Blu contact blues
I guess he didn't. My friend got it with a lot of apps still there when they probably would have disappeared. The guy must have been really disgusted with it. Why isn't there an option to export contacts, not just import them? Is the phone really that cheap?
do not know why there is not an export option.
and with tech.....you get what you pay for.
if the contacts are still on the phone, he can go to the play store and search for saving contacts.
here is my search:
do not know if any will be available for your friends phone or not.
Backup Samsung Android Phone
i use samsung smart switch. it backs up most of my app and its data, but not all. i would use sms backup to backup and restore your text messages. and make sure your google account is all sync'd up. this will make sure that your google contacts and your photos are all saved to the cloud.
I backup my contacts and photos separately so not so worried about those.
I installed SMS Backup and performed a backup to Dropbox within minutes. Very user-friendly.
Otherwise I would just like to capture apps, app data, widgets, layout, settings, Wi-Fi / Bluetooth connections etc and backup to Dropbox or a USB connected drive and be able to restore to a new phone. Are these all captured via the following backup mechanism?
Settings-> Accounts and backup - Smart switch -> External storage transfer
Memorial Weekend
It was a fun day here. I had lawns to mow and it rained early this morning which changed my plans. I went over to my son's house and saw all my kids then dashed home and mowed five lawns. Took a quick shower and ran back to the party just in time to eat burgers and dogs. Had a few brewskis and came home. The weather was so nice that I took the bike out for a ride. When you have high seventy temps and no wind in Kansas, you had best get out and enjoy it.
Happy Memorial Day everyone.
Green, sometimes Black, Screen - How do I transfer Photos and Files to Replacement?
My screen is totally black now and unresponsive though every thing else seems to be working. I am hearing notifications, etc. I am hoping that when the replacement arrives that maybe smartswitch will work without input from the broken screen. I don't think I had/have Google photos.
Well let's hope that using Smart Switch when you're phone was at least minimally usable will have made at least one full backup on your data, and to an external source, like a computer. If that is the case, you should be able to use the Smart Switch utility on your new phone to restore your previous data.
Keep in mind that except for a few exceptions (i.e. WhatsApp data) that Smart Switch will be able to backup/restore your entire user account. Then it to from an old phone to a new one. Apps like Google Photos only pertain to photo and video content so that would only be part of your all your data.
If you don't have a Smart Switch full backup however, that could be a problem. The other alternative is to do a direct phone-to-phone transfer of your user account but that involves being at least some ability to do things on your old phone. It is a user interactive process, and on both phones.
Android Recent Photos vs Google Photos
I didn't respond because I'd never seen anything on my phone called "Recent Photos". But then when I read your thread I wondered whether this might be something to do with the Samsung gallery app (which, despite owning an s21, I don't use at all), and opening that app, pressing the 3 line menu and selecting "Recent" does give me a timeline view of images on my phone. Is this what you are talking about?
(I might add that my Samsung Gallery is also an old version because I don't update Samsung apps that I don't use, so may look different to yours as well).
Personally I doubt very much that "recent photos" is actually a folder. Different gallery apps can show different collections of images, ordered by time, by folder, sorted into photos and videos, or whatever, but when a picture shows in a timeline view or a folder view, or in your Gallery app vs Google Photos, it will be the same file in every case. So if you delete it in one place it will be gone from them all.
My Clipboard Deleted
What exactly was deleted? It's not clear from your post. You mentioned the clipboard in the title, but it will be different if you cut a piece of text or tried to move a file that way.
I'm not optimistic either way - data recovery in Android is always problematic, so I'd always recommend copying important stuff and then deleting the original afterwards. But more information might help.
Oneplus 8T - Swapping components between KB2007 & KB2000
If that has been determined and verified to be the problem, that's just a software issue. The upgrade process failed in some way that affected the video driver/firmware. Why not just try reapplying the upgrade or re-flash the phone with its newer, stock (international) ROM? Software fixes are less involved than hardware swapping of components. Fixing up that international model will negate the need to mess with that T-Mobile model.
Yes, the housing is the same for that model line (8T). But I still think you're better off just fixing that international model. Even if you do have all that work done, you're still going to need to flash the stock ROM on that T-Mobile phone to solve it's carrier-lock issue.
Dude, we've given you all the best advice.
If you don't believe us, or don't want to sound like a pain in the a** you're free to reach out to other Android Forums that are out there.
Jeez take a pill.
Odds are you are going to end up with 2 phones that have been busted open trying to fix one phone. The end result is two basically dead parts phones.
You should just bite the bullet and resale the OP8T and start from square one. When buying unlocked phones, non carrier specific phones you need to research what models will work in your area. I've seen so many incorrect descriptions on Ebay and Amazon. Not just look at Global phones either, look at each specific model and the bands that phone supports. Every manufacturer is very different about what bands they support in what areas except Apple and Google. The new Apple/Google phones basically support all bands worldwide
I have done swapping displays of Oneplus 8T between KB2007 & KB2000.
All work perfectly fine except the FINGERPRINT
Fingerprint does not being recognized at all.
Does anybody have an answer to this ?
What I found googling is it needs to be recalibrated through a oneplus official store
Does anyone have any idea about any other way, as I am not having a OP official store in my country
Anyone's help here is greatly appreciated.
Help The phone app disappears after recent system update?
Funny thing: I received another update for my s21 last night, less than a fortnight after the previous one (and after my phone had had a couple of UI hangups and another spontaneous restart yesterday). Update description was standard boilerplate, but the top item was "Stability and reliability: device behaviour has been improved". Too soon to say whether it has fixed the issues, but a second update in rapid succession looks a lot like they've realised that the previous one was buggy.
[FREE GAME] Firefly Dash - Casual Game
After one year of trial and error, we finally released our first game: Firefly Dash!
Dash your way through different color-changing aesthetic zones and be mindful of the way you go down the hills as a bad angle can shatter your firefly.
In Firefly Dash, you relax and light your way through the mountains as you eat more fireflies to keep your size. Don't die and go as far as you can to discover new colors!
✨How to play ✨
Light your way through the aesthetically pleasing scenery
1. Hold to speed your firefly
2. Release to make your firefly fly
3. Eat other fireflies to keep your size
4. Use boost to increase your speed, but be careful! It lowers your firefly's speed.
5. Don't let the darkness catch you.
Game Features
1. Aesthetically pleasing graphics;
2. Beautiful scenery and lights;
3. Easy gameplay; ✅
4. Time to relax;
Travel as far as you can with your firefly through this aesthetic game and reach new colors!
Download Now
Android
IOS
You can see how far we've come - from concept to final design. You can download Firefly Dash for free on both Android and IOS! Any criticism is welcomed.
Can I earn by playing car racing games online?
The best way of thinking about NFTs is "digital tulip bulbs". If you don't understand that reference you should not be in the investment market at all, because your ignorance will make you an easy mark.
Just remember that by every metric the NFT market has shrunken dramatically since late 2021, and that the people and organisations who talk it up have a vested interest in it. If you still want to get involved despite that, well it's your loss.
Galaxy Tab S7+ WiFi only. Locked in demo mode. Help please
Does Samsung Touchwiz allow you to control any changes?
touchwiz? thats very old. samsung now uses OneUI. and what do you mean by "control any changes"?
both touchwiz and OneUI are just samsung's launcher that they put on top of the android os to make it look and fell different from other manufacturers. i dislike OneUI so i use the Nova launcher that you can get in the play store.
Top down racing game recommendation?
If you're looking for top-down racing games similar to Reckless Racing and Mini Moto Racing, here are a few recommendations:
  1. Thumb Drift - A unique racing game where you control your car by drifting and sliding your thumb across the screen. It offers various tracks, challenging obstacles, and a wide selection of cars to unlock.
  2. Horizon Chase - Inspired by classic arcade racing games, Horizon Chase offers fast-paced top-down racing with retro-style graphics. It features a nostalgic soundtrack, multiple game modes, and a wide range of tracks from different locations around the world.
  3. Table Top Racing - This game combines top-down racing with elements of combat. Drive miniature cars on creative tracks and use weapons and power-ups to take down your opponents. It offers various game modes and customization options for your vehicles.
  4. Pico Rally - Experience retro-style top-down racing with a pixel art aesthetic. Pico Rally features challenging tracks, different weather conditions, and a variety of cars to choose from. It offers both single-player and multiplayer modes for some competitive racing action.
  5. Riptide GP: Renegade - Although not strictly top-down, Riptide GP: Renegade offers thrilling jet ski racing with a similar perspective. Race through futuristic waterways, perform stunts, and compete against AI opponents in a story-driven career mode.
These games should provide you with enjoyable racing experiences without the limitations of fuel systems or the gameplay styles you mentioned avoiding.
Be advised that you are responding to a thread that is over five years old. I doubt seriously if they are still looking or still active on these forums.
Canadian Carriers
Their coverage map looks terrible, unless I'm looking at it wrong: Freedom Mobile | Network Coverage - Nationwide Cell Phone Signal Map
I looks about right for Canada. Especially as most of the population lives in the south, and often within 100km of the US border. And the population of Canada is about half that of the UK. If you're up in the northern wildernesses of Canada, it's best if you have a satellite phone.
Samsung A23 - Blocking and removing apps
Hi
I have a Samsung A23, (will be buying additional 49 after this is figured out and configured) I want to remove all software on it, add 1 communication app to the main screen (which will work via wifi) there will not be any sim card installed, I want to block/disable any installations of apps etc , including social media, browsing the web, and giving the user the phone without a google account on it (don't mind using one to implement this, then removing it), the mobile will be used only for corporate use, to receive and make calls, hence the reason for this
Any ideas would be greatly appreciated
Thanks
Sounds like Knox Manage might be useful for this. That's what Samsung designed it for, managing corporate use devices.
Root QPST Service Programming Error??
The QPST (Qualcomm Product Support Tools) is a software suite developed by Qualcomm for various tasks related to Qualcomm chipset-based devices, such as programming, diagnostics, and firmware updates. The "Service Programming Error" message you encountered indicates that there was an issue while attempting to program or configure a device using QPST.
Here are a few suggestions to troubleshoot the QPST Service Programming Error:
  1. Check device compatibility: Ensure that the device you are attempting to program is supported by the version of QPST you are using. Different versions of QPST may have varying levels of compatibility with different devices.
  2. USB drivers: Verify that the correct USB drivers for your device are installed on your computer. Without the proper drivers, QPST may not be able to communicate with the device correctly.
  3. Port configuration: Open the QPST Configuration application and go to the "Ports" tab. Make sure the appropriate COM port is selected for your device. If the correct COM port is not listed, you may need to reinstall the USB drivers or troubleshoot your device's connectivity.
  4. Restart devices: Try restarting both your computer and the device you are trying to program. Sometimes, a simple restart can resolve temporary communication issues.
  5. Firewall and antivirus: Temporarily disable any firewall or antivirus software on your computer. In some cases, these security measures can interfere with the QPST software's communication with the device.
  6. Reinstall QPST: If none of the above steps work, try uninstalling QPST and reinstalling it from a trusted source. Make sure you are using the latest version available.
If the issue persists after trying these steps, it may be helpful to consult the documentation or support resources provided by Qualcomm or the device manufacturer for further assistance. They may have specific troubleshooting steps or recommendations tailored to your device or situation.
Filter
