Help If i block someone right after sending a text, does that text still get delivered to them?
- By maggiem2481
- VIP Lounge
- 5 Replies
The text message had gone to that person if you had blocked that person after sending it.
<RatingBar
android:id="@+id/rating_bar"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:numStars="5"
android:stepSize="1.0"
android:rating="3.5"
android:isIndicator="false" />
where are you seeing this? can you post a screenshot?
Lol........at the very bottom of each post you should see options for "tools", "quotes ", and "reply". If you select tools you can edit or report the post to moderators.I know how embarrassing! I realize that after I hit send and I couldn't figure out how to go back and edit it!,
Probably not without bricking your tablet. A few people have rooted your tablet at XDA but there's not a lot of info on it.
hi
To help you troubleshoot the issue you are experiencing, it might be helpful to try the following steps:
I hope this helps! Let me know if you have any other questions.
- Review the code around line 30 in the file App.java, as this is where the Strict Mode violation is being triggered. This is likely the code that is responsible for acquiring the resource that is being leaked.
- Look for any places in your code where you might be opening resources, such as streams or database connections, and make sure that you are properly closing them when you are finished with them.
- If you are unable to find the cause of the leak in your code, you could try enabling more verbose logging in Strict Mode by setting the penaltyLog flag in the VmPolicy.Builder object. This will cause Strict Mode to print a more detailed log message when a violation occurs, which might provide more clues about the cause of the leak.
- Another option might be to try running your app in a debugger and setting a breakpoint at line 30 in App.java. This will allow you to pause the app at the point where the leak is occurring, and inspect the state of the app to see if you can find any clues about the cause of the leak.
Try using Samsung's Smart Switch utility to transfer her old S10 user account data to the new S22. It's a pretty reliable tool to backup/transfer data, especially between two Samsung phones, but be sure to read through the exclusions for third-party data that might not be included (i.e. WhatsApp, which has its own backup service in the WhatsApp app.)
https://www.samsung.com/us/apps/smart-switch/
Hope your retirement into a RV life is as awesome as it sounds to be.
repositories {
maven {
url "http://localhost/"
allowInsecureProtocols()
just curious as to how inconsistent are they? are they even close? and you are only measuring sleep duration? i would only trust the one that you are supposed to use with the watch, the MI Fit app ....but that is me.
import java.io.BufferedReader;
import java.io.InputStreamReader;
import java.io.PrintWriter;
import java.net.ServerSocket;
import java.net.Socket;
public class Server {
public static void main(String[] args) {
try {
ServerSocket serverSocket = new ServerSocket(8000);
System.out.println("Server started on port 8000");
Socket clientSocket = serverSocket.accept();
System.out.println("Client connected");
BufferedReader in = new BufferedReader(new InputStreamReader(clientSocket.getInputStream()));
PrintWriter out = new PrintWriter(clientSocket.getOutputStream(), true);
String inputLine;
while ((inputLine = in.readLine()) != null) {
System.out.println("Received message: " + inputLine);
out.println("Server received message: " + inputLine);
} catch (Exception e) {
e.printStackTrace();
import android.os.AsyncTask;
import android.os.Bundle;
import android.support.v7.app.AppCompatActivity;
import android.view.View;
import android.widget.EditText;
import android.widget.TextView;
public class MainActivity extends AppCompatActivity {
private TextView mTextView;
private EditText mEditText;
@Override
setContentView(R.layout.activity_main);
mTextView = findViewById(R.id.text_view);
mEditText = findViewById(R.id.edit_text);
public void sendMessage(View view) {
String message = mEditText.getText().toString();
new SendMessageTask().execute(message);
private class SendMessageTask extends AsyncTask<String, Void, String> {
@Override
protected String doInBackground(String... strings) {
try {
String message = strings[0];
Socket socket = new Socket("192.168.42.129", 8000);
PrintWriter out = new PrintWriter(socket.getOutputStream(), true);
BufferedReader in = new BufferedReader(new InputStreamReader(socket.getInputStream()));
out.println(message);
String response = in.readLine();
return response;
return null;
AudioManager audioManager = (AudioManager) getSystemService(AUDIO_SERVICE);
audioManager.setMicrophoneMute(true); // turn off the microphone
audioManager.abandonAudioFocus(new AudioManager.OnAudioFocusChangeListener() {
@Override
public void onAudioFocusChange(int focusChange) {
// handle audio focus changes here
interface RetroService {
@POST("graphql/")
@Headers("Content-Type: application/json")
fun getLastLaunch(): Call<LaunchModel>
data class LaunchModel(val data: Data)
data class Data(val launchLatest: LaunchLatest)
data class LaunchLatest(
val id: String,
val details: String?,
val isTentative: Boolean?,
val launchDateLocal: String?,
val launchDateUnix: Long?,
val launchDateUtc: String?,
val launchSite: LaunchSite?,
val launchSuccess: Boolean?,
val launchYear: String?,
val links: Links?,
val missionId: List<String>?,
val missionName: String?,
val rocket: Rocket?,
val staticFireDateUnix: Long?,
val staticFireDateUtc: String?,
val telemetry: Telemetry?,
val tentativeMaxPrecision: String?,
val upcoming: Boolean?,
val ships: List<Ship>?
data class LaunchSite(val siteId: String, val siteNameLong: String)
data class Links(val flickrImages: List<String>, val missionPatch: String, val missionPatchSmall: String, val presskit: String, val redditCampaign: String, val redditLaunch: String, val redditRecovery: String, val redditMedia: String, val videoLink: String)
data class Rocket(val rocketId: String, val rocketName: String, val rocketType: String)
data class Telemetry(val flightClub: String)
data class Ship(val shipId: String, val shipName: String, val shipModel: String)
val retroInstance = RetroInstance.getRetroInstance().create(RetroService::class.java)
val requestBody = "{\"query\":\"{launchLatest{id, details, isTentative, launchDateLocal, launchDateUnix, launchDateUtc, launchSite{siteId, siteNameLong}, launchSuccess, launchYear, links{flickrImages, missionPatch, missionPatchSmall, presskit, redditCampaign, redditLaunch, redditRecovery, redditMedia, videoLink}, missionId, missionName, rocket{rocketId, rocketName, rocketType}, staticFireDateUnix, staticFireDateUtc, telemetry{flightClub}, tentativeMaxPrecision, upcoming, ships{shipId, shipName, shipModel}}}\",\"variables\":null}"
val retrofitData = retroInstance.getLastLaunch(requestBody)
retrofitData.enqueue(object: Callback<RetroService.LaunchModel> {
override fun onFailure(call: Call<RetroService.LaunchModel>, t: Throwable) {
Toast.makeText(this@MainActivity, "call fail", Toast.LENGTH_LONG).show()
override fun onResponse(
response: Response<RetroService.LaunchModel>
val responseBody = response.body()
if(responseBody != null){
val
