Tetrd — USB Tethering & Reverse Tethering (NoRoot)
Hello ramencoder,
Just wanted to say I love your app. I use it to bypass the tether throttling on my T-Mobile phone, which as of today stopped working when I changed the TTL to 65. Your app is the only wait for me to get full speeds on my Mac. I'm even able to share my connection using tethering over Wi-Fi from my Mac! My question is this:
I'm able to see tetrd as a network interface in Macos "sharing" menu in the system preferences. But I can't see it as a network interface in the "network" menu in system preferences. I'm trying to work out how T-Mobile knows that I'm tethering even though I've changed my TTL to 65, which used to work for wi-fi. But I'm not able to go into the network settings and adjust or even view IP information / proxy information because to etrd only shows up in the sharing menu and not the network one. Can you please help?
How to remove or hide this volume notification in Android
What is your problem with it?
It should only appear for a few seconds when the volume is changed.
If it lags on the screen for an extended time, that could be a sign that the device has too many things running- such as having multiple apps using accesibility service.
This can slow a device down so much that toast messages like that can linger for about 15 seconds.
If it only appears for 3-4 seconds, then it is normal and cannot be avoided.
Apps Sharing image on Whatsapp : Android
Hi I am trying to create a simple android code of sharing QR code image via Whatsapp.But even though QR code is being properly generated and image is being also stored in the emulator, the image share to Whatsapp(via Intent) doesnt happen and the application crashes in phone but works in emulator.Here below is my code snippet.
public void onCreateContextMenu(ContextMenu menu, View v, ContextMenu.ContextMenuInfo menuInfo)
super.onCreateContextMenu(menu, v, menuInfo);
// you can set menu header with title icon etc
menu.setHeaderTitle("Share It");
// add menu items
menu.add(0, v.getId(), 0, "Share on Whatsapp");
menu.add(0, v.getId(), 0, "Share on Email");
public Uri getImageUri(Context inContext, Bitmap inImage) {
ByteArrayOutputStream bytes = new ByteArrayOutputStream();
inImage.compress(Bitmap.CompressFormat.JPEG, 100, bytes);
String path = MediaStore.Images.Media.insertImage(inContext.getContentResolver(), inImage, "Title", null);
return Uri.parse(path);
@override
public boolean onContextItemSelected(MenuItem item) {
if (item.getTitle() == "Share on Whatsapp")
Uri imageUri=getImageUri(getApplicationContext(),bitmap);
Toast.makeText(getApplicationContext(),imageUri.getPath().toString(),Toast.LENGTH_SHORT).show();
// Log.e("Check",imageUri.getPath().toString());
Intent shareIntent = new Intent();
shareIntent.setAction(Intent.ACTION_SEND);
//shareIntent.putExtra(Intent.EXTRA_TEXT,title + "\n\nLink : " + link );
shareIntent.putExtra(Intent.EXTRA_STREAM, Uri.parse(imageUri.getPath()));
shareIntent.setType("image/*");
startActivity(Intent.createChooser(shareIntent, "Share image via:"));
//Uri imageUri = Uri.parse(pictureFile.getAbsolutePath());
/* Intent shareIntent = new Intent();
//Target whatsapp:
shareIntent.setPackage("com.whatsapp");
//Add text and then Image URI
// shareIntent.putExtra(Intent.EXTRA_TEXT, picture_text);
shareIntent.putExtra(Intent.EXTRA_STREAM,imageUri);
shareIntent.setType("image/jpeg");
shareIntent.addFlags(Intent.FLAG_GRANT_READ_URI_PERMISSION);*/
try {
startActivity(shareIntent);
} catch (android.content.ActivityNotFoundException ex)
//Toast.makeText(getApplicationContext(),"Exception "+ex.getMessage().toString(),Toast.LENGTH_SHORT).show();
Log.e("Error",ex.getMessage().toString());
//Toast.makeText("Whatsapp not installed",Toast.LENGTH_SHORT).show();
//Toast.makeText("Whatsapp not installed", Toast.LENGTH_SHORT).show();
else if (item.getTitle() == "Share on Email")
return true;
Here is the crash report on phone
java.lang.NullPointerException: uriString
at android.net.Uri$StringUri.<init>(Uri.java:490)
at android.net.Uri$StringUri.<init>(Uri.java:480)
at android.net.Uri.parse(Uri.java:452)
at com.sudarshan.qrcodegenerator.MainActivity.getImageUri(MainActivity.java:109)
at com.sudarshan.qrcodegenerator.MainActivity.onContextItemSelected(MainActivity.java:117)
at android.app.Activity.onMenuItemSelected(Activity.java:3628)
at android.support.v4.app.FragmentActivity.onMenuItemSelected(FragmentActivity.java:436)
at android.support.v7.app.AppCompatActivity.onMenuItemSelected(AppCompatActivity.java:196)
at android.support.v7.view.WindowCallbackWrapper.onMenuItemSelected(WindowCallbackWrapper.java:109)
at com.android.internal.policy.PhoneWindow$PhoneWindowMenuCallback.onMenuItemSelected(PhoneWindow.java:3750)
at com.android.internal.view.menu.MenuBuilder.dispatchMenuItemSelected(MenuBuilder.java:776)
at com.android.internal.view.menu.MenuItemImpl.invoke(MenuItemImpl.java:148)
at com.android.internal.view.menu.MenuBuilder.performItemAction(MenuBuilder.java:923)
at com.android.internal.view.menu.MenuBuilder.performItemAction(MenuBuilder.java:913)
at com.android.internal.view.menu.MenuPopup.onItemClick(MenuPopup.java:128)
at android.widget.AdapterView.performItemClick(AdapterView.java:318)
at android.widget.AbsListView.performItemClick(AbsListView.java:1165)
at android.widget.AbsListView$PerformClick.run(AbsListView.java:3145)
at android.widget.AbsListView.onTouchUp(AbsListView.java:4077)
at android.widget.AbsListView.onTouchEvent(AbsListView.java:3831)
at android.widget.DropDownListView.onTouchEvent(DropDownListView.java:116)
at android.view.View.dispatchTouchEvent(View.java:12558)
at android.view.ViewGroup.dispatchTransformedTouchEvent(ViewGroup.java:3079)
at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:2727)
at android.view.ViewGroup.dispatchTransformedTouchEvent(ViewGroup.java:3085)
at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:2741)
at android.widget.PopupWindow$PopupDecorView.dispatchTouchEvent(PopupWindow.java:2407)
at android.view.View.dispatchPointerEvent(View.java:12804)
at android.view.ViewRootImpl$ViewPostImeInputStage.processPointerEvent(ViewRootImpl.java:5428)
at android.view.ViewRootImpl$ViewPostImeInputStage.onProcess(ViewRootImpl.java:5219)
at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:4730)
at android.view.ViewRootImpl$InputStage.onDeliverToNext(ViewRootImpl.java:4783)
at android.view.ViewRootImpl$InputStage.forward(ViewRootImpl.java:4749)
T-mobile Data breach and sim swapping scam
Huh? To swap sim cards doesn't a new card have to be inserted ?
yes....this is from the article:
Regardless whether you're a T-Mobile user, the exposure of account PINs is a major danger. That's the password that you're asked to give to a T-Mobile employee before any changes can be made to your account. A scammer who knows your account password can call customer care and ask to have the SIM card linked to your phone number changed to a new SIM card and device, effectively taking over your phone number.
AUHB Global, Exynos update
This YouTube video by Velian takes a run through of the AUHB release...
I must say that his AnTuTu and GeekBench benchmarks seem a little on the low side compared to the ones I have got... without putting my phone in the fridge first.
AnTuTu AUHB benchmark
GeekBench AUHB benchmark
Been on AUHB for 10 days and it is both battery friendly and cooler as well as fast.
Filter
