what server i can use for pubg like game
- By ocnbrze
- Apps & Games
- 2 Replies
"pubg like game"? what game are we talking about? wouldn't the server be determined by what game you are playing?
They were not pets, they were (are) working animals.Also their pets who also fought amongst with them. Do not forget about their pets.
How can I calibrate my stylus with Ibis paint. The draw line is about 1/8" below where the tip hits the screen. I have a Galaxy F9+. Thanks for any help....
Well, allow me to bury my head in the sand.
Your reply got me to look at the cord (which has always worked in the past). I traced it with my gaze from the phone all the way down to... the AC adapter on a power strip. Oops.
Lousy way to transfer data.
Thanks. You are an inspiration.
what happened? if you don't get specific we can't help.Yes,
I have tried that also but no luck
Can someone tell me how to block spam messages. I have GMAIL, and the spam is coming in crazy!
1. Yes, doing the "Clear Data" option probably erased the backups. That's why it's important to also upload the backup to Google DriveHello,
I have an issue with Whatsapp as I am not very familiar with it and I am trying to get help with it.
Two days ago, I cleared the data in my whatsapp accidently (s21 ultra). Then, I pushed the button backup thinking that it will ask me to select the backup file that I have.
But, It seems I deleted the old backup and overwrote it with nothing. Therefore, I lost all my data.
As I know, we can find many backup versions in the phone (Internal storage/Android/media/com.whatsapp/databases). But, I found only one file "mgstore.db.crypt14".
I want to know, if possible :
- How all the old backups were deleted ? is it due to clear data option ?
- Is there any solution to find that old backup ?
- Should I use Data recovery software in order to find what was deleted ?
The smallest help will be more than appreciated.
Thank you,
Amin Gaaloul
Message forums is our place to stay in forever. Gee heard of having a heart?LOL what hotel??
Thank youNot all icon packs are designed to be used in all launchers. You should be able to tell if one will work with your launcher from the description given in the play store.
NICE!!!!!!!! did they say what happened? was it something on their end?Chatted with trac-fone ... they solved the problem.
