Root [5.1.1]XenonHD For LG Leon C50/H345 on T-Mobile and Walmart Family Mobile
- Smartphones
- 458 Replies
Damn, just found my old Tmobile Leon (C50 model I guess), sucks the links are dead. If anyone has a mirror that would be awesome though!
huh?????From your confidence, I see that you got a lot of useful experience that has helped you to get a lot of positive results
Hi
I am creating an Activity(Client)/Service App. The Service is local and bound to the Activity. What I would like to do is send messages from the Service to the Activity. I've looked at the Messenger class and it looks promising, except the only examples I've found have the handler in the Service, where I would like the Handler in the Activity (Client) and am not sure how to reverse the examples I've found. The Client does not need to send messages to the Service. If need be, the Client will make method calls on the Service using the IBinder.
One example I've looked through is there;
https://developer.android.com/guide/components/bound-services
There are many others that do the same thing.
The plan is the Service will open comms with other processes and funnel up messages back to the Client.
Both Client and Service will be a long running process.
Any advice would be appreciated.
Edit:
I have an example of what I'd like to do
The activity example:
Java:// Activity public static class Binding extends Activity { class IncomingHandler extends Handler /// Handle messages from Service { @Override public void handleMessage(Message msg) { switch (msg.what) { case MessengerService.MSG_SET_VALUE: mCallbackText.setText("Received from service: " + msg.arg1); /// MessengerService should be LocalService break; default: super.handleMessage(msg); } } } final Messenger mMessenger = new Messenger(new IncomingHandler()); private LocalService mBoundService; /// For Local Service private ServiceConnection mConnection = new ServiceConnection() { public void onServiceConnected(ComponentName className, IBinder service) { mBoundService = ((LocalService.LocalBinder)service).getService(); /// For Local Service mService = new Messenger(service); } } void doBindService() { bindService(new Intent(Binding.this, MessengerService.class), mConnection, Context.BIND_AUTO_CREATE); /// MessengerService should be LocalService bindService(new Intent(Binding.this, LocalService.class), mConnection, Context.BIND_AUTO_CREATE)); /// For Local Service mIsBound = true; mCallbackText.setText("Binding."); } }
Example of the Service:
Java:// Service public class LocalService extends Service { NotificationManager mNM; final Messenger mMessenger = new Messenger(new IncomingHandler()); /// The Local Binder public class LocalBinder extends Binder { LocalService getService() { return LocalService.this; /// Does this include both the ability to make local methods call and the messenger? } } class IncomingHandler extends Handler { @Override public void handleMessage(Message msg) { } } private final IBinder mBinder = new LocalBinder(); /// For Local comm with client (method calls) /// For the Messenger version @Override public IBinder onBind(Intent intent) { return mMessenger.getBinder(); } /// For the Local method call version @Override public IBinder onBind(Intent intent) { return mBinder; /// Does this include the messenger capability? } }
So as you can see, I'm trying to do two things with my Service, make local method calls on it from the Activity through the IBinder and also have the Service send messages back to the Activity through a Messenger. I have to believe that this is possible, I would like to know if I'm on the right track?
Thanks...
It depends, but sometimes, they will be deleted as well.Do images and other data remain in internal storage when you click clear storage in files by google, 1.0.385.. ?
I'm pretty sure it's not stolen. It was just lying around with some other old phones. I guess I'll just have to check with the person about email and password.
try a factory reset and then update the phone.
