Help How to permanently remove "Mute all sounds" from Samsung Galaxy A13?
On an unrooted phone, no. Even with root you'd have to find a system mod (probably specific to this particular model) that does this, which I've never heard of.
Maybe you could change your Do Not Disturb settings so that almost everything is allowed to make a sound even in DnD mode (i.e. make everything you can an "exception")? Might be possible to work around it that way.
Check your Do Not Disturb settings to make sure you don't have any schedules set up. And maybe check that your calendar app doesn't have an opinion to mute during events (not a common feature, indeed I use Tasker to make mine do this, but worth eliminating as a possibility).
If it's not something like that all I can think of is maybe something keeps pressing the volume down button?
Android Studio multi build
Hi, I need some help with a problem I need to solve. I have an application that I need to install on three different customers' devices. Each client has to point to his own server and use some features and not all. What's the best way to handle this? As sources I have only one but I would like to be able to generate several apk automatically by setting in some way a parameter that allows me to make the application work in the correct way
Do APKs take up less space?
If I install an APK version of an app instead of downloading from the play store, does it take up less or more space???
Installing an APK version of an app instead of downloading it from the Play Store does not necessarily take up less or more space. The size of the app remains the same, regardless of the source of installation.
When you download an app from the Play Store, the app's APK file is downloaded to your device, along with any additional data or resources needed to run the app. When you install the app, these files are stored in the device's internal storage or on an external SD card, depending on your settings.
Similarly, when you install an APK file manually, the APK file and any associated data or resources are stored in the device's internal or external storage, just like when installing from the Play Store.
However, it's worth noting that downloading and installing APK files from third-party sources can be risky, as they may contain malware or other security vulnerabilities. It's always recommended to download apps from trusted sources such as the Google Play Store or other official app stores to minimize these risks.
What's apk+ ?
When I backup an Android app, I've noticed that some newer apk files have actually the extension apk+
What's the meaning of this?
Thanks.
The .apk+ extension that you are seeing in some Android app backups is a file extension used by the Helium Backup app. Helium Backup is a popular backup tool for Android devices that allows users to backup and restore their apps and data without requiring root access.
The .apk+ extension is used by Helium Backup to indicate that the APK file has been backed up along with its associated data. The plus sign (+) is used to differentiate these backup files from regular APK files.
When you use Helium Backup to create a backup of an app, it creates a backup file with the .apk+ extension that contains both the APK file and the app's data. This allows you to restore the app along with its data, preserving your app settings, user data, and other app-specific information.
It's worth noting that Helium Backup is not the only app that uses this file extension. Some other backup and restore apps may also use the .apk+ extension to indicate that a file contains both the APK and data for an app. However, the use of this file extension is not standardized across all backup tools, so it's important to check the documentation of the backup tool you are using to understand how it stores and restores app data.
Find the Difference Game
Have you gotten bored of scrolling for games that are interesting to play and also increase your concentration? Then you have reached the right application, find a difference game that has all the features that you expect in one interesting game.
Do you really think you can conquer this game's levels? Sometimes it seems simple but it's not!
Play find the difference game on your smartphone and go to levels, find out the difference between two pictures. Use your skills to spot the potential difference between those pictures, while the timer running in the background, find the differences in less time which will help you to perform better and train you for the next challenging levels.
Find the difference game is a photo hunt puzzle game that looks simple and easy but it is more challenging when you go to the upper levels, if there will be more challenges it means more fun playing this game. Playing the find the difference game will improve your focus power and observation skills. Everyone can play this game and improve their skills. The best advantage of this game is that it allows you to take a short break whenever you need it and also helps in sharpening your memory.
So what are you waiting for? Take your magnifying glass and enter the level, the magnifying glass on your screen helps you to see the missing objects if they are too small for you to see! Zoom in, and tap it if you spot any difference between two pictures and win the level.
Every level will present you with two beautiful HD pictures that look the same, but there will be some small differences between them, it's your job to spot the difference as quickly as you can. In addition to that, finding the difference game gives you the option of hints. Note that you can use hints only twice at each level. Avoid regularly using hints, practice more, and clear the level with your skills will give you more confidence for the next challenging levels. The more you will play this game, the better your observation will become.
Improving your memory by finding the difference will be a significant aspect of this game. Whenever you play at a new level, you exercise your brain to solve that level.
Benefits You Get Playing This Game:
-> Simple game pattern for all.
-> Help you in improving your mental strength!
-> Power up your observation skills!
-> You enter the detective world!
-> Beautiful Pictures for everyone
-> Easy to use with simple UI/UX
Find the difference game gives you relief from stress while playing the game, easily show your patience and detective skills to clear the level and head to the next! The levels will become more challenging as it goes higher & higher so to tackle them easily concentrate on the game and find the spots!
Amazing Features By Find The Difference Game:
-> More than 200+ Amazing & Challenging levels with high-quality pictures
-> Find the spots from the smaller details and improve observation
-> Use hints if you unable to clear levels
-> Magnifying Glass: Zoom in to spot the smallest differences between pictures
-> Play with a timer to analyze your true mental strength
Find the difference is a fun game that is designed for everyone.
when you progress in levels the difficulties also increase. It is highly recommended to play spot the differences games and constantly increase the level of difficulty which helps you in improving your skills. Spot the difference games will look simple to you but many times we are unable to find all the differences.
So what are you waiting for? Try out this challenging and fun game by downloading it now!
Root Make and Receive FREE calls over WiFi..No Mobile Service Required
is this a statement? or are you asking for help? what phone do you have?
No I was saying CM7.2 has SIP settings and how all I need is to find a SIP provider, and it's also an AT&T Huawei Fusion 2 U8665
Edit: found Linphone, but I kinda want one that lets me call any number, kinda like a regular carrier number. Seeing how VoIP can do so, so I'm still trying to find a provider for it.
New phone ‘complaints’
The last time I used Titanium Back up was around four years ago, so I back up my photos to mostly terabox, and my contacts to google contacts.. I do tend to deleted a few of them because either they are so caught up with themselves, or even a justify surfacing a lie covered up from another lie..
Android Studio Preview Rendering problems
Hi, I am trying to learn Android development. I am learning from developer.android.com/courses
And have problems with @Preview rendering.
Every time I change something in code (even if I just added new line) preview try to automatically Build and Refresh, but every time it fails. It says "Some issues were found while trying to render this preview".
In Problems window I see some Render problems in Compose tab.
Rich (BB code):
android.content.res.Resources$NotFoundException: Could not resolve resource value: 0x1CFDEB.   at android.content.res.Resources_Delegate.throwException(Resources_Delegate.java:1161)   at android.content.res.Resources_Delegate.throwException(Resources_Delegate.java:1137)   at android.content.res.Resources_Delegate.throwException(Resources_Delegate.java:1141)   at android.content.res.Resources_Delegate.getString(Resources_Delegate.java:823)   at android.content.res.Resources.getString(Resources.java:546)   at androidx.compose.ui.res.StringResources_androidKt.stringResource(StringResources.android.kt:39)   at com.example.superheroes.HeroesScreenKt.HeroItem(HeroesScreen.kt:30)   at com.example.superheroes.HeroesScreenKt$HeroPreview$1.invoke(HeroesScreen.kt:49)   at com.example.superheroes.HeroesScreenKt$HeroPreview$1.invoke(HeroesScreen.kt:48)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:107)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:34)   at androidx.compose.material.MaterialTheme_androidKt.PlatformMaterialTheme(MaterialTheme.android.kt:23)   at androidx.compose.material.MaterialThemeKt$MaterialTheme$1$1.invoke(MaterialTheme.kt:82)   at androidx.compose.material.MaterialThemeKt$MaterialTheme$1$1.invoke(MaterialTheme.kt:81)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:107)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:34)   at androidx.compose.runtime.CompositionLocalKt.CompositionLocalProvider(CompositionLocal.kt:228)   at androidx.compose.material.TextKt.ProvideTextStyle(Text.kt:265)   at androidx.compose.material.MaterialThemeKt$MaterialTheme$1.invoke(MaterialTheme.kt:81)   at androidx.compose.material.MaterialThemeKt$MaterialTheme$1.invoke(MaterialTheme.kt:80)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:107)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:34)   at androidx.compose.runtime.CompositionLocalKt.CompositionLocalProvider(CompositionLocal.kt:228)   at androidx.compose.material.MaterialThemeKt.MaterialTheme(MaterialTheme.kt:72)   at com.example.superheroes.ui.theme.ThemeKt.SuperheroesTheme(Theme.kt:38)   at com.example.superheroes.HeroesScreenKt.HeroPreview(HeroesScreen.kt:48)   at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(NativeMethodAccessorImpl.java:-2)   at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)   at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)   at java.lang.reflect.Method.invoke(Method.java:566)   at androidx.compose.ui.tooling.ComposableInvoker.invokeComposableMethod(ComposableInvoker.kt:155)   at androidx.compose.ui.tooling.ComposableInvoker.invokeComposable(ComposableInvoker.kt:195)   at androidx.compose.ui.tooling.ComposeViewAdapter$init$3$1$composable$1.invoke(ComposeViewAdapter.kt:590)   at androidx.compose.ui.tooling.ComposeViewAdapter$init$3$1$composable$1.invoke(ComposeViewAdapter.kt:588)   at androidx.compose.ui.tooling.ComposeViewAdapter$init$3$1.invoke(ComposeViewAdapter.kt:625)   at androidx.compose.ui.tooling.ComposeViewAdapter$init$3$1.invoke(ComposeViewAdapter.kt:583)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:107)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:34)   at androidx.compose.runtime.CompositionLocalKt.CompositionLocalProvider(CompositionLocal.kt:228)   at androidx.compose.ui.tooling.InspectableKt.Inspectable(Inspectable.kt:61)   at androidx.compose.ui.tooling.ComposeViewAdapter$WrapPreview$1.invoke(ComposeViewAdapter.kt:531)   at androidx.compose.ui.tooling.ComposeViewAdapter$WrapPreview$1.invoke(ComposeViewAdapter.kt:530)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:107)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:34)   at androidx.compose.runtime.CompositionLocalKt.CompositionLocalProvider(CompositionLocal.kt:228)   at androidx.compose.ui.tooling.ComposeViewAdapter.WrapPreview(ComposeViewAdapter.kt:525)   at androidx.compose.ui.tooling.ComposeViewAdapter.access$WrapPreview(ComposeViewAdapter.kt:124)   at androidx.compose.ui.tooling.ComposeViewAdapter$init$3.invoke(ComposeViewAdapter.kt:583)   at androidx.compose.ui.tooling.ComposeViewAdapter$init$3.invoke(ComposeViewAdapter.kt:580)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:107)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:34)   at androidx.compose.ui.platform.ComposeView.Content(ComposeView.android.kt:402)   at androidx.compose.ui.platform.AbstractComposeView$ensureCompositionCreated$1.invoke(ComposeView.android.kt:248)   at androidx.compose.ui.platform.AbstractComposeView$ensureCompositionCreated$1.invoke(ComposeView.android.kt:247)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:107)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:34)   at androidx.compose.runtime.CompositionLocalKt.CompositionLocalProvider(CompositionLocal.kt:228)   at androidx.compose.ui.platform.CompositionLocalsKt.ProvideCommonCompositionLocals(CompositionLocals.kt:177)   at androidx.compose.ui.platform.AndroidCompositionLocals_androidKt$ProvideAndroidCompositionLocals$3.invoke(AndroidCompositionLocals.android.kt:123)   at androidx.compose.ui.platform.AndroidCompositionLocals_androidKt$ProvideAndroidCompositionLocals$3.invoke(AndroidCompositionLocals.android.kt:122)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:107)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:34)   at androidx.compose.runtime.CompositionLocalKt.CompositionLocalProvider(CompositionLocal.kt:228)   at androidx.compose.ui.platform.AndroidCompositionLocals_androidKt.ProvideAndroidCompositionLocals(AndroidCompositionLocals.android.kt:114)   at androidx.compose.ui.platform.WrappedComposition$setContent$1$1$3.invoke(Wrapper.android.kt:157)   at androidx.compose.ui.platform.WrappedComposition$setContent$1$1$3.invoke(Wrapper.android.kt:156)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:107)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:34)   at androidx.compose.runtime.CompositionLocalKt.CompositionLocalProvider(CompositionLocal.kt:228)   at androidx.compose.ui.platform.WrappedComposition$setContent$1$1.invoke(Wrapper.android.kt:156)   at androidx.compose.ui.platform.WrappedComposition$setContent$1$1.invoke(Wrapper.android.kt:140)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:107)   at androidx.compose.runtime.internal.ComposableLambdaImpl.invoke(ComposableLambda.jvm.kt:34)   at androidx.compose.runtime.ActualJvm_jvmKt.invokeComposable(ActualJvm.jvm.kt:74)   at androidx.compose.runtime.ComposerImpl$doCompose$2$5.invoke(Composer.kt:3193)   at androidx.compose.runtime.ComposerImpl$doCompose$2$5.invoke(Composer.kt:3183)   at androidx.compose.runtime.SnapshotStateKt__DerivedStateKt.observeDerivedStateRecalculations(DerivedState.kt:252)   at androidx.compose.runtime.SnapshotStateKt.observeDerivedStateRecalculations  at androidx.compose.runtime.ComposerImpl.doCompose(Composer.kt:3183)   at androidx.compose.runtime.ComposerImpl.composeContent$runtime_release(Composer.kt:3119)   at androidx.compose.runtime.CompositionImpl.composeContent(Composition.kt:584)   at androidx.compose.runtime.Recomposer.composeInitial$runtime_release(Recomposer.kt:811)   at androidx.compose.runtime.CompositionImpl.setContent(Composition.kt:519)   at androidx.compose.ui.platform.WrappedComposition$setContent$1.invoke(Wrapper.android.kt:140)   at androidx.compose.ui.platform.WrappedComposition$setContent$1.invoke(Wrapper.android.kt:131)   at androidx.compose.ui.platform.AndroidComposeView.setOnViewTreeOwnersAvailable(AndroidComposeView.android.kt:1015)   at androidx.compose.ui.platform.WrappedComposition.setContent(Wrapper.android.kt:131)   at androidx.compose.ui.platform.WrappedComposition.onStateChanged(Wrapper.android.kt:182)   at androidx.lifecycle.LifecycleRegistry$ObserverWithState.dispatchEvent(LifecycleRegistry.java:354)   at androidx.lifecycle.LifecycleRegistry.addObserver(LifecycleRegistry.java:196)   at androidx.compose.ui.platform.WrappedComposition$setContent$1.invoke(Wrapper.android.kt:138)   at androidx.compose.ui.platform.WrappedComposition$setContent$1.invoke(Wrapper.android.kt:131)   at androidx.compose.ui.platform.AndroidComposeView.onAttachedToWindow(AndroidComposeView.android.kt:1102)   at android.view.View.dispatchAttachedToWindow(View.java:21291)   at android.view.ViewGroup.dispatchAttachedToWindow(ViewGroup.java:3491)   at android.view.ViewGroup.dispatchAttachedToWindow(ViewGroup.java:3498)   at android.view.ViewGroup.dispatchAttachedToWindow(ViewGroup.java:3498)   at android.view.ViewGroup.dispatchAttachedToWindow(ViewGroup.java:3498)   at android.view.ViewGroup.dispatchAttachedToWindow(ViewGroup.java:3498)   at android.view.ViewGroup.dispatchAttachedToWindow(ViewGroup.java:3498)   at android.view.AttachInfo_Accessor.setAttachInfo(AttachInfo_Accessor.java:58) Copy stack to clipboard   Tip: Try to refresh the layout.
But if I manually Build and Refresh no problems are found and everything works. This is very frustrating.
For new assignment I had to create HeroesScreen.kt file and write some code here. I tried to create @Preview in HeroesScreen.kt but was not even able to move from "Code" tab to "Split" tab. Pressing on Split tab did not do anything. Closed Android Studio and opened it again and was able to press and open Split window. But preview would show same issues as above, even if I Build and Refresh manually.
Opened MainActivity.kt file to write some code here. Wanted to copy code from HeroesScreen.kt so I opened it and @Preview is rendered no issues.
I made screen video
Accessories Best program to save and share status
Certainly, you will like one of your friend's Status and want to save or re-share it, and due to the lack of privacy in the modified WhatsApp applications, this application was built to facilitate saving statuses and sharing them easily and completely safely, since this application is officially published in the Google Play Store and under the supervision of Google.
Advantages of status downloader app:
・Save all photos and videos
・Supports WhatsApp Business also
・Multiple save, delete, repost, and share
・The possibility of re-sending the status without saving
・Watch video HD directly
・Easy and fast
・Stylish design
・Completely free
・Many great features
Download status saver Now for free on Google Play
Lenovo tablet TB328XU Palm Rejection
Oh like a bio scanner? I think that mine does not have that at all, I can rest both of my hands easily on it.
no......when you try writing or drawing whatever app you use, it will detect your hand and your stylus. it will think that you are also using your hand to draw or write and will mark the page as so. but on a tablet that has a designated stylus like the note, s22 or s23 and even the lenovo tab P11, you can place your hand on the screen and it will ignore your hand and only recognize the stylus.
but on tablets or phones that does not come with its own stylus will read your hand as well. so you can't touch the screen while you write or draw. i have yet to find an app that will do this.
Taking a screen shot?
Have you tried this? It's off my Pixel 7 - Settings>System>Gestures The double tap is all I see as an alternative.
That's all I see - was hoping to be able to attach this functionality to the power button or one fo the pull-down commands.
there is also:
wipe up from the bottom of the screen to the Recents screen; you'll see a button for Screenshot at the bottom of the screen
I have disabled swipe navigation, so this does nothing.
Root [Sprint] LG G2 Stuck in fastboot mode. PLEASE HELP!
yep 2014 is when this pre-paid phone came out. i would look to get a new phone.
if you really want to revive this ancient relic, then can you please post the output of your fastboot command? and you say that fastboot sees the phone, so just to be sure when you type "fasboot devices", you get a bunch of numbers, correct?
also post all of the outputs from the fastboot commands that you have tried.
My thread:
Filter
