14556.424719] init: sys_prop: permission denied uid:10002 name:ril.ecclist
<6>[14556.578786] [TOUCH] Press 0 : x=490 y=786 p=33
<4>[14556.581319] [qcoin_power_set] Motor Level is 0
<4>[14556.589377] [qcoin_power_set] Motor Level is 24
<4>[14556.629480] [qcoin_power_set] Motor Level is 0
<6>[14556.706758] [TOUCH] Release 0 : x=492 y=781 p=28
<6>[14557.327939] [TOUCH] Press 0 : x=123 y=667 p=47
<4>[14557.336271] [qcoin_power_set] Motor Level is 0
<4>[14557.340971] [qcoin_power_set] Motor Level is 24
<4>[14557.382204] [qcoin_power_set] Motor Level is 0
<6>[14557.441048] [TOUCH] Release 0 : x=128 y=671 p=31
<6>[14558.211107] [TOUCH] Press 0 : x=332 y=679 p=31
<4>[14558.213640] [qcoin_power_set] Motor Level is 0
<4>[14558.217761] [qcoin_power_set] Motor Level is 24
<4>[14558.259451] [qcoin_power_set] Motor Level is 0
<6>[14558.322354] [TOUCH] Release 0 : x=333 y=677 p=42
<6>[14558.547655] [TOUCH] Press 0 : x=483 y=600 p=22
<4>[14558.552966] [qcoin_power_set] Motor Level is 0
<4>[14558.559894] [qcoin_power_set] Motor Level is 24
<4>[14558.601249] [qcoin_power_set] Motor Level is 0
<6>[14558.687988] [TOUCH] Release 0 : x=500 y=590 p=27
<6>[14559.943321] [TOUCH] Press 0 : x=523 y=793 p=29
<4>[14559.953973] [qcoin_power_set] Motor Level is 0
<4>[14559.966181] [qcoin_power_set] Motor Level is 24
<4>[14560.006499] [qcoin_power_set] Motor Level is 0
<6>[14560.035432] [TOUCH] Release 0 : x=520 y=791 p=40
<4>[14561.947045] >>>pet_watchdog_work [system rev: 10][raw ver: 4]
<6>[14563.958185] [TOUCH] Press 0 : x=351 y=243 p=32
<6>[14564.081243] [TOUCH] Release 0 : x=360 y=243 p=49
<6>[14565.100349] Exiting as rconn_mohm is 0
<4>[14566.127665] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=350, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-529506, UUC=83100, RUC=1526706, VBATT=4341885, IBAT=-202800
<6>[14566.130930] [BMS_SOC_INFO] soc=100% vbatt=4340V temp=35 ibat=-204mA
<4>[14566.155896] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-529507, UUC=83100, RUC=1526707, VBATT=4340991, IBAT=-204000
<4>[14566.187515] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-529509, UUC=83100, RUC=1526709, VBATT=4341885, IBAT=-208000
<4>[14566.219104] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-529511, UUC=83100, RUC=1526711, VBATT=4341885, IBAT=-205100
<4>[14566.257285] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-529513, UUC=83100, RUC=1526713, VBATT=4341291, IBAT=-210300
<4>[14566.297205] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=351, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-529515, UUC=83100, RUC=1526715, VBATT=4340694, IBAT=-203500
<6>[14569.883959] [TOUCH] Press 0 : x=419 y=895 p=27
<6>[14570.657895] [TOUCH] Release 0 : x=519 y=387 p=31
<4>[14571.947411] >>>pet_watchdog_work [system rev: 10][raw ver: 4]
<6>[14575.098701] Exiting as rconn_mohm is 0
<4>[14576.127420] [BMS] ORG_SOC=96, ADJ_SOC=96, COMP_SOC=101(101), LAST_SOC=100, BAT_TEMP=352, OCV=3953288, RBATT=211, FCC=1662000, RC=1080300, CC=-530046, UUC=83100, RUC=1527246, VBATT=4340397, IBAT=-193800
<6>[14576.130747] [BMS_SOC_INFO] soc=
