Apps Help with system design
There are already apps that do this very thing.
The one that I use?
NewPipe.
https://f-droid.org/en/packages/org.schabi.newpipe/
https://newpipe.en.uptodown.com/android
It seems that this app just helps to experience videos from youtube better. I mean a separate app that takes and processes the audio coming out of the phone's speaker (eg while watching youtube). Thank you for the help
Who can make a simple Android app
Hi,
I develop lots of little programs for my home and now I just need a very simple app that i can use with my programs. The app should do only 2 things :
1. read a barcode
2. save it on the phone in a text file (1 barcode per file)
Important is that after each barcode is read, it is stored in a separate text file on the phone. the file must have a unique sname so preferably based on date and time (incl milliseconds)
Thats all because I can read, write and delete in an android phone so I can check these files, so I can use my phone as a barcode reader :)
Thanks in advance. You can contact me on my email <mod removed email, reply below or PM>
Thank you and have a splendid 2021 !
Help Radio Transceiver/Radio Hopping
Out of curiosity, which transceivers are you referring to? I've been looking for a transceiver that is Bluetooth compatible that I can connect to my Android. Do you happen to know any?
I appreciate it. Thanks!
The only software defined radios I know and have seen are USB, and have only seen them been used with a computer(running Linux or Window). Devices like these. https://blog.bliley.com/10-popular-software-defined-radios-sdr
The only one that's apparently Bluetooth is "The Ubertooth One is an open source 2.4 GHz wireless development platform suitable for Bluetooth experimentation." So make of that what you will.
Is it ham radio use you're looking for or something?
Android Wearable App development query
I don't think it would take any more development time and resources than for Apple Watches, but I'm also guessing that they had more demand for an Apple Watch version. Those seem to be a lot more popular (particularly with the golfers I know) than any of the Android-based wearables.
There are also several different breeds of Android wearables - Google's Wear OS, Samsung's Tizen, Huawei's whatever-they-call-it, and then a whole bunch of cheap watches from unknown brands which run straight Android (usually poorly).
I love my Wear OS watches but I totally get why developers aren't keen to port their apps unless there's a significant demand for it.
AFAIK Huawei uses the open source code to Wear OS, but what they do with it doesn't have much to do with Google.
Help Android 9.1
yeah that one says 9 so its not 9.1.
and what 'bs' are you talking about? is it just the number? or some system app?
Here are a few that just seem alil strange to me (screenshots may be out of order cux phones being stupid atm)
Developers, Here is how to announce apps on AndroidForums.com
Option two for creating channels.
Install this plugin for Chrome: https://chrome.google.com/webstore/detail/discussion-for-google-pla/blecahjbdenphbhmgmchammlajojlakp
Now when you go to an app in Play you will see a Discuss button.
Click that and it will bring you to the channel. If the channel does not exist it will create it.
Note: If you create the channel after you create a thread, just report the thread and let us know you want it moved into the channel.
Problem with moving sms
It really shouldn't happen, because the SMS app is just a front end, they all connect to the same message database and use the same messaging service. You have given Next SMS permission to access your contacts? Though that shouldn't stop the messages displaying, it would just stop it showing names for the sender.
Otherwise all I can think of is to force Next SMS to resynch with the message database. Textra actually has an option for that, but that's unusual, so you may have to clear data for Next SMS to force it to restart (which will unfortunately remove any customisations you've made). And I don't guarantee success, this is just the only guess I have.
Filter
