Flag/crown notification in status bar
It doesn't look like any form of dating app. Nothing about it says chat either. I saw it as some sort of document, though whether it was supposed to be a ticket, a page from a planner, from a newpaper or magazine, or from a webpage or blog, it's impossible to say.
(Of course chat apps also have many uses other than dating - I have 2 that my wife doesn't have, which are used exclusively for work discussions).
The truth is that we get a number of these queries most days, and they are almost all "is this a dating app?", so you are far from alone. It seems to have been something that's developed over the last couple of years, before that we never got such queries - I suspect there's a thesis there if any sociologists are reading this ;). But there are so many apps out there that in many cases nobody can identify the particular icon, so if you really care the simplest answer is to ask him or her.
Apps Bluetooth discovery issue - Jetpack Compose + Kotlin
If you are using android.permission.ACCESS_FINE_LOCATION I have found that you must also have android.permission.ACCESS_COARSE_LOCATION.
My Manifest permissions look like this
<uses-permission android:name="android.permission.BLUETOOTH" />
<uses-permission android:name="android.permission.BLUETOOTH_ADMIN" />
<uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION" />
<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION" />
<uses-permission android:name="android.permission.BLUETOOTH_CONNECT" />
<uses-permission android:name="android.permission.BLUETOOTH_SCAN"/>
Hope that helps
Screen won't break
So after starting this thread I somehow managed to scratch it. Definitely get a screen protector folks.
Then you can try a screen protector from Gadgetshieldz where I bought one for my S21 Ultra and it gives good protection. I dropped my phone 3-4 times but it had no impact on my screen because of this protector. I'll drop a link for you,
https://www.gadgetshieldz.com/samsung-galaxy-s21-ultra-screen-protector.html
Nokia G50 Smartphone
Thanks.
I was having trouble acessing the phone's files from my PC to download camera photos and thought I might have encountered some major issue with Nokia's Android implementation.
I realised eventually I just needed to give the PC access from the phone's notifications when I plugged in the USB lead. I never needed to do this with my old Samsung Galaxy J5 phone. However I do remember having to do that with some of my other older android devices.
ok well i'm glad you were able to figure it out.
The new recommendations for preview assets on Google Play
I found the answer to my question. Phrases like "Create your own visualizer" and "Visualize music from any player" are not defined as Call-to-actions here. It is only the obvious Call-to-actions like "Download now" and "Install now", which are not recommended. I got the answer to all my questions in a course from the Play Academy, called "Google Play Store Listing certificate study guide".
The information there is much clearer and detailed than in the official document:
https://support.google.com/googleplay/android-developer/answer/9866151
The only thing I wonder now is if premium features can be mentioned in taglines for screenshots. If microphone visualization is only available in the premium version, is it then OK to have a tagline like "Visualize from the microphone"? Or should the tagline also mention that this is only available in the premium version? If so, the tagline would probably be too long according to Google's recommendations, since the text should not be too small and the text should not occupy more than 20% of the screenshot.
Need help factory resetting
Not much u can do, other than use it as a paperweight......
  • No adb
  • Can't go to recovery mode( are you sure you are doing the button combo correctly?)
  • You would also need USB debugging enabled as well, and I doubt that it was.
........ sorry
Yeah, I have another of the exact same tablet and reset that no problem. That's upsetting. I'll keep trying for fish for a solution and thanks for the reply anyway.
Filter
