this happened when the URL changed
- By ozonetrooper
- Suggestions & Feedback
- 99 Replies
Who is your ISP ?
not all threads have this option. this thread, for me, does not have that option.Try clicking on a thread. It should bring an option to follow if you aren't following or to unfollow if you are currently subscribed.
Back before meme images were a thing you'd get jokes circulated by email. One I remember was a "Microsoft press release" announcing that since their user surveys had discovered that the activity Windows users spent most time doing was "staring at the blue screen of death" they were planning on selling advertising space on it...Windows 11 doesn't have enough ads, says Microsoft's latest plan to force more ads onto your PC
Then do a factory reset
I have used it a few times, and pretty much if you want to glance at it head over to the XDA developers, that is the first time I have heard of it to turn off the fingerprint haptic.never used SetEdit SettingsDatabaseEditor - Apps on Google Play before so i can't comment really on how to use it. the only thing that i see in the app is for enabling haptic feedback. it shows no specifics for the fingerprint scanner. and from what i can gather, it looks like you can only edit the strength of the feedback.....which you can just go to your phone's settings under vibration and haptics to adjust it....no need to use the SetEdit app.
.....but i could be wrong cuz like i said i have never used it before.
www.comingsoon.net
