Help! What is this notification icon ??
Hi hadron...
Thanks very much mate..your respond have soothe my worries....nevertheless ...still hoping that maybe one of the member here are using the said apps and can adv what kind of apps the icon belongs to..once again thanks mate..
these questions almost always never get fully answered. as @Hadron said there are millions upon millions of apps each with their own notification icon.....so finding what app an icon is is like looking for a single drop of water in a vast ocean.
if it really is worrying you, then just ask your partner. there is no harm in knowing what app that it is for. being suspicious or jealous is not very healthy and can doom the relationship.
i wish you luck, but do not hold your breath that someone will know exactly what the app is.
Gradle problem:Using an .AAR in both Release and Debug
I have a app comprising some unit tests, which test functions packaged in an AAR file, which itself contains unmanaged (C++) binaries. This file is created through another build process that dumps it in it's Release or Debug forms in a directory of the form build/Android.${Configuration} .
I have figured out how to bring this file into my project as a module by adding the AAR through the 'Project Structure' dialog, which is pretty standard. However, I must point it at either the Release or Debug AAR.
For my needs up to now, that has been fine: Debug all the way. Now I need to support Release bits also. [FWIW the need is driven by a request to put it into a build/test harness that runs in an Azure pipeline and wants Release]. The user would have access to either build type when running/debugging locally, but the server builds would default to Release.
What is the gradle "school solution" to this?
There must be one.
editing files on a nas and then saving back to nas
So depending on where the source file it located, use a file manager app to move it to her mobile device's internal storage. That original file is the primary one that all edits or copies should work off of.
And keep in mind, if that file is stored only on her device, she will risk losing it if something should happen to it (it get stolen. or lost, or it just fails in some way). Set up an automatic backup solution so there's always a backup. Seriously, backups are important.
What is com.samsung.android.fmm in my activity?
It sounds like that package is Samsung's Find My Mobile:
https://www.samsung.com/uk/support/...an-i-use-it-to-locate-lock-or-wipe-my-device/
You can generally Google those package names to find out what they are. That doesn't work for everything, but it should at least get you close.
And, like @Hadron says, anything which starts out com.samsung.* will be a Samsung package.
Thank you, I was messing with my find my mobile yesterday so that's what it was probably
I'm not tech savvy. Spyware,malware??
Are you thinking of the apps that load up from the carrier branded phones? I didn't compare mine to the OP's pictures, but I have an S10+ bought and shipped directly from Samsung and it didn't come loaded to the gills at all. It was refreshing to see compared to what Verizon put into my Note II...
Carriers add more crap, but my Samsung tablet and my daughter's S8 still both came with a hell of a lot more stuff than say my Pixel did. In fact the S8 allocates more space to the /system partition than the Pixel does despite the S8 having a single system partition and the Pixel having 2. Of course some of it is to support loads of system "features", rather than stuff that appears in the app drawer, but I've yet to see a Samsung that I'd consider "lean". And to be clear, nobody in my family ever buys carrier-branded devices.
Though to be fair, they have improved: my tablet's original ROM had a number of commercial apps (stuff like Evernote) not only pre-installed but set so you couldn't even disable them (so they'd still use space with updates - or else clutter your app update list permanently - and sometimes run in the background even if you never used them). Thankfully a lot - though not all - of that was removed by later system updates. Of course whether that was because Samsung realised this was hostile to customers or because the companies decided it wasn't worth paying Samsung to do this I don't know ;).
Reviews THE ULTRA CAMERA FIX AND MORE
Hmm .. It's really weird that such high end devices have such problems. I really don't understand why to overpay for the brand, when the functionality in more budget smartphones is not worse at all. For example, I use a Xiaomi smartphone with a 48 megapixel camera. I agree that the standard application that comes with a smartphone is a complete slag, but thanks to third-party applications like Google cameras, this problem can be easily solved. For example, recently on the site https://lensespro.org I found an article on how to properly photograph at night. I tried this method on my camera and the result amazed me very much. I decided to try a similar method on my smartphone and google camera allowed me to do it. As unreal as it may sound, the night sky can be perfectly photographed and it will look really cool.
I wanna find a launcher app that can put all icons(apps and shortcuts*) into nested folders
@huhiha
"Sorry I don't fully understand what you say. Do you mean Apex Launcher slows down your phone?
And what do you mean by 200MB RAM?"
Yes.
Apex was putting an undoable strain on the limited resources of my low end devices.
The launcher itself was using about 30MB of RAM, which is fairly typical for launchers that I have tested, but the crappy Google analytics in it was using 200MB.
This being a launcher, it was always a running app.
This constant 200+MB was such a strain on a 1GB RAM device that the device was constantly crashing and restarting.
Now that Apex is gone, the problem has stopped.
I now use a fast, simple launcher called KISS that has no analyitics at all.
Help Recommend a program that makes reminders more visible and fixed
How old is your phone's software? There used to be an app called Calendar Snooze which did this perfectly, but it's no longer supported and doesn't work with modern Android versions (9 or 10 certainly, not sure about 8).
"Calendar Notify" does something similar, but I had trouble with that too (can't remember details, might have been that it interfered with forwarding notifications to my fitness tracker - in any event I removed that a year ago).
Those are the only 2 I can think of. All I can suggest is trying and seeing whether they work for you, but since neither is being updated now don't be surprised if it's not a long-term solution. Maybe someone else will pick up this baton...?
simultaneous Bluetooth connections?
Hiệu quả phương pháp đánh lô miền Nam chuẩn từng con số
Để người chơi có thể có được cách tính đánh lô tô số đề miền Nam thứ tư hàng tuần để người chơi có thể mang về cho mình nhiều cách chơi hiệu quả nhất
Bí quyết cách đánh lô đề miền Nam hiệu quả nhất hiện nay
Với cách chơi
xsmb t4 ◀◀◀ QUAN TRỌNG lô đề miền Nam khác với xsmb hằng ngày miền Nam có 3 đến 4 đài quay thưởng khác nhau nên việc theo dõi soi cầu cũng trở nên khó khăn hơn và người chơi để từ đó có thể giúp người chơi bắt được những con số chính xác nhất cho riêng mình và từ đó có thể chịu khó nghiên cứu và cần cải thiện khả năng theo dõi các dữ liệu và người chơi có thể thấy thú vị không kém và chính xác nhất.
Cách đánh đề miền Nam hiệu quả
Một số phương pháp phổ biến sau đây để có được cách đánh lô đề miền Nam hiệu quả
Vậy nên người chơi có thể đánh con số trên 50 thì được gọi là đánh tai và còn nếu dưới 50 thì được gọi là xỉu vậy nên những tỷ lệ thường thấy của người chơi có được một cách chơi
Còn việc đánh xỉu chủ ở miền nam thì cách này rất giống voeis cách chơi 3 càng ở miền Bắc và bạch thủ đánh con lô tô có 3 số đề để người chơi có thể dò thưởng hiệu quả
Hoặc người chơi
Xo so mien Bac thu 4 ◀◀◀ THAM KHẢO có được cách bao lô 3 đài và người chơi sẽ chọn được một con lô số đề nào ưng ý và người chơi chơi sẽ được đối chiếu trong 3 đài quay thưởng trong ngày hôm đó để có được cách chơi trúng khớp nhất hiện nay
Vậy nên cách đánh đề miền Nam được nhiều người yêu thích nhất và quen thuộc nhất giúp cho người chơi có được cách chơi hiệu quả nhất hiện nay.
Làm sao để soi cầu hiệu quả
Làm sao để soi cầu lô đề chuẩn bài hiệu quả
Để giúp người chơi mang về cho những cách chơi theo dõi sát sao kết quả về từng ngày và từ đó có thể sử dụng với những thống kê xổ số uy tín và có thể tiết kiệm thời gian và hiệu quả nhất giúp người chơi có thể mang về những con số ăn cầu thông hiệu quả nhất
Người chơi sẽ cần chọn ra một số đầu mà người chơi quan tâm nhất và đưa ra những vị trí trong bảng kết quả xổ số đã và cần phải đối chiếu cầu kèo sao cho hiệu quả nhất trong thời điểm.
Qua bài viết này người chơi
Xổ số miền Bắc thứ 4 hôm nay ◀◀◀ CLICK XEM biết thêm một số phương pháp bắt cầu và soi cầu xsmn thứ 4 hàng tuần hiệu quả nhất và từ đó đưa ra cho mình một số phương pháp cụ thể và hiệu quả nhất hiện nay. Chúc các bạn may mắn
Need Custom Recovery For lava A97
not every phone is rootable. unfortunately your phone is one of them.
for anything root related always head on over to xda. this is the closet thing that has some tid bits of info about rooting your phone. it really does not lead to anything, but there a few posts that can put you in the right direction. but you will need to know how to use adb, fastboot, and some coding to go further.
here is the thread:
https://forum.xda-developers.com/android/help/hot-to-root-lava-a97-t3584124
but really why do you want to root? there is no development for your phone. there is no custom recovery which is the one selling point in order for me to root a phone. a custom recovery can make backups of your phone called nandroid backups. these backups are essential especially if you plan on deleting things off your phone. if you delete the wrong thing, your phone can become a paperweight. but if you have a custom recovery and made a nandroid backup, you can just restore back and all is good.
so no development means that a developer has not made a custom recovery or even custom roms. and just remember no devs=no fun.
next time pick a phone that has a good development community before buying it, if you plan on rooting the phone.
Filter
