plasticarmyman
Android Expert
Yes... Yes it has...![]()
and now the link is down because of some stupid SOD issue....
*grumble*
the you had a Viewsonic Gtab right?....i know we had the same tablet at some point...![]()
Soft bricked my phone twice already LOL! This is my one and only and I use it to take support calls also. I'm going to try a few more times then say f#$k it. On a device similar to ours they hijacked the charging system, on another they hijacked the wallpaper. You would think using similar methods to trick other LG devices should work with ours. They can't be that different can they? This is me being hopefulGot my phone today, looks like a stalemate on this project tho:what:
Soft bricked my phone twice already LOL! This is my one and only and I use it to take support calls also. I'm going to try a few more times then say f#$k it. On a device similar to ours they hijacked the charging system, on another they hijacked the wallpaper. You would think using similar methods to trick other LG devices should work with ours. They can't be that different can they? This is me being hopeful![]()
Just using their method as a roadmap. But if you don't get past the guard at the gate he makes you a soft brick. I'm pouring over logcat, dmesg, and boot logs etc. Been looking for clues on what we can hijack to pass 2nd init to. Maybe we have to write our own 2nd init, the one included in their app references HTC.![]()
I know, right! That's the first thing I did was replace the boot ramdisk with ours and also recovery made by Jenkins. Next I started mucking with the bootrecovery and bootunsecure scripts. Swapped out netd with ours. Tried running scripts manually. I'm gonna keep pluggin away until I've decompiled every piece of this crizap and it starts to make sense LOL! Thanks for your attention to this effort!Well if the original file booted to cwm, one would think thats all that would need replaced. Dunno tho lol, very hard working on shyt like this blind. So gl n i will advise when i can. Other that i am at a loss on it.![]()
i just tried the optimus 4x CWM installer 1.0 and it worked...i have CWM on my phone...it's not the right resolution or anything...but it works...we need someone to fix the app so it installs the correct recovery....
i am attaching all the files that i have
i got caught in a bootloop of the boot animation and i am going to try everything to get past it...
but 1.0 has been tested, i'm going to try 1.1 next and then 1.2 after that...
I talked to LG live chat and they told me metro is the one who locked the bootloader could that be true....also how would we be able to find an inside man that could leak the unlock of the bootloader either at LG or metro?
Thanks! I'm going to take another fstab at this. I missed a couple client's calls last time I mucked up my device so I'm hesitant to use it as a testerAnything I can ever help out with let me know...I'm going to pm you my contact info just in case
