Best Games or Apps for 2021
- By sullencab
- Apps & Games
- 3 Replies
Well, I tried Zoom and Skype. They are very useful especially now that face-to-face interactions are limited. What do you use for organization?
.I got one last year once it was released and is amazing. it's huge, but, when I get other phones they feel like fake and nanoHow does it feel in your hand @donb2010?
Thanks so much for your efforts Sir.The trouble is that many manufacturers install their own calendar apps, and they are almost all called "Calendar". So I never make assumptions about what calendar app someone is using unless I at least know what device they have.
I did just enable notifications in the Google calendar app on my phone (I leave them off as I have other calendar apps that suit me better) and created a test event, but it did not produce the type of reminder you describe for me. This may however depend on the device, android version or other settings (e.g. I have a Pixel 2 running Android 11 with always on display disabled). But the Google app, in common with most Google apps, is very limited in what options it provides and I couldn't spot anything in its settings myself that looked relevant to this.
Thank you for support, waiting for commentsI created a channel for your app. Good luck!!
https://androidforums.com/apps/the-curse-of-emily-horror-game-in-the-woods.19738/
I think ARM7, that's usually good for most recent ARM based devices.
An anti-theft system works by being a deterrent, and so is most effective if all phones have it. If it's known that some phones can be re-used easily then even if they aren't as valuable as new ones there's still an incentive for theft, so it's better if the thief knows that your phone will be useless before they get to examine it closely. After all, if a thief grabs the phone off you or you kid in the street and then decides it's of no interest to them (for whatever reason, too new or too old) you've still lost the phone, you or the kid has still had the trauma of having it snatched, and you still have the cost of replacing it.Seems like the manufacturer would turn on the FRP for new phones... but as they age and they're 3-5 years old and basically worthless, they should send an update disabling this feature. It's a pain and no one would want to steal this phone (which has a cracked screen as it is.)
like i said, there are others that might work. try them and let us know which one you like better.not perfec
not perfect but okay...thx.
