Help Android 9 "open with" options for apps
The Kodi forums are back up and in this thread (Kore 3.0 feedback) it sounds like the dev removed the IMDb link due to the site being unreliable. So it was an intentional change. But other's are asking for the feature to be reinstated or at least offered as an option and I posted the same request.
Thanks for everyone's help but I guess it's in the dev's hands now.
Android should make a phone with a better graphics card and with a screen that is slightly wider than normal phone
Android should make a phone with a better graphics card and with a screen that is slightly wider than normal phone. It should have a slightly bigger memory core. Mobile gaming is on the rise more than ever I just think it would be smart to roll something out ahead of the game. Also because In all personal opinion I absolutely want Android phones to always to better than apple products even though it's not that hard for them. Lmao
There isn't a company called "android" that makes phones. Google provide the base Android OS, manufacturers who wish to use it customise it to their hardware. So any company that wants to make a specialist gaming phone is free to do so (the OS is provided free, though if you wish to integrate Google services there are conditions), provided they believe that there is a commercial case for doing so. But "Android" won't because "Android" as a manufacturer doesn't exist.
So far nobody in the industry has concluded that this is a proposition worth investing in. You may think they are wrong, you may or may not be right, but it's a gamble that nobody has felt worth taking. Bear in mind that unless you are one of the market leaders the margins in this business are tight (companies the size of LG have pulled out of making phones because they couldn't make a profit), and a niche device will need to command a high price to be profitable, which then cuts the sales potential, making this a tricky balance to get right.
As a technical matter, when you say "with a better graphics card" I'm afraid no phone has a separate graphics card. The SoC (System on a Chip) includes a GPU, and the manufacturer uses that. I don't even know whether it would be feasible to do anything else, i.e. whether any SoC has the necessary connectivity to drive an external GPU (there's no obvious reason to include that in the design, and components integrated into the SoC have advantages in terms of bandwidth and latency). If there is an SoC that can drive an external GPU, and if anyone makes a suitable external GPU, that will be a more expensive solution. If not then you need to make a SoC with a more powerful graphics system, in which case don't you think that the existing SoC manufactures already try to do this?
If you think you can do better you had better have very deep pockets, because SoC design and manufacture is a job for the big boys. So far precisely 2 phone manufacturers design their own SoCs: Apple and Google. Apple have done it all along, Google have only started recently and have yet to catch up with the established manufacturers in most respects (their chips rely on a lot of Samsung IP), and if you think about how much money Google have to burn that tells you how difficult this is to do. Others use SoCs from specialist designers, with Qualcomm leading the game in performance vs power, and Samsung, MediaTek and HiSilicon all lagging to varying degrees (I didn't count Samsung as a manufacturer who make their own SoCs because strictly speaking their processor manufacturer and phone manufacturer are separate companies, though part of the same group, and their best phones actually use Qualcomm SoCs rather than Samsung ones).
So in reality your best bet for a gaming phone is to use the same Snapdragon processors that many current Android flagships use already, and hope that there is a sufficient market for a "slightly wider" phone with gamer branding. And then you hit the other problem that if your device is sufficiently different from the mass market for this to make a difference you need to persuade the game developers to write for your phone rather than just writing for the much larger market of "slightly narrower" phones.
Traveling to Europe, best option to use phone abroad
It would depend on the eSIM I guess. The data-only ones I use don't include a phone number, so any texting would have to be via a data connection of some sort. I'm sure you can get some with regular telephony too, but that didn't interest me: I'd have to tell people a different number to use for a week, if they sent me a text they'd pay international text prices, just didn't seem worth the effort.
However I very rarely use SMS these days anyway: with MMS being both inadequate and (on many UK tariffs) expensive, while SMS is quite limited, like a lot of people I've moves most of my messaging to third party internet-based services (WhatsApp, Signal etc). So to be honest I never even bothered checking how/whether I could make that work.
Rooting Tecno F1
never use apps that claim that it can root your phone.
here try this guide:
but first you will need to unlock your bootloader:
Why can't I send voice recordings in text message?
Hi, welcome to Android Forums.
As I understand it, the IPhone uses Imessaging to send audio, video and picture files. Imessaging is sent using your mobile data or wifi connection and is the equivalent of MMS (multimedia messaging service).
Text messaging (SMS) uses a small amount of bandwidth within the communication channel between your cellphone and the network and is restricted to 160 text characters per message. This why even the most basic cellphone can send text messages.
To send audio, video or picture files you need to create an MMS message.
Hope this helps.:)
I have always had an Android and over the last month. I have been unable to send voice recordings through text. I don't know what's going on but this is a new development
How can I stop my phone from updating?
rohansaadat2 – Thanks for the reply.
I tried installing both KingoRoot and SuperSU on my phone, since they are known to be able to proviide apps with root permission, but neither was able to run.
I do have X-Plore installed on my phone, and a *update* search under /system found:
/bin/update_engine /bin/update_verifier /etc/init/update_engine.rc /etc/init/update_verifier.rc /lib64/libupdate_engine_stable-V1-cpp.so
and a *ota* search under /system found ten files, of which
/bin/otapreopt
may be relevant.
Should I modify any of these files? If so, should I do that before or after rebooting my phone (as it has asked to be done)?
Hear me out— not a loon
I really don’t want to be that guy but those this log line mean
that worked! At least on the s23. Thanks so much.
was looking into the logs from the from the bootloader screen and it just looks like there was an MDM and some other scripting that ensured a reset would always fail. At least I think so— pretty much a layman
Also! I remember once hearing from a “pro” that my kernel was not an official one.
Wechat QR code scan
I want to login to a game with wechat, can you help me for that ?
did you not read his post????
To err on the safe side, I'm now only doing WeChat account verification QR scans for users I've seen and know in person. As I don't wish to assist anyone who may have got banned from WeChat for spamming, or illegal activities, etc, as that might put my own WeChat usage at risk. That's how it is.
I am aware there's a black market for paid WeChat verification QR scanning...Good Luck!
If anyone just needs a general purpose messaging and calling app, I recommend Telegram or Signal, but those are not available in China(unless using a VPN).
Why do youtubers hide or censor out applying thermal paste
"I'm gonna use the perfect amount of thermal paste" proceeds to edit part of video out or move camera
--Tronicsfix
"oops, gonna need to put thermal paste on that [moves camera where the user can't see the process]"
--Adrian's Digital Basement.
The term "the perfect amount of thermal paste" line is also used across the board, always hiding/censoring or making a joke about people seeing the process each time. Is there a joke/meme I'm missing or what? I don't understand. What if I am interested in building a PC and would like to see the process? I hate being out of the loop here.
Because the internet loves to argue, and every redditor and their dog would flood the comments about how you're using the wrong amount. Even on Reddit, such images always generate floods of comments about how someone used too much, too little, didn't apply it right, and it happens with stunning and sobering regularity. Even when other channels have shown that barring something especially conductive being used and bridging vulnerable points on a given device, one can go ham and it would run fine. Ultimately, it's about having enough to fill in the micro-gaps between the component generating heat (cpu/gpu/etc) and the contact of the cooler.
How to stop Google Maps from showing the Media Playback Controls if the setting to turn it off is not where the help documents say it is
If the problem is not solved still, you can try this. Disable Media Playback Controls on Google Maps for Android version 13 on your phone.
  1. Open Google Maps.
  2. Tap your profile picture in the top right.
  3. Go to "Settings."
  4. Navigate to "Navigation settings."
  5. Look for "Media Playback Controls" or a similar option.
If the setting isn't there, it's possible that the feature is not available on your specific Android version or device model. You may want to check for app updates or contact Google Support for device-specific assistance.
Right, the problem is it's not there. But the feature is enabled, because I have the media controls. The problem is I can't turn it off!
How to add to sharing options, send to my mail?
Did you not follow my steps from previous?
If you aren't doing this correctly then I can't help you
As I mentioned in my recent post, there is no option in the share option to send a link to the article directly to my email account, although based on a weird algorithm, some of my contacts' email accounts which I recently sent email are showing up there. My email account is not there, however.
Please post here a picture with your Google news share option with your blurred email.
Anyone experienced the Octo trojan?
Those are all browser redirects, no malware or octo whatever. Start using a good ad blocker that will stop these from popping up and you'll be fine.
Personally I use Adguard, which is not in the play store but is 100 percent safe and I've been using it for years without ever an issue. Get it here :
Can be installed on all OS, Android, IOS and computers
Facebook ad on my phone's opening screen
I have an ad on my phone's opening screen that says "Facebook. Find friends and see what's new". To be clear, this is the screen that appears when I turn on the device and before I enter the PIN to access the phone.
I used my desktop computer to make a facebook account several years ago to find a friend from my remote past. Couldn't find that person so closed the account and haven't accessed the account in several years and have never accessed it on any phone I have ever owned.
  • Why am I getting this ad?
  • How do remove it and prevent it in the future?
I think you're referring to this notification, which I also got on some of my phones:
Basically, it is an "ad" sent from the Facebook app itself that's installed on your phone (often as pre-loaded, or "bloatware" since that's what people loves to call those as) when there are no accounts being signed into. Holding on that notification shows this:
The easy way to stop that ad from coming is to turn that notification category off, or disable the app (I assume that it came pre-loaded on your phone and can't be uninstalled) if you don't plan to use it.
(I also apologize for replying to this old post here, but seeing how incredibly stupid that yadic guy was, I just had to do it.)
AntiVirus blocking install
Malware, trojans, etc. but never a virus.
I think you misunderstand the "virus" part of "anti-virus". It's true that, strictly speaking, trojan horses (for example) are not viruses. But the "virus" in "anti-virus" does not use the strict meaning of the term! "Virus", in-context, simply means "malicious software". Malicious software are trojan horses, classic viruses, etc.
That, or I'm missing something here.
BUG: "currently unable to send your message. It will be sent automatically when service is available"
This was happening with Android 12 on the S20 FE I had two years ago too. It's a One UI thing across the board.
But if it were possible to root and put Android 2.3 on this thing, I would have by now. I hate modern Android and went out of my way to skin it to look like Android 2.3 and Sense 3.x, with TouchWiz notifications/ringtones.
Filter
