Stuck sd tray
I've got some good news. After 2 reboots the SD card showed up and it's been working ever since. The phone's charging is not that great, sometimes turbo and others nothing. Rebooting makes it charge, I guess. I have another question about a brand new phone. When I thought the Play wasn't going to work at all, I got a Moto G Stylus. I thought they were always 128 GB, but this is 64. I haven't used it yet because I want to set it up right. I was planning to use the Play's SD for that, but I figure I better not mess with it. There are some apps I wanted to put on SD and put that in the new phone. I can't do that now. Is there some way I could use Bluetooth to send apps to the new phone? Would that be working already on a phone that's barely out of the box? The main thing I want to do is lock it down to keep google and Facebook and that kind of junk from taking over because it's defenseless. I guess I'll have to let it connect to WiFi, but if I could use SD, I wouldn't have to do that.
Motorola About Data Saver
Take into account the chain of connectivity between your computer to the Internet. Since you're using your phone's connectivity as the source, it's the account with your cellular carrier that's the source of that online access.
Your phone has two ways of getting online access -- WiFi and cellular. The two are very different from each other and are not interchangeable with each other. One relies on a relatively low-powered wireless signal, typically supplied by a router which is itself directly connected to a modem that's connected to an ISP's broadband network. The other relies on a more powerful cellular signal supplied by cellular towers and cellular access points (often located miles/kilometers away), Those cellular signals are supplied by each carrier's cellular network. A WiFi signal and a cellular signal are also themselves different frequencies, so it's always one or other in usage.
Your Android phone's Tethering/Hotspot feature is a workaround solution so you can use your phone as a limited-feature quasi router,but you're expecting your phone to magically allow your computer online access for free. When you don't have WiFi connectivity available, that leaves with the option rely upon mobile data/cellular access.
Thanks for the trouble you went to, to explain all that, svim. I have a general understanding of the situation, now. For me, the bottom line is that, for my limited Internet needs, I am not paying thirty-odd pounds a month to an ISP, but more like eleven pounds. As long as I keep a careful eye on the data usage, all will be well. Thanks again!
Samsung Galaxy copy data from SD card to internal memory
What calendar app are you using? I use Google's and it backs it up automatically. And the same goes for samsung. You can also use Samsung's Smart Switch to transfer most of your data.
Sorry, I missed you asking about the calendar app. It's a proprietary one, but I backed it up weekly, so I still have those.
Help Investigate surge in data usage?
Are you actually sure you mean "USB tethering" to sync a Windows app with Android? I generally understand that term to mean "sharing the phone's internet connection via USB", which isn't the same as just allowing file transfer between the computer and phone. It's not obvious to me why you'd need USB tethering to sync an app, but of course I don't know what this app does.
If the computer is also connected to the Internet through Ethernet → modem → Internet, doesn't Windows use that connection instead of the smartphone + data plan when it's connected to the computer through USB tethering?
Computers generally only use one internet connection at a time, e.g. if I plug my laptop into the wired network in my office it uses that instead of WiFi (which it is also connected to). So the question is, if you connect to both, which one will it use? And if you do have USB tethering running but the ethernet connection taking precedence, it will certainly switch to using the USB internet connection if the ethernet is interrupted.
In any case I agree with others: that screen is saying that some other device, presumably your PC, ran up your data usage via either USB tethering or WiFi hotspot.
D-Day June 6th, 1944
I probably will not watch Saving Private Ryan, I've seen it many times. That doesn't diminish my respect, admiration, and appreciation for those that stormed the Beaches of Normandy.
Here's a good one: DDay plus 20: Walter Cronkite interviewed Eisenhower. Amazing stuff! CBS Reports (1964): "D-Day Plus 20 Years - Eisenhower ...YouTube · CBS News1 hour, 22 minutes, 16 secondsJun 5, 2019
Samsung Samsung Galaxy with 2 sims and SD Card?
Having read more, it seems to me that manufacturers are going down this route, for whatever reason i don't know.
Most consumer products are driven by the features that the actual consumer wants. The exceptions to that are cars, which are driven by government regulations and the cellphone industry which seems to be driven by the manufacturers. It's them that determine what features are there. Gone are the days of replaceable batteries, expandable memory and wired headphones.
Can't get Opera as default browser
Today, on my Samsung Z Fold 5, I can't get email links to open up with Opera, even though when I go go settings (phone settings/apps), all browsers say that Opera is the default browser. This seems to have happened after I added some accounts to Aqua Mail. For now, I got links to stop opening with Chrome by disabling Chrome, but I do not think this is the proper or desired way. Chrome was not disabled on my Z Fold 4 and links opened there Correctly. Possibly dome changes got made in Aqua Mail or in my Google account during the email account additions. Any ideas here??
Danny
Just as a subtle tip, I'd focus on just the actual problem, getting the Opera browser app to open web links you encounter in other apps. Adding in other suppositions just adds confusion and misdirection.
-- Have you tried to just restart your phone? If the rproblem is due to a one-off glitch that just popped up, a simple rebott might be all that's required. If the web link problem is still a problem after a reboot at least you can rule that out.
-- I have doubts the AquaMail app is actually part of the problem. It's just an email client, and it's s a different app that is only relevant to email services. It does not have any web browser capability nor can it manage other apps and/or over-ride the settings and configurations of other apps. When there is an web link in an email message, there's only a very indirect 'link' between the AquaMail app and whichever web browser app. Simply your problem started to occur approximately after you added some email accounts to the AquaMail app does not necessarily mean that's the actual cause of the web link problem itself, a classic corrleation vs causation example::
-- Getting back to the web link problem, part of the problem might be a common Google oversight matter. Just purely anecdotally, on my OnePlus phone running 12 my default web broser is the Firefox Forcus app, and I also need to keep the Chrome app disabled otherwise some, but not all, web links in other apps might trigger Chome instead. And yes, in the Default Apps menu in my phone's Settings menu Firefox Focus is set as the default. The issue being some apps, notably Google services apps, are 'hard-coded' to use the Chrome app, no matter what the Default Apps option is set to use. By Disabling the Chrome app that forces all web links to use my prefered choice.YMMV.
Again, that might part of the problem, there's apparently other factors involved. Try resetting the Opera app and then go through the processs of using a different app to open a web link so you can choose Opera as the default to siee if it sticks this time. -- be sure the Chrome app is Disabled, be sure to backup any saved bookmarks in Opera, then go into the Apps menu and use the Clear data option in the Opera apps linsting. Using Clezr data will remove all of that apps settings/config data, along with its cache essentially returning it back to its original firtt time used state. You;'ll need to do a restore of your email account infor and such so it's definitely an involved task.
Samsung Voice typing doesn't recognize the period all of a sudden?
according to this:
punctuation is not automatic. if you pause after a sentence, google will put the appropriate punctuation.
check to see if your phone is up to date.
There has been no changes in awhile to the system that I could see. However, the punctuation started working again on its own, a couple of days ago. Now the question is why does this seem to happen so often periodically (ha! pun).
How to disable Digital Wellbeing?
Yeah, bloody thing doesn't even let you turn off notifications, never mind disable it (at least on my Samsung). I have turned-off what I can, and got to the point where I don't get notifications from it, but that's all. I don't think you can even force stop it: the button is there, but it doesn't grey out after use so I suspect it does nothing (it might just respawn immediately when you stop it, but being cynical I suspect that it doesn't even stop in the first place).
You could root and stop it, or switch to a ROM without it (if you have ROMs for your phone), but I don't think it's worth doing that just for this app.
Default browser for Google Assistant, Bixby, Galaxy s23
I'm looking for another app that is comparable to the features and behavior of Google Assistant, but he key factor is that it will use Firefox as it's vehicle. For instance, when you ask the Google Assistant to look for alternatives for Google Assistant, it will uses the Google/Chrome browser to perform perform it's search and render the results.
Assistant can do more than just search. This is what I was trying to clarify: is it just search you want, or some of its other features as well?
Firefox has a voice search option, but you have to open the browser and tap the icon on the input bar. If you set Google as your search engine I imagine that would trigger a Google search, but I you are looking for constant listening & keyword triggers I don't know how to do that. It should be possible to set a shortcut to open the app itself (I could set a double tap on the power key to do this on my s21), but you'd still have to touch the icon - I don't know a way of opening the app directly and activating voice search in a single shortcut.
Help Easiest backup for thousands of calls
Hi I'm not very good on my phone and I need to back up some files, including 8000 or so recorded calls, which I must not lose. It's a Huawei 20x 5G. It is absolutely stuffed full of really important stuff including the phone calls which I cannot lose, but if I try to back up to Google Drive it will only let me back up 40 or so at a time and it takes hours upon hours. I have in the past managed to put things onto a USB pendrive but the USB port is dodgy and it doesn't always transfer over. If the port breaks then I can't do anything at all obviously as I can't charge it. what is going to be the easiest quickest way for me to get copies of all this stuff? I'm terrified of doing something wrong trying to sort it ! Sorry to sound so totally daft.
Your phone model supports Nano Memory cards, yes? Do you have one?
Transferring your audio library to a NM card should be quicker than uploading to an online storage service. Then remove the card and copy your audio files to a PC (assuming it has a card slot or you have a USB card adapter).
Otherwise, while 8000 audio files are a pretty significant number of files, a big factor you're leaving out is the file size amount. If these are relatively low-res recordings than each file is going to reflect that in its file size, if these are higher res audio than of course conversely they'll each be a lot larger in file size. Also are they mono or stereo? That among other factors are relevant. The point being the total amount of those 8000 files is dependent on a mystery -- i.e. when it takes hours to upload a batch of 40 files that could mean those are high-res audio files, or it could mean you have a relatively slow broadband or cellular connection. Are you using WiFi (broadband, ISP-based) or mobile data (cellular, carrier-based)?
Filter
