Screen protector
- Smartphones
- 8 Replies
Whitestone Dome Glass for Samsung Galaxy S22 Ultra. The Whitestone Dome Glass is one of a few all-glass screen protectors recommended for the S22 Ultra
Have you installed any screen orientation apps?
Maybe one that lets you put the screen in an orientation that it normally would not do?
I use one that has a habit of turning itself on whenever the device is restarted.
I use Greenify to turn it off automatically, so it does not bother me anymore.
never heard of them. but they have plenty on Amazon which has a good return policy. if you do not like it just send it back. spigen is always my go to as i have said before. i would give them a go. they quite a bit more on some cases though. but to me, its worth it. they have saved my very expensive z fold 3 from certain ruin.
When i read first massage, I wanna advice you re-install appFound them! I had to uninstall, then re-install
So what you're doing is apparently going into your A52's Settings menu and changing Display options but it's important you keep in mind that this affects your phone's screen. Or in other words, the changes you make affect how everything appears to you on your phone so this may change how your pictures appear but it also involves everything you do on your phone. You're changing the phone's display properties but not correcting the actual photo files themselves (the former can always be changed back again, just re-do what options you changed, the latter will be more involved.).....
Went into settings - Display and set to LIGHT and VIVID. White Balance set at full on to WARM. Max for R and G and half way for B. Adaptive Brightness is on. Brightness set at 50%.
