Jailbreak Fire8
Is there a strictly android OS than I can install on a Fire 6 Tablet? Is the 8 a 32 or 64 bit device?
Sounds like the most reliable thing to do is to just root the native OS that's on the device. I would be able to install from google then?
this is the forum you want with all things root related for your device:
https://forum.xda-developers.com/f/fire-hd-8-and-hd-10-android-development.4713/
xda is always the best source to find if a device is rootable and to find things like custom roms, kernels and recoveries.
also if you plan on rooting here are somethings we have hear for you to read:
https://androidforums.com/threads/before-you-root-read-this.909662/
https://androidforums.com/threads/youve-rooted-your-phone-now-what.617220/
https://androidforums.com/threads/rooting-best-practices.450904/
and here are some root terminology:
https://androidforums.com/threads/root-terminology.443075/
Help Is my Android infected with spyware? How do I find out?
Since you will not receive month security patch update on phone then try getting some paid antivirus tools but it will make the phone slow.
anti virus apps are worthless on android. there are no viruses in android......malware, yes......viruses, no.
just be smart on what you install on your device and you should be fine. but the op has a rooted phone which makes it vulnerable to malware apps. but again, as long as you are careful on what you install on your device, it should be fine.
What is the lock/unlock icon on task list?
Do you have your phone or a third party app lock certain apps, i.e., when you tappy tap on them, do you need to enter a pin or code?
Thank you. No, it seems a builtin feature in Stock Android, but i do not know what it does mean .
I can lock and unlock each application in the task list but i do not know what i have locked and unlocked then...
I suspect it does mean some "keep in main memory" feature or something like that but i'm not sure in that.
Help Usb not connecting my phone to windows 10
May well be something wrong with the PC, Could be a software problem, could be a hardware problem, impossible to say without seeing it and/or having more information.
If it's software. Check the Device Manager in Windows, see if that's showing any errors. Maybe the motherboard drivers need re-installing?
If it's hardware. Could be a fault on the motherboard? If you don't know what you're doing with diagnosing computer hardware, consult a competent PC technician.
Thanks for the reply I will try reformatting and installing the drivers.
Apps how to do button with transparent background
hello i have an app with a big button in the middle of the screen and it looks like this:
and the (coordinator) fragment layout file looks like this:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout
xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:layout_height="match_parent"
android:eek:rientation="vertical">
<View
android:layout_height="276dp"
android:background="?android:attr/listDivider" />
<LinearLayout
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:eek:rientation="horizontal"
android:layout_gravity="center_horizontal">
<ImageButton
android:id="@+id/send_btn"
android:layout_width="186dp"
app:srcCompat="@drawable/ic_circle"
android:contentDescription="send text to device" />
</LinearLayout>
<TextView
android:id="@+id/receive_text"
android:layout_weight="1"
android:freezesText="true"
android:gravity="bottom"
android:scrollbars="vertical"
android:textAppearance="@Style/TextAppearance.AppCompat.Medium" />
</LinearLayout>
i'm wondering how to get that background on the button to be transparent.
Help What are these notification icons for?
no idea. what phone do you have? do you have access to said phone? you can always look in the notifications in your phone's settings to find out.
but
something tells me this is not your phone. the problem is that there are millions upon millions of apps out there, each with their own notification icons......sooooooo......unless it is something popular like facebook or youtube, the chance of somebody recognizing it is very small. we get this kind of question asked almost on a daily basis. most of them go unanswered. the true way to know is to look in the phone.
so why not just ask?
Thanks for the response, phone is a Samsung S20, I will most likely end up asking under the right circumstances. Last time something like this came up, I was lied to and had to do some digging to prove the lie. Hoping this isn’t the case this time.
Help Identify this notification symbol
please help me identify this android notification symbol
but
so why not just ask what it is?
Newbie Help - App Subscriptions for Google Play
Welcome to Android Forums.
I hope this is the right place to ask this- please redirect me to the proper thread if this isn't it!
I can't answer any of your questions but this, sorry. :( You are most definitely asking in the right place. Hopefully someone can help. :)
I've submitted my first app to Google Play and I've gotten it close with a group of beta testers to where I want to do my big launch.
And just so I'm not a one trick pony, congratulations of nearing release and good luck!! :)
New App: Tower Defense Castle golden (Version 3.45)
My friends! I hasten to inform you that today I posted updates, a lot of work has been done, new maps with different locations have been added. Created a destroyed city that can be rebuilt and every building will benefit. Also added the ability to pump the hero. I thought that at least one of you would write a comment. If you liked the game, I will post the promotional codes here. I was in a hurry and there are a lot of minor problems in the game, do not judge strictly, I will fix them.
Filter
