App Inventor How can I Simulate External Drives in Android Studio?
'm currently working on a small internal application for my company. (non-commercial, just a QoL app) The plan is to connect several hard drives to one mobile device and simultaneously flash them all for backup purposes, rather than connect the drives one at a time, the plan is to connect them all at once via an on-the-go cable.
For testing purposes, I was wondering if there was a way to emulate external hard-drives on Android Studio?
(Also any tips for the creation of the idea is appreciated^^)
Is it a good phone?
-basic calling, sms
-dual sim
-Light in weight
-basic browsing websites
-Whatapp
-minimal YouTube usage
-Tik tok
-minimal game play 2-3 games (games less 200mb)
*Removable battery (lasting)
-Readily available spare parts
-Budget less $100
I suggest getting a basic Samsung phone, like one of the A series, rather than a whatever it is "Welcome" good-luck-cheapo-knock-off.
AF's foremost authority on China phones, recommends Samsung. :thumbsupdroid:
Help Twitter on Pixel 4, 5, 6
24 hours later and not only does it still not work, but I uninstalled, re-installed, and logged in with my password, and NOTHING WORKS NOW. I am using Android 14 but some people who reported on Downdetector are using Android 13 so it's not the 14 upgrade. What I don't know is how many of us are using Twitter over phone like Verizon/ATT/T-mobile instead of cable like Xfinity/cox/whatever.
I guess you mean android 13, as 14 won't be released until next Summer.
Stylus problems AGAIN
Even the act of plugging your phone into a PC and using it as a USB hard disk is ruined. At one time USB Mass Storage existed and made it easy. Today it relies on something called MTP which I failed at trying to make work. Windows 10 kept insisting it was a camera and wouldn't gain me access to the data other than images, and Windows XP just said 'What?! You need a driver!' so I gave up and now go back to emailing the files one at a time to myself like it was 1999 again. Thanks, Google.
It's unheard of in human culture today, but when a brand name screws me over multiple times, I simply never buy from that brand again. Now, it's avoid anything emblazoned with 'Made in China' on the back. That means any future purchases involve equipment no newer than 1972. Works for me though, I don't need new things anyway.
Basic question about Playstore
My home phone is a Pantech Breakout (2011) running Android 2.3. It's my favorite android version, easily hackable, rootable, and it was the last truly open Android before Play Store and the like. It won't allow a Google login but I don't use it anyway. Email works, Browser works (and third party browsers work around compatibility), phone and messages works, but lately it's running super hot and won't last longer than 3 hours on a charge. Battery stats say 'time without a signal' is 100% but it's got five bars of LTE, and 4 bars of 1x, and everything works. Same issue with the same SIM on my HTC Thunderbolt as well. Must be some kind of network issue somewhere but I can't pinpoint it. It worked fine until July sometime. Now it's acting like its searching for signal but it has signal. Cell Standby accounts for over 80% of battery use no matter the apps you use.
Nothing I use a phone for requires a Google account, or any modern apps. I use the same apps and the same things I've done with a phone I've done since 2010. My needs haven't changed. Music, email, notes, calculator, SMS messaging, phone calls, that's it. I don't need any more than that.
The only thing that has changed, and requied me to upgrade to a more modern phone (Galaxy A13 5G) happened around Covid lockdown time. I got into using a few apps (Walmart, Little Caesar's, Burger King) to get food delivered and now I just am used to using those. Those apps require Android 6+ and the battery was starting to swell (again) in my Galaxy S5 so I got an A13. Should be good for the rest of my life.
My normal policies (ADB delete Play Store, Netguard disable all updates, any apps that don't depend on internet, route all requests to Play Services to 127.0.0.1, reinstall all my Android 2.3 apps, skeuo up the UI, etc) still apply.
Sending "Clickable" links to unsaved/new number
I believe that's the default setting for WhatsApp. You can disable it in the Settings > Account > Privacy > Groups options.
WhatsApp is Meta/Fakebook, and since when did they care about your privacy.
No. You have missed my question. I need to know how to send a message to an unknown number ( who has never interacted with me, nor has saved my number in their contact). And, when i send the message which contains a link, it should be clickable to the receiver. Generally, it is not possible. But, few have a workaround. I am interested to know about that work around.
Find My Device app asking for gmail password
The Find My Device app requires your Gmail password because app is itself tied to your online Google account. The app isn't just connected to your Google account, it won't function without that link. The first time you started up your phone, part of the setup process involved entering your Google account info. That linked the phone to your online Google account. The Find My Device app is developed and maintained by Google, and without that link between your phone and your Google account, you wouldn't be able to use the Find My Device service to remotely track your phone.
Find Lost Android
My friend's phone is missing. I think it has Lost Android or Android Lost on it. I'm not sure how to use it, though. I went with googoo instead and it apparently found the phone but can't contact it now, though it did earlier. It might be in the vehicle of someone he knows. Is there any way I can call up his contacts list and find the number? If we can call this person instead, maybe we'll be able to find it.
you can just ping it whatever operating system you are using you can ping it your return will be the Geo location numerical date to locate it
Help Screen lock apps
Hi, thanks for the info... re 'Personally I just use the lock screen that's already integral to Android' I don't just follow you here, I didn't know Android had a lock screen app hence the existence of so many apps filling that gap ?
cheers
A good way to get familiar with the features in your phone is to just sit down and go through the Settings menu. There are usually a lot of third-party alternative apps that duplicate existing services on your phone, often with bigger feature sets and added capabilities than the stock apps. But don't forget to always pay attention to the background details of the apps you install (where you obtain them, the developer's reputation, etc.) Adding more apps just on a whim also involves possible security and/or privacy problems.
Help Escape Room Magical Mystery
Join me in these amazing escape games and take an exciting adventure into the world of magical stories to an unforgettable journey to solve its mysteries. Fantasy escape is a new point-and-click adventure game in the "escape the room" genre with complicated quests. Play logic puzzles and brain teasers in one of the best new escape games free! In this one of the top room escape games your goal is to unlock the door escape needed to become an escape hero!
ldmUs_spRVToOh7PF4mIoR2G63GEIvP8Sggf21kQqURGkQlvglkXWehS1mEn6k8RDyCl=w240-h480-rw
https://play.google.com/store/apps/...sy.Room.Escape.Magical.Mystery.Adventure.Game
Your Adventure begins now! This escape game is made for you. Explore great adventure, fantasy locations full of magic and mystery! Will you be able to solve many riddles, challenging gameplay, different mysteries, and can you escape?
3EsZ8oMmU86nrBFKUr_h_ioSHAPY9TciZfYwsv2KucxFML6SX3nGWOd-ChAwgQPrv5g=w526-h296-rw
Can you escape the 100 rooms to solve the mystery? Get ready for your own escape games in a fantastic world. In a game full of complex puzzles and a great new environment ready to be explored and Challenging brain teasers and making your escape plan for exit as fast as possible from this mysterious fantasy place! Witness a new room escape game with escape puzzle systems and make it fast to the exit door!
G1JGPUiIxu2slawb36KAkiCGgsold8W1e06L6apqeiqiu_L3Dz8pzK6WFH53fEogUd0=w526-h296-rw
Use your brain skills to find the answer from mysterious puzzles, collect clues and needed items, Analyze and investigate every place of the room! In this fantastic world of escape games and puzzles. Escape game this fun, exciting and addictive fantasy adventure game!
Step inside our magical locations to search for hidden objects. Solve hundreds of brain puzzles and riddles.100 doors is a mystery game that offers a different kind of puzzles. Find a magic way to get out of each room. While this escape game is absolutely free to play, you have the ability to unlock optional
Get away from classic puzzle games and experience a new way of room escape gaming. Every level needs an escape plan, make your exit plan with no fear! Combine information collected from each room to get to the next room.one of the best fantasy escape games you ever played! An addiction improves your logical thinking and your puzzle solving ability! Find the clues and win the room escape challenge!
Hello, Escape Legend fans! Here is another one of the best escape games waiting for you! If you like fantasy and fairy tales mystery, You can open a lot of different doors. To Escape behind each door.
⭐⭐⭐New Features:⭐⭐⭐
⭐ 100 Fantastic locations and beautiful graphics
⭐ Unique fantasy escape stories
⭐ Visit more than 50 magical levels
⭐ Addictive Brain Teaser
⭐ Amazing Logic with hidden objects.
⭐ Explore different themes and rooms
⭐ Exciting search for hidden objects
⭐ Challenging Puzzles
Download Fantasy magical games and the best puzzle adventure is waiting to be solved! The greatest escape journey begins now. Enjoy fun!
Filter
