Root ZTE ZMAX Pro (Z981) tethering discussion
Which is rather sad they have to go with 128K like that. I would think 1mbps would be nice but fat chance on that.
Actually 128k is 1mbps.
Difference between Mbps and MB/s (internet speed) Mbps means megabits per second while MB/s means megaBYTES per second. There are eight bits in a byte, so a megabit is eight times smaller than a megabyte.
Most traffic isn't even scanned. MetroPCS/T-Mobile hardly scan your data to see if you're tethering. They DO scan for PSN/Xbox Live though, even during the couple of months where we all had unlimited tethering, they would still count PSN activity and Xbox live... I guess a lot of school kids use tethering for games? Kinda weird that is the one thing they check for the most.
Thanks for the explanation there. I suppose I should've said 1 MB/s then.
How do you get unlimited tethering with a rooted phone? Do know any website link? Im asking because I was thinking to switch back to my rooted LG K7 and use this phone as a tablet.
You need root, the $60 metro plan and PDAnet / foxfi apk. I read about it on XDA when I had the stylo.. I've been getting texts about changes to metro tethering and data policy. I didn't read them but maybe it will now work with the $30 plan. PDAnet uses your data plan, not the tether plan. Also the $30 plan LTE data gets capped at 2/3gb but the $60 is unlimited LTE ( unless you tether without PDAnet). This is the part where i thing you need root. When you use PDAnet to turn on the hotspot, the stock hotspot activate along side it. You need to go into your settings and turn off the system hotspot. PDAnet should still be on in the background until you turn it off through PDAnet. I've read of people getting 500+GB tethering with this method.. don't know of any other working method.
Let's keep the tethering discussion in it's own thread. And you're wrong. You just need to use FoxFi and the TTL trick and you get unlimited tethering. Check the other thread for details and reply to this post in the dedicated tethering thread. This thread is for root and it has already been derailed one time before due to tethering discussion.
Thanks
I pay for my plan. I pay 60 a month for unlimited everything. And yes I tested the FoxFi connection over Wifi hotspot. The FoxFi + APN combo will bypass most of the hotspot usage, I'm unsure if it blocks everything. If you want I can PM you the instructions on how to do this. Since FoxFi doesn't support USB C... Or whatever is stopping USB tether, Wifi is the only way to share internet.
I'd appreciate the info on how to do it, thx.
Anubis, do you pay the for the hotspot, also? I have the hotspot, limited to 5GB/month. I also have FoxFi full unlocked compliments of Blackmart. Did you use WiFi tether for your test?
I need help with that answer. I just upgraded to the $60 plan and I also have the FoxFi however, it's using my plans hotspot and now I'm already almost out of my hotspot data. Please help. Thanks in advance.
I've heard that you can fool the hotspot app by editing your APN to have "dun" at the end of the APN settings... I've tried testing it but I'm not sure if it is working. Does the hotspot allow YouTube without consuming data? If not then I think I've found a working bypass.
I did this and it kicked me down to regular 4G
Well I'm back and I'm pleased to admit that a combo of APN editing and FoxFi premium will at least semi-bypass the hotspot restrictions. I started earlier today with 30.1GB of total data usage for the month and ever since I edited the APN and used FoxFi hotspot, the total usage for the month boosted to 30.7GB while the hotspot data seems unchanged. You never know for sure though, it might be using small amounts of hotspot data, but who cares? Not enough to make a 100MB difference. I'm going to post this as another topic. Hope this helps you guys out with your data usage!
Hi. Would you mind sending me steps to bypassing hotspot restrictions using FoxFi & changing APN, please. I've been using pdanet/FoxFi for past 4 years with phones in past. Now have ZTE ZMAX pro and need to tether for internet on notebook for my job. I'm at a loss and on the verge of losing job if don't catch up on work. I live out in the country in Texas, it costs about $300 to get internet out here. I can't afford that, struggling as is. Thank you in advance with any help you can send me.
step #1 read the person above your post.. he has a link
find a program for your pc called cyber ghost. It has been working great for me, it even makes my hotspot much faster.
Can you help me do this
Just keep in mind that it uses way more battery using the wifi hotspot, so you will have to plug it in anyways.
<br>
<br> Really hoping root comes around. I can tell this phone is super popular right now. The Stylo 2 plus dropped in price $20. it hasn't even been out that long itself.
Right keep in touch
