New Game: Bubbles Pop Infinite 2020 (Version 1.0.3)
What's this game ?
"Bubbles Pop Infinite 2020" is a casual game for Android. The objective is simple:
  • survive as long as you can and make your best score to get your place in the top 15.
Bubbles will appear randomly and your mission is to explode them by tapping on it.
It will be faster and faster with the time.
But you can't tap as you wish. To explode them and get points, the bubbles and
the borders must have the same color at the moment you tap them.
Borders colors also change randomly, faster and faster with time
Tapping a wrong bubble will give you penalties. Your reflexes, accuracy and calm will be needed.
Game rules ?
  • A bubble explodes if it has the same color as the borders when you tapped on it
  • Each exploded bubble gives 1 point
  • If you tapped a bubble whose color is different from the borders color:
    • 1 random ball is added
    • 1 point is removed from your score
  • If the number of bubbles reaches the max quantity, it’s a Game Over
How to download it ?
You have to way to get the game.
The first one will help the game to get a better place when people look for it.
I'm grateful if you can use the option 1:
  1. you can look for "Bubbles Pop Infinite 2020" on the Play Store
  2. you can use this link directly: https://play.google.com/store/apps/details?id=com.amandin.bubblepup
More Info ?
For more info and be aware of any new updates, you can follow:
Video promo
Screenshots
This is nice, I have something new to enjoy with
Samsung Galaxy Note 9 — ADDING NEW RINGTONE TO S6
Hello:
I'm trying to add a new sonnerie from an MP3 file. I go to Settings/Ringtone and scroll down to "add from device storage" when I click on this I get a window what shows my gmail address as well as my yahoo address. I click on this and then it goes to "My drive choose an item" then I clock and it shows, my drive, computers, shared with me, starred, and recent. No matter which I choose I can't find the file that i'm looking for, it's in my download folder. But it won't let me find it by doing what I mentioned above
Hope you all can help.
thanks
Hope you can
App Inventor How to pass the Selected Image To ImageView From ArrayList
CardView Been clicked and gallery opened, Selected an Image, I'm trying to pass the image selected from the gallery and pass to ImagePreview inside the CardView , the cardview is generated via ArrayList. I'm getting the error like delivering a result
java.lang.RuntimeException: Failure delivering result ResultInfo{who=null, request=123, result=-1, data=Intent
How to re-initialize sim card?
Yes, it is meant to go in the 2nd sim/micro-sd card hybrid slot, in order to allow you to use a second sim at the same time as a micro-sd card. I understood that when I bought it.
Dont think my phone supports dual sim, I wanted to just use it as a way to swap sims without opening the sim tray. I want to make something which allows me to easily swap between a lot of sims quickly.
No firmware mentioned on the product page.
Phone Slow
Try restarting your phone into its Safe Mode and see if this makes any improvement.
https://www.hardreset.info/devices/lg/lg-stylo-5/safe-mode/
When running in Safe Mode, only the base Android operating system gets loaded into memory during the startup process. Any third-party apps or services that typically get preloaded too are bypassed so this is a good way to at least check if something you've installed recently is causing the problem. Also keep in mind that since no apps are getting preloaded like they normally do, when you start up different apps in a Safe Mode there will often be a lag in their startup time. (...just so you can distinguish the difference between how responsive the Android OS will be vs. an app's initial loading up time.)
If you do notice there's a significant different on how your phone is running while in Safe Mode, than that would indicate there's a problem with some third-party app. You still need to determine just which one. If you look in your Settings >> Battery menu, is there any app listed there showing a recent increase in its power usage that corresponds with the approximate time when this problem started occurring?
Well, what a coincidence. As we spoke my 'older' phone (launched mid 2019) got it's OS 10 update. And other remaining models should be receiving theirs by December 2020. Now I'll just be anxiously awaiting the OS11 that launched recently. Just not for budget model phones.
Seriously, it's much better. And I do like the features of this model.
Just as a side note I don't have many apps running in background, idle apps are automatically dealt with after a certain length of time and I do a Smart Clean regularly. Thanks for allthe help and suggestions.
Copy images from gallery in app directory targetSDKVersion > 28
Hallo, sorry for my bad english.
I have problems with the value "targetSdkVersion" in the build.gradle related to copying images from the Gallery to my APP directory. The background is that I use MediaStore.INTENT_ACTION_STILL_IMAGE_CAMERA take several pictures in a row with the camera APP and then display them in a list. Unlike with MediaStore.ACTION_IMAGE_CAPTURE you can't save the pictures directly here and with the second you can only take a picture.
If set the value 28 as targetSdkVersion, I can easily copy images from the Gallery to my APP directory (after appropriate permission) and no more at 29 (otherwise no change). srcFile.exist() returns true at both values, FileTools.fileCopy(src,dest) returns true at value 28 and the file is copied. If 29 is a value, the value is returned false and the file is not copied. The app needs to be uninstalled and reinstalled once when changing values, there are no problems with the update from 28 to 29.
I think this has something to do with it, as can be seen from https://developer.android.com/distribute/best-practices/develop/target-sdk.
• Scoped storage
• External storage access is limited only to an app-specific directory and to specific types of media that the app has created.
Does anyone have an idea what alternative I have to copy the images from the DCIM directory to my app directory. Other apps do the same.
greetings Jens
Update notification
Hi Jacques, welcome to Android and welcome to Android Forums! I think you'll be pleasantly surprised by Android, and your new abilities that iOS couldn't offer you.
That said, I'm not sure about the Pixel 4a (except that the Pixel will be among the first devices to get a new Android version) update notifications, but you can always go to Settings -- About Phone -- Software Information and see the Android version you are currently on (likely 10). Going back to Settings -- Software Update -- Download and install, the phone will retrieve any new updates or security patches.
I hope this helps. It's great to have you here!
netstat connections.
Hi I'm trying to learn more about Android OS and how it utilizes connections. I'm using a Samsung Galaxy Note 9 512GB with Android 10. I'm using the app "termux" to use shell commands, not adb. When I run:
$ netstat -a
It returns:
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node Path
unix 2 [ ACC ] STREAM LISTENING 31747 /dev/socket/zygote
unix 2 [ ACC ] STREAM LISTENING 33312 @mcdaemon
unix 2 [ ACC ] STREAM LISTENING 31752 /dev/socket/usap_pool_primary
unix 2 [ ACC ] SEQPACKET LISTENING 16135 /dev/socket/lmkd
unix 2 [ ACC ] STREAM LISTENING 34219 /data/.socket_stream
unix 2 [ ] STREAM 33803 /dev/socket/sap_uim_socket1
unix 2 [ ACC ] STREAM LISTENING 37863 /data/.tcpdump_socket
unix 2 [ ACC ] STREAM LISTENING 7699 /dev/socket/traced_consumer
unix 2 [ ACC ] STREAM LISTENING 7704 /dev/socket/traced_producer
unix 2 [ ACC ] SEQPACKET LISTENING 34064 /dev/socket/tombstoned_crash
unix 2 [ ACC ] SEQPACKET LISTENING 34081 /dev/socket/tombstoned_intercept
unix 2 [ ] DGRAM 24353 /dev/socket/wpa_wlan0
unix 2 [ ACC ] STREAM LISTENING 44384 /data/system/ndebugsocket
unix 2 [ ACC ] SEQPACKET LISTENING 34084 /dev/socket/tombstoned_java_trace
unix 2 [ ACC ] STREAM LISTENING 3036 @com.android.internal.os.WebViewZygoteInit/8008e13c-f194-4023-98cf-138090c059a4
unix 2 [ ] DGRAM 34349 /dev/socket/location/xtra/socket_xtra
unix 2 [ ACC ] STREAM LISTENING 36028 @EngineeringModeServiceSocket
unix 2 [ ACC ] STREAM LISTENING 36670 /dev/socket/eris
unix 2 [ ACC ] STREAM LISTENING 30280 /dev/socket/dnsproxyd
unix 2 [ ACC ] STREAM LISTENING 39209 @Multiclient
unix 2 [ ACC ] STREAM LISTENING 30287 /dev/socket/napproxyd
unix 2 [ ACC ] STREAM LISTENING 30290 /dev/socket/domainfproxyd
unix 2 [ ACC ] STREAM LISTENING 30293 /dev/socket/mdns
unix 2 [ ACC ] STREAM LISTENING 30296 /dev/socket/fwmarkd
unix 2 [ ACC ] STREAM LISTENING 25176 /dev/socket/frigate
unix 2 [ ACC ] STREAM LISTENING 30299 /dev/socket/tcpopd
unix 2 [ ACC ] STREAM LISTENING 30302 /dev/socket/qosd
unix 2 [ ACC ] STREAM LISTENING 30305 /dev/socket/SecSoftap
unix 2 [ ACC ] STREAM LISTENING 28003 /dev/socket/vaultkeeper/vaultkeeper
unix 2 [ ] STREAM 25956 /dev/socket/pps
unix 2 [ ACC ] STREAM LISTENING 31081 /dev/socket/location/mq/location-mq-s
unix 2 [ ACC ] STREAM LISTENING 33841 @time_genoff
unix 2 [ ACC ] SEQPACKET LISTENING 32404 /dev/socket/mlaudio/audio_server
unix 2 [ ACC ] STREAM LISTENING 15508 /dev/socket/logd
unix 2 [ ACC ] SEQPACKET LISTENING 32407 /dev/socket/mlaudio/audio_client
unix 2 [ ACC ] SEQPACKET LISTENING 15513 /dev/socket/logdr
unix 238 [ ] DGRAM 15516 /dev/socket/logdw
unix 2 [ ] DGRAM 48376 /data/vendor/wifi/wpa/sockets/wlan0
unix 14 [ ] DGRAM 30369 /dev/socket/statsdw
unix 2 [ ACC ] STREAM LISTENING 36037 @PACMSERVICE
unix 2 [ ACC ] STREAM LISTENING 2845 @THERMALE_UI
unix 2 [ ] DGRAM 17840 /dev/socket/ipacm_log_file
unix 2 [ ACC ] STREAM LISTENING 25010 /dev/socket/property_service
unix 2 [ ACC ] STREAM LISTENING 129975 /dev/socket/mdnsd
unix 2 [ ACC ] STREAM LISTENING 32658 @perfmon_send
unix 2 [ ACC ] STREAM LISTENING 16325 /dev/socket/stork/stork
unix 2 [ ACC ] STREAM LISTENING 30918 /dev/socket/sdp
unix 2 [ ACC ] STREAM LISTENING 2510 /dev/socket/ss_conn_daemon2
unix 2 [ ACC ] STREAM LISTENING 24015 /dev/socket/imsd
unix 2 [ ACC ] STREAM LISTENING 37946 @VND_Multiclient
unix 2 [ ACC ] STREAM LISTENING 2520 /dev/socket/thermal-send-client
unix 2 [ ACC ] STREAM LISTENING 2525 /dev/socket/thermal-recv-client
unix 2 [ ACC ] STREAM LISTENING 2528 /dev/socket/thermal-recv-passive-client
unix 2 [ ACC ] STREAM LISTENING 2531 /dev/socket/thermal-send-rule
unix 2 [ ACC ] STREAM LISTENING 7650 /dev/socket/bsd/bsd
unix 2 [ ] DGRAM 27625 /dev/socket/location/socket_hal
unix 2 [ ACC ] STREAM LISTENING 2539 /dev/socket/zygote_secondary
unix 2 [ ACC ] STREAM LISTENING 2544 /dev/socket/usap_pool_secondary
unix 2 [ ] DGRAM 25391 @gplisnr@
unix 2 [ ACC ] SEQPACKET LISTENING 54769 /dev/socket/perfsdkserver
unix 2 [ ACC ] STREAM LISTENING 35779 @DeviceRootKeyService
unix 2 [ ] DGRAM 209621
unix 2 [ ] DGRAM 36120
unix 3 [ ] SEQPACKET CONNECTED 33702
unix 3 [ ] SEQPACKET CONNECTED 2906
unix 2 [ ] DGRAM 25182
unix 3 [ ] STREAM CONNECTED 227583
unix 2 [ ] DGRAM 216184
unix 3 [ ] SEQPACKET CONNECTED 113351
unix 2 [ ] DGRAM 112054
unix 2 [ ] DGRAM 32393
unix 2 [ ] DGRAM 36708
unix 2 [ ] DGRAM 18373
unix 2 [ ] DGRAM 216080
unix 2 [ ] DGRAM 99167
unix 2 [ ] DGRAM 59253
unix 2 [ ] DGRAM 197980
unix 3 [ ] SEQPACKET CONNECTED 84092
unix 2 [ ] DGRAM 60195
unix 2 [ ] DGRAM 52509
unix 3 [ ] SEQPACKET CONNECTED 2905
unix 2 [ ] DGRAM 222429
unix 2 [ ] DGRAM 54689
unix 2 [ ] DGRAM 50561
unix 3 [ ] SEQPACKET CONNECTED 46207
unix 2 [ ] DGRAM 33865
unix 3 [ ] STREAM CONNECTED 226458 /dev/socket/qosd
unix 3 [ ] STREAM CONNECTED 42936 /dev/socket/sdp
unix 2 [ ] DGRAM 200982
unix 2 [ ] DGRAM 137071
unix 3 [ ] STREAM CONNECTED 70037
unix 3 [ ] STREAM CONNECTED 67449
unix 3 [ ] SEQPACKET CONNECTED 227566
unix 2 [ ] DGRAM 103598
unix 3 [ ] SEQPACKET CONNECTED 95695
unix 3 [ ] STREAM CONNECTED 60737
unix 2 [ ] DGRAM 32344
unix 3 [ ] SEQPACKET CONNECTED 28109
unix 2 [ ] DGRAM 68739
unix 3 [ ] SEQPACKET CONNECTED 60046
unix 3 [ ] SEQPACKET CONNECTED 46205
unix 2 [ ] DGRAM 1791
unix 3 [ ] STREAM CONNECTED 107801
unix 3 [ ] SEQPACKET CONNECTED 227560
unix 2 [ ] DGRAM 179957
unix 2 [ ] DGRAM 102726
unix 3 [ ] SEQPACKET CONNECTED 54020
unix 3 [ ] SEQPACKET CONNECTED 46206
unix 2 [ ] DGRAM 18375
unix 3 [ ] STREAM CONNECTED 42943 /dev/socket/mdns
unix 2 [ ] DGRAM 16054
unix 2 [ ] DGRAM 17947
unix 3 [ ] SEQPACKET CONNECTED 93171
unix 3 [ ] STREAM CONNECTED 60736
unix 3 [ ] SEQPACKET CONNECTED 84090
unix 3 [ ] SEQPACKET CONNECTED 60045
unix 2 [ ] DGRAM 24515
unix 2 [ ] DGRAM 1803
unix 3 [ ] STREAM CONNECTED 107805
unix 2 [ ] DGRAM 18371
unix 3 [ ] STREAM CONNECTED 225842 /dev/socket/dnsproxyd
unix 3 [ ] STREAM CONNECTED 55179
unix 2 [ ] DGRAM 34265
unix 2 [ ] DGRAM 127042
unix 3 [ ] STREAM CONNECTED 112909
unix 2 [ ] DGRAM 17909
unix 3 [ ] SEQPACKET CONNECTED 93169
unix 3 [ ] STREAM CONNECTED 67450 @Multiclient
unix 2 [ ] DGRAM 7712
unix 2 [ ] DGRAM 148971
unix 3 [ ] SEQPACKET CONNECTED 46208
unix 2 [ ] DGRAM 33840
unix 2 [ ] DGRAM 15540
unix 3 [ ] SEQPACKET CONNECTED 60044
unix 2 [ ] DGRAM 1823
unix 3 [ ] SEQPACKET CONNECTED 93170
unix 3 [ ] SEQPACKET CONNECTED 226404
unix 3 [ ] STREAM CONNECTED 70038
unix 2 [ ] DGRAM 58817
unix 3 [ ] STREAM CONNECTED 60735
unix 2 [ ] DGRAM 36193
unix 3 [ ] SEQPACKET CONNECTED 28115
unix 2 [ ] DGRAM 18225
unix 2 [ ] DGRAM 17662
unix 3 [ ] SEQPACKET CONNECTED 227561
unix 2 [ ] DGRAM 34200
unix 2 [ ] DGRAM 32333
unix 2 [ ] DGRAM 58933
unix 3 [ ] SEQPACKET CONNECTED 69069 /dev/socket/perfsdkserver
unix 3 [ ] SEQPACKET CONNECTED 67527
unix 2 [ ] DGRAM 1826
unix 2 [ ] DGRAM 49886
unix 3 [ ] SEQPACKET CONNECTED 33699
unix 2 [ ] DGRAM 34010
unix 3 [ ] SEQPACKET CONNECTED 25019
unix 3 [ ] STREAM CONNECTED 223962
unix 2 [ ] DGRAM 180050
unix 3 [ ] STREAM CONNECTED 112910
unix 2 [ ] DGRAM 35395
unix 2 [ ] DGRAM 34198
unix 3 [ ] STREAM CONNECTED 222807 /dev/socket/dnsproxyd
unix 2 [ ] DGRAM 115839
unix 3 [ ] SEQPACKET CONNECTED 226405
unix 2 [ ] DGRAM 34213
unix 3 [ ] STREAM CONNECTED 172846
unix 2 [ ] DGRAM 59207
unix 2 [ ] DGRAM 60981
unix 2 [ ] DGRAM 27692
unix 2 [ ] DGRAM 196576
unix 2 [ ] DGRAM 198469
unix 3 [ ] SEQPACKET CONNECTED 120421
unix 3 [ ] SEQPACKET CONNECTED 25018
unix 2 [ ] DGRAM 54791
unix 3 [ ] SEQPACKET CONNECTED 46246
unix 2 [ ] DGRAM 32860
unix 3 [ ] SEQPACKET CONNECTED 60946
unix 2 [ ] DGRAM 18364
unix 2 [ ] DGRAM 226575
unix 2 [ ] DGRAM 124793
unix 2 [ ] DGRAM 96675
unix 3 [ ] STREAM CONNECTED 42935
unix 2 [ ] DGRAM 17657
unix 3 [ ] SEQPACKET CONNECTED 60947
unix 3 [ ] SEQPACKET CONNECTED 69068
unix 3 [ ] SEQPACKET CONNECTED 60043
unix 2 [ ] DGRAM 16335
unix 3 [ ] SEQPACKET CONNECTED 36311
unix 2 [ ] DGRAM 27677
unix 2 [ ] DGRAM 214960
unix 3 [ ] STREAM CONNECTED 223963 /dev/socket/dnsproxyd
unix 3 [ ] SEQPACKET CONNECTED 227565
unix 2 [ ] DGRAM 158222
unix 3 [ ] SEQPACKET CONNECTED 46247
unix 3 [ ] SEQPACKET CONNECTED 41345
unix 3 [ ] SEQPACKET CONNECTED 226402
unix 2 [ ] DGRAM 208377
unix 2 [ ] DGRAM 59989
unix 2 [ ] DGRAM 33884
unix 3 [ ] SEQPACKET CONNECTED 25021
unix 2 [ ] DGRAM 99272
unix 2 [ ] DGRAM 31217
unix 3 [ ] SEQPACKET CONNECTED 194911 /dev/socket/logdr
unix 3 [ ] SEQPACKET CONNECTED 120420
unix 3 [ ] STREAM CONNECTED 42942
unix 2 [ ] DGRAM 127020
unix 2 [ ] DGRAM 34231
unix 3 [ ] SEQPACKET CONNECTED 216827
unix 2 [ ] DGRAM 193009
unix 3 [ ] SEQPACKET CONNECTED 54021
unix 3 [ ] SEQPACKET CONNECTED 36310
unix 2 [ ] DGRAM 18345
unix 2 [ ] DGRAM 59369
unix 2 [ ] DGRAM 208216
unix 3 [ ] SEQPACKET CONNECTED 113352
unix 2 [ ] DGRAM 49694
unix 2 [ ] DGRAM 212617
unix 3 [ ] SEQPACKET CONNECTED 25020
unix 3 [ ] STREAM CONNECTED 227582 /dev/socket/dnsproxyd
unix 3 [ ] SEQPACKET CONNECTED 84091
unix 3 [ ] STREAM CONNECTED 37864
unix 2 [ ] DGRAM 16057
unix 3 [ ] SEQPACKET CONNECTED 226407
unix 3 [ ] SEQPACKET CONNECTED 113350
unix 3 [ ] SEQPACKET CONNECTED 67528
unix 2 [ ] DGRAM 51487
unix 2 [ ] DGRAM 33090
unix 2 [ ] DGRAM 28542
unix 2 [ ] DGRAM 25369
unix 3 [ ] STREAM CONNECTED 227613 /dev/socket/dnsproxyd
unix 2 [ ] DGRAM 82398
unix 2 [ ] DGRAM 47227
unix 3 [ ] SEQPACKET CONNECTED 39985
unix 3 [ ] SEQPACKET CONNECTED 40974
unix 2 [ ] DGRAM 192722
unix 2 [ ] STREAM 59929
unix 2 [ ] DGRAM 225027
unix 3 [ ] SEQPACKET CONNECTED 45626
unix 3 [ ] SEQPACKET CONNECTED 84093
unix 2 [ ] DGRAM 70678
unix 3 [ ] SEQPACKET CONNECTED 46248
unix 3 [ ] SEQPACKET CONNECTED 28108
unix 3 [ ] SEQPACKET CONNECTED 46249
unix 2 [ ] DGRAM 3038
unix 3 [ ] STREAM CONNECTED 33093
unix 2 [ ] DGRAM 16330
unix 2 [ ] DGRAM 7518
unix 3 [ ] STREAM CONNECTED 227584 /dev/socket/dnsproxyd
unix 2 [ ] DGRAM 192881
unix 3 [ ] SEQPACKET CONNECTED 39986
unix 3 [ ] SEQPACKET CONNECTED 40973
unix 3 [ ] STREAM CONNECTED 37861
unix 3 [ ] STREAM CONNECTED 73925
unix 3 [ ] STREAM CONNECTED 215240
unix 2 [ ] DGRAM 197919
unix 3 [ ] SEQPACKET CONNECTED 45625
unix 3 [ ] SEQPACKET CONNECTED 28114
unix 2 [ ] DGRAM 216168
unix 2 [ ] DGRAM 138820
unix 3 [ ] SEQPACKET CONNECTED 57990
unix 3 [ ] STREAM CONNECTED 31212
unix 2 [ ] DGRAM 202955
unix 2 [ ] DGRAM 34409
unix 3 [ ] SEQPACKET CONNECTED 216826
unix 3 [ ] SEQPACKET CONNECTED 227562
unix 2 [ ] DGRAM 226335
unix 2 [ ] DGRAM 156848
unix 3 [ ] SEQPACKET CONNECTED 40976
unix 2 [ ] DGRAM 34425
unix 3 [ ] SEQPACKET CONNECTED 49810
unix 2 [ ] DGRAM 56745
unix 3 [ ] STREAM CONNECTED 33094
unix 3 [ ] SEQPACKET CONNECTED 57991
unix 3 [ ] STREAM CONNECTED 31214 /dev/socket/location/mq/location-mq-s
unix 3 [ ] SEQPACKET CONNECTED 67752
unix 2 [ ] DGRAM 16326
unix 2 [ ] DGRAM 117996
unix 3 [ ] SEQPACKET CONNECTED 95693
unix 3 [ ] SEQPACKET CONNECTED 95692
unix 2 [ ] DGRAM 34429
unix 2 [ ] DGRAM 131885
unix 2 [ ] DGRAM 94187
unix 3 [ ] STREAM CONNECTED 49488 /dev/socket/eris
unix 2 [ ] DGRAM 228416
unix 3 [ ] SEQPACKET CONNECTED 227571
unix 2 [ ] DGRAM 82074
unix 3 [ ] SEQPACKET CONNECTED 40975
unix 2 [ ] DGRAM 111460
unix 3 [ ] SEQPACKET CONNECTED 56768
unix 2 [ ] DGRAM 46390
unix 2 [ ] DGRAM 33187
unix 2 [ ] DGRAM 15692
unix 3 [ ] SEQPACKET CONNECTED 194910
unix 3 [ ] STREAM CONNECTED 107800
unix 2 [ ] DGRAM 31213
unix 2 [ ] DGRAM 25384
unix 2 [ ] DGRAM 183150
unix 2 [ ] DGRAM 123554
unix 3 [ ] SEQPACKET CONNECTED 33703
unix 2 [ ] DGRAM 194127
unix 2 [ ] DGRAM 104213
unix 3 [ ] SEQPACKET CONNECTED 67753
unix 2 [ ] DGRAM 28007
unix 2 [ ] DGRAM 86105
unix 2 [ ] DGRAM 44670
unix 2 [ ] DGRAM 192063
unix 2 [ ] DGRAM 119093
unix 2 [ ] DGRAM 44648
unix 3 [ ] STREAM CONNECTED 211964
unix 3 [ ] SEQPACKET CONNECTED 84089
unix 2 [ ] DGRAM 24462
unix 2 [ ] DGRAM 33026
unix 2 [ ] DGRAM 27706
unix 2 [ ] DGRAM 108480
unix 3 [ ] STREAM CONNECTED 214621
unix 3 [ ] SEQPACKET CONNECTED 78530
unix 2 [ ] DGRAM 49979
unix 2 [ ] DGRAM 39773
unix 2 [ ] DGRAM 33793
unix 3 [ ] STREAM CONNECTED 172847
unix 3 [ ] STREAM CONNECTED 60734
unix 2 [ ] DGRAM 25489
unix 3 [ ] STREAM CONNECTED 223914
unix 3 [ ] STREAM CONNECTED 227581
unix 3 [ ] SEQPACKET CONNECTED 39981
unix 2 [ ] DGRAM 15667
unix 3 [ ] STREAM CONNECTED 73926
unix 2 [ ] DGRAM 61067
unix 2 [ ] DGRAM 18416
unix 3 [ ] SEQPACKET CONNECTED 227559
unix 2 [ ] DGRAM 58066
unix 2 [ ] DGRAM 32231
unix 3 [ ] STREAM CONNECTED 107806
unix 2 [ ] DGRAM 69863
unix 2 [ ] DGRAM 60049
unix 3 [ ] STREAM CONNECTED 24498
unix 2 [ ] DGRAM 50135
unix 3 [ ] SEQPACKET CONNECTED 33698
unix 2 [ ] DGRAM 15646
unix 3 [ ] STREAM CONNECTED 222806
unix 2 [ ] DGRAM 7651
unix 3 [ ] SEQPACKET CONNECTED 227570
unix 3 [ ] SEQPACKET CONNECTED 113349
unix 3 [ ] SEQPACKET CONNECTED 39982
unix 3 [ ] STREAM CONNECTED 39306 /data/.socket_stream
unix 3 [ ] SEQPACKET CONNECTED 49203
unix 3 [ ] STREAM CONNECTED 41363 /data/.socket_stream
unix 2 [ ] DGRAM 31083
unix 2 [ ] DGRAM 7514
unix 2 [ ] DGRAM 195272
unix 2 [ ] DGRAM 36510
unix 3 [ ] SEQPACKET CONNECTED 226403
unix 2 [ ] DGRAM 72864
unix 2 [ ] DGRAM 34348
unix 3 [ ] STREAM CONNECTED 211965
unix 3 [ ] STREAM CONNECTED 215241
unix 2 [ ] DGRAM 195970
unix 2 [ ] DGRAM 218128
unix 3 [ ] STREAM CONNECTED 227612
unix 3 [ ] STREAM CONNECTED 223915 /dev/socket/dnsproxyd
unix 2 [ ] DGRAM 216130
unix 3 [ ] SEQPACKET CONNECTED 41346
unix 3 [ ] SEQPACKET CONNECTED 39983
unix 2 [ ] DGRAM 27759
unix 2 [ ] DGRAM 93016
unix 3 [ ] SEQPACKET CONNECTED 49204
unix 2 [ ] DGRAM 46323
unix 3 [ ] SEQPACKET CONNECTED 33700
unix 3 [ ] STREAM CONNECTED 37865 @Multiclient
unix 2 [ ] DGRAM 31084
unix 3 [ ] STREAM CONNECTED 35769 /data/.socket_stream
unix 2 [ ] DGRAM 214188
unix 2 [ ] DGRAM 47338
unix 3 [ ] SEQPACKET CONNECTED 24505
unix 2 [ ] DGRAM 32901
unix 2 [ ] DGRAM 198396
unix 2 [ ] DGRAM 95750
unix 3 [ ] SEQPACKET CONNECTED 84094
unix 2 [ ] DGRAM 27731
unix 3 [ ] STREAM CONNECTED 225841
unix 3 [ ] SEQPACKET CONNECTED 226406
unix 2 [ ] DGRAM 158247
unix 2 [ ] DGRAM 95638
unix 3 [ ] SEQPACKET CONNECTED 39984
unix 3 [ ] STREAM CONNECTED 35781
unix 2 [ ] DGRAM 88050
unix 3 [ ] SEQPACKET CONNECTED 49809
unix 3 [ ] SEQPACKET CONNECTED 24506
unix 2 [ ] DGRAM 46346
unix 3 [ ] SEQPACKET CONNECTED 33701
unix 2 [ ] DGRAM 32998
unix 2 [ ] DGRAM 77794
unix 2 [ ] DGRAM 23750
unix 2 [ ] DGRAM 2299
unix 2 [ ] DGRAM 193032
unix 3 [ ] STREAM CONNECTED 78734
unix 3 [ ] SEQPACKET CONNECTED 83012
unix 3 [ ] STREAM CONNECTED 36065 /dev/socket/location/mq/location-mq-s
unix 2 [ ] DGRAM 27319
unix 2 [ ] DGRAM 25856
unix 3 [ ] SEQPACKET CONNECTED 45229
unix 3 [ ] SEQPACKET CONNECTED 32649 /dev/socket/lmkd
unix 2 [ ] DGRAM 27480
unix 2 [ ] DGRAM 26086
unix 2 [ ] DGRAM 185029
unix 3 [ ] SEQPACKET CONNECTED 78733
unix 2 [ ] DGRAM 39207
unix 2 [ ] DGRAM 2260
unix 2 [ ] DGRAM 43666
unix 3 [ ] STREAM CONNECTED 39259 /dev/socket/zygote
unix 3 [ ] STREAM CONNECTED 182584
unix 2 [ ] DGRAM 2159
unix 2 [ ] DGRAM 27440
unix 2 [ ] DGRAM 25894
unix 2 [ ] DGRAM 2305
unix 2 [ ] DGRAM 48575
unix 2 [ ] DGRAM 226784
unix 2 [ ] DGRAM 31786
unix 2 [ ] DGRAM 27285
unix 2 [ ] DGRAM 35049
unix 2 [ ] DGRAM 94869
unix 3 [ ] STREAM CONNECTED 8112
unix 3 [ ] STREAM CONNECTED 78735
unix 3 [ ] SEQPACKET CONNECTED 83013
unix 2 [ ] DGRAM 2302
unix 2 [ ] DGRAM 23677
unix 3 [ ] STREAM CONNECTED 78737
unix 3 [ ] STREAM CONNECTED 43799
unix 2 [ ] DGRAM 23634
unix 2 [ ] DGRAM 27364
unix 3 [ ] SEQPACKET CONNECTED 45197
unix 2 [ ] DGRAM 117824
unix 2 [ ] DGRAM 27526
unix 2 [ ] DGRAM 25804
unix 3 [ ] SEQPACKET CONNECTED 45228
unix 3 [ ] SEQPACKET CONNECTED 45198
unix 3 [ ] SEQPACKET CONNECTED 39700
unix 3 [ ] SEQPACKET CONNECTED 39941
unix 2 [ ] DGRAM 23909
unix 3 [ ] STREAM CONNECTED 43800
unix 3 [ ] SEQPACKET CONNECTED 78746
unix 3 [ ] STREAM CONNECTED 8100
unix 3 [ ] STREAM CONNECTED 7713
unix 2 [ ] DGRAM 214315
unix 2 [ ] DGRAM 27402
unix 2 [ ] DGRAM 25821
unix 3 [ ] SEQPACKET CONNECTED 78747
unix 3 [ ] STREAM CONNECTED 37881
unix 3 [ ] STREAM CONNECTED 43843
unix 3 [ ] STREAM CONNECTED 28227 /dev/socket/traced_producer
unix 2 [ ] DGRAM 213780
unix 3 [ ] SEQPACKET CONNECTED 78732
unix 2 [ ] DGRAM 27509
unix 2 [ ] DGRAM 112196
unix 3 [ ] SEQPACKET CONNECTED 39940
unix 3 [ ] SEQPACKET CONNECTED 35179
unix 3 [ ] SEQPACKET CONNECTED 105139
unix 3 [ ] STREAM CONNECTED 36124 @com.android.internal.os.WebViewZygoteInit/8008e13c-f194-4023-98cf-138090c059a4
unix 2 [ ] DGRAM 27624
unix 2 [ ] DGRAM 25759
unix 2 [ ] DGRAM 214560
unix 3 [ ] STREAM CONNECTED 107303
unix 2 [ ] DGRAM 26447
unix 2 [ ] DGRAM 27449
unix 2 [ ] DGRAM 35089
unix 3 [ ] STREAM CONNECTED 107302
unix 3 [ ] STREAM CONNECTED 78744
unix 3 [ ] SEQPACKET CONNECTED 39701
unix 3 [ ] STREAM CONNECTED 37882 /dev/socket/zygote_secondary
unix 2 [ ] DGRAM 23810
unix 2 [ ] DGRAM 193016
unix 2 [ ] DGRAM 26272
unix 2 [ ] DGRAM 185001
unix 3 [ ] SEQPACKET CONNECTED 78749
unix 3 [ ] SEQPACKET CONNECTED 95694
unix 2 [ ] DGRAM 7904
unix 3 [ ] SEQPACKET CONNECTED 48515
unix 2 [ ] DGRAM 45533
unix 2 [ ] DGRAM 26022
unix 3 [ ] SEQPACKET CONNECTED 45549
unix 2 [ ] DGRAM 2658
unix 2 [ ] DGRAM 213828
unix 2 [ ] DGRAM 7813
unix 2 [ ] DGRAM 30099
unix 3 [ ] SEQPACKET CONNECTED 226753
unix 2 [ ] DGRAM 30483
unix 3 [ ] SEQPACKET CONNECTED 45543
unix 3 [ ] SEQPACKET CONNECTED 93168
unix 3 [ ] STREAM CONNECTED 78743
unix 3 [ ] SEQPACKET CONNECTED 39703
unix 3 [ ] SEQPACKET CONNECTED 78748
unix 2 [ ] DGRAM 26127
unix 2 [ ] DGRAM 220521
unix 3 [ ] SEQPACKET CONNECTED 39702
unix 3 [ ] STREAM CONNECTED 78738
unix 2 [ ] DGRAM 95438
unix 3 [ ] SEQPACKET CONNECTED 45548
unix 3 [ ] SEQPACKET CONNECTED 48516
unix 3 [ ] SEQPACKET CONNECTED 56767
unix 3 [ ] STREAM CONNECTED 182583
unix 2 [ ] DGRAM 7925
unix 2 [ ] DGRAM 94570
unix 2 [ ] DGRAM 35130
unix 2 [ ] DGRAM 25933
unix 2 [ ] DGRAM 182940
unix 2 [ ] DGRAM 112372
unix 3 [ ] STREAM CONNECTED 39328 /dev/socket/domainfproxyd
unix 3 [ ] SEQPACKET CONNECTED 105140
unix 2 [ ] DGRAM 29763
unix 3 [ ] SEQPACKET CONNECTED 78531
unix 2 [ ] DGRAM 24198
unix 2 [ ] DGRAM 26135
unix 2 [ ] DGRAM 48301
unix 2 [ ] DGRAM 137871
unix 2 [ ] DGRAM 226778
unix 2 [ ] DGRAM 30526
unix 2 [ ] DGRAM 26060
unix 3 [ ] STREAM CONNECTED 8127
unix 2 [ ] DGRAM 24132
unix 2 [ ] DGRAM 48410
unix 3 [ ] SEQPACKET CONNECTED 226754
unix 2 [ ] DGRAM 137192
unix 3 [ ] SEQPACKET CONNECTED 32676
unix 2 [ ] DGRAM 48411
unix 3 [ ] SEQPACKET CONNECTED 32677
unix 2 [ ] DGRAM 7767
unix 3 [ ] SEQPACKET CONNECTED 45544
unix 2 [ ] DGRAM 43615
unix 2 [ ] DGRAM 30076
Which compared to my Linux PC there are A LOT more connections then I am used to seeing. Is this a normal or typical netstat return for Android OS? What are the typical ports used by the Android system? Are the "proxy" connections normal? (ex. /dev/socket/dnsproxyd ) I'm familiar with using proxies on PC but I wasn't aware I was using any on this phone. Any insight would be greatly . Thanks in advance.
Shared storage locking apps on SD card or internal depending on present location
When your device is configured to use the SD card as extended internal storage, it becomes encrypted and can only be used on that device.
When configured as media storage, any device can read it.
You can try copying insternal storage files wirelessly to your PC using a PS file manager that supports it. Or you could backup your files to the cloud.
After backing up, format the SD card as FAT32 on your PC, put it back in your device, and use it as media storage so your won't have to go through this wonderful experience again.
Filter
