Does Samsung's password manager actually work?
Has anyone used Keeper as their Password Manager and if so , how is it ?
Dittoi don't get ads when i use google photos. i love the fact that all of my photos are backed up on the cloud with me not having to do anything. plus i can take a photo and almost instantly i can get that photo to my pc without having to hook up any wires and such.
but to each their own. i am glad you found something that works for you.
Ok.. you're right. Then he is right. He's just not one of the cool kids.The Chief was here before either of us![]()
I definitely agree with the stupid stuff but I also remember when remdesivir was touted as working to stop the covid symptoms there was a concerted effort to block that information from being posted also.
This does work. Thanks. 😊Right click on the bell, and open with a new tab.
Stop thinking! You will only hurt yourselfI'm starting to think the OP is a bot 🤣 🤣
FWIW though, Phantasy Star online had the same moniker there as well as Dot hack series, sure it was a check in the game the message fourms you get form playing in the game, without an online connection, same as PSO.The Dreamcast was a great console, unfortunately the infrastructure for online gaming wasn't there yet.
NFL 2K was so much better than anything Madden had at the time.
I've gone completely away from beer. We buy the Truly Variety pack that has the berry flavors. If we go out to dinner I just get a gin and tonic.My wife, if she drinks anything, it is a Truly Berry Seltzer. She rarely has a drink. Me, I drink something every day. Tonight I'm drinking regular Shiner Bock beer.
I worked through a lot of it, but right now I am trying to figure out what, if anything, "Turn off at 90%" (Battery saver turns off when battery reaches 90%) does. I know what the words mean and what it says it does, or is supposed to do, but when it is enabled, I am not seeing anything happen.Hi, what exactly is your problem ?
iDrive apparently offers several levels of backup services, with the free level being limited and other pay-for levels with more features when you pay more accordingly.Idrive. If I use smart switch I don't know if the files and folders will get dumped where they were originally.
ADB commands are well documented on the web. But it's not clear precisely what you want: what "restricted settings" do you want to change? Is "restricted settings" DooGee's name for Developer Options, or is it something else? Your first post talks of the 3 dot menu being gone from "the app" but doesn't say which app. Without knowing precisely what you want to do it's hard to suggest anything more than "look at the adb documentation and see if there's anything that looks helpful".Are there any known ADB bridge commands for me to try. I used one that helped in controlling themes.
Or you might need a DooGee expert. There are always differences between "android X" and "manufacturer Y's software based on android X for device Z", and people commonly assume that when a feature changes with an update it's an Android change when very often it's a manufacturer change that comes in the same update (as manufacturers often change their UIs at the same time).But I need an Android 13 expert to give me good tips.
Sure if you lived in the ninties.SP Bullet with Butterfly Wings "The world is a vampire" makes a great ringtone!
I don't see myself getting anywhere near an Advantage plan, BUT in some states where they have minimal copays and minimal annual maximum out of pocket expenses, I would consider it. My state is like most states. Lots of out of pocket. SoCal, Florida and Oregon are three states that I know of that have good Advantage plans.They are chatty. I have United Health Care advantage plan. They are the worst at filling my box with trash.
Since meteorologists are never right anyway there is no 'sure'.If you have more than one you are never sure...
