A newspaper novel.
Some are saying this thing needs a complete overhaul, while others say it just needs a tune up.
sorry but this is an english only site.Fui atualizar pelo apply update from external storage com o arquivo Acer_AVL0_A1-860_RV00RC02_WW_GEN1.ZIP ao executar aparece a mensagem
E:footer is wrong
E:signatura verification failed --Install Fail
O que devo fazer
I was updated by apply update from external storage with the file Acer_AVL0_A1-860_RV00RC02_WW_GEN1.ZIP when running the message appears E: footer is wrong E: signatura verification failed --Install Fail What should I do
between the two, you will need to decide if you want a stylus or not. no stylus, get the s20+. if you want the stylus, get the note 10+.I'm eligible for an upgrade on att and considering the S20+ and Note 10+. Which should I go with? Or should I consider something else? Thoughts?
of course it is....LOL!!!!!Is Sammobile still a thing?
i already alerted the mods....but just an fyi, we have a development forumIn some cases, the error happens while I build my Android project.
The error message likes “The Android Gradle plugin supports only Kotlin Gradle plugin version 1.2.51 and higher. Project ‘AnkitSuda#Faysr’ is using version 1.2.41.”
So, I want to know is there any summary about the version of Android Gradle plugin supports the corresponding version of Kotlin plugin?
Flashing is not working for me. This is what I got.
D:\fastboot final>fastboot flash gpt gpt.bin
(bootloader) has-slot:gpt: not found
(bootloader) is-logical:gpt: not found
Sending 'gpt' (45 KB) OKAY [ 0.172s]
Writing 'gpt' (bootloader) Validating 'gpt.
default.xml'
(bootloader) Security version downgrade
(bootloader) Image primary_gpt failed validation
(bootloader) Preflash validation failed
(bootloader) Cancelling 'gpt.default.xml'
FAILED (remote: '')
fastboot: error: Command failed
D:\fastboot final>fastboot flash bootloader bootloader.img
(bootloader) has-slot:bootloader: not found
(bootloader) is-logical:bootloader: not found
Sending 'bootloader' (5179 KB) OKAY [ 0.334s]
Writing 'bootloader' (bootloader) Validating 'boot
loader.default.xml'
(bootloader) Committing 'bootloader.default.xml'
(bootloader) - flashing 'emmc_appsboot.mbn' to 'aboot'
(bootloader) - flashing 'rpm.mbn' to 'rpm'
(bootloader) - flashing 'tz.mbn' to 'tz'
(bootloader) - flashing 'devcfg.mbn' to 'devcfg'
(bootloader) - flashing 'cmnlib.mbn' to 'cmnlib'
(bootloader) - flashing 'cmnlib64.mbn' to 'cmnlib64'
(bootloader) - flashing 'keymaster.mbn' to 'keymaster'
(bootloader) - flashing 'prov.mbn' to 'prov'
(bootloader) - flashing 'sbl1.mbn' to 'sbl1'
OKAY [ 0.544s]
Finished. Total time: 1.243s
D:\fastboot final>fastboot flash modem NON-HLOS.bin
(bootloader) has-slot:modem: not found
(bootloader) is-logical:modem: not found
Sending 'modem' (73891 KB) OKAY [ 2.496s]
Writing 'modem' OKAY [ 0.659s]
Finished. Total time: 3.370s
D:\fastboot final>fastboot flash fsg fsg.mbn
(bootloader) has-slot:fsg: not found
(bootloader) is-logical:fsg: not found
Sending 'fsg' (1120 KB) OKAY [ 0.194s]
Writing 'fsg' OKAY [ 0.066s]
Finished. Total time: 0.507s
D:\fastboot final>fastboot erase modemst1
(bootloader) has-slot:modemst1: not found
Erasing 'modemst1' OKAY [ 0.024s]
Finished. Total time: 0.241s
D:\fastboot final>fastboot erase modemst2
(bootloader) has-slot:modemst2: not found
Erasing 'modemst2' OKAY [ 0.024s]
Finished. Total time: 0.237s
D:\fastboot final>fastboot flash dsp adspso.bin
(bootloader) has-slot:dsp: not found
(bootloader) is-logical:dsp: not found
Sending 'dsp' (16384 KB) OKAY [ 0.693s]
Writing 'dsp' OKAY [ 0.177s]
Finished. Total time: 1.111s
D:\fastboot final>fastboot flash logo logo.bin
(bootloader) has-slot:logo: not found
(bootloader) is-logical:logo: not found
Sending 'logo' (1386 KB) OKAY [ 0.208s]
Writing 'logo' OKAY [ 0.068s]
Finished. Total time: 0.518s
D:\fastboot final>fastboot flash boot boot.img
(bootloader) has-slot:boot: not found
(bootloader) is-logical:boot: not found
Sending 'boot' (16384 KB) OKAY [ 0.691s]
Writing 'boot' (bootloader) Image signed wit
h key bad key
OKAY [ 0.304s]
Finished. Total time: 1.241s
D:\fastboot final>fastboot flash recovery recovery.img
(bootloader) has-slot:recovery: not found
(bootloader) is-logical:recovery: not found
Sending 'recovery' (16484 KB) OKAY [ 0.699s]
Writing 'recovery' (bootloader) Image signed wit
h key bad key
OKAY [ 0.337s]
Finished. Total time: 1.278s
D:\fastboot final>fastboot flash system system.img_sparsechunk.0
(bootloader) has-slot:system: not found
(bootloader) is-logical:system: not found
Sending 'system' (511914 KB) OKAY [ 16.812s]
Writing 'system' OKAY [ 4.104s]
Finished. Total time: 21.150s
D:\fastboot final>fastboot flash system system.img_sparsechunk.1
Sending 'system' (508182 KB) OKAY [ 16.703s]
Writing 'system' OKAY [ 4.106s]
Finished. Total time: 21.040s
D:\fastboot final>fastboot flash system system.img_sparsechunk.2
Sending 'system' (510802 KB) OKAY [ 16.690s]
Writing 'system' OKAY [ 3.890s]
Finished. Total time: 20.809s
D:\fastboot final>fastboot flash system system.img_sparsechunk.3
Sending 'system' (512872 KB) OKAY [ 16.845s]
Writing 'system' OKAY [ 3.778s]
Finished. Total time: 20.855s
D:\fastboot final>fastboot flash system system.img_sparsechunk.4
Sending 'system' (524286 KB) OKAY [ 17.114s]
Writing 'system' OKAY [ 4.189s]
Finished. Total time: 21.527s
Sending 'system' (524286 KB) OKAY [ 17.012s]
Writing 'system' (bootloader) Failed to valida
te sparse image
FAILED (remote: '')
D:\fastboot final>fastboot flash oem oem.img_sparsechunk.0
(bootloader) has-slotem: not found
fastboot: error: cannot load 'oem.img_sparsechunk.0': No such file or directory
D:\fastboot final>fastboot flash oem oem.img_sparsechunk.1
fastboot: error: cannot load 'oem.img_sparsechunk.1': No such file or directory
D:\fastboot final>fastboot erase cache
(bootloader) has-slot:cache: not found
Erasing 'cache' OKAY [ 0.016s]
Finished. Total time: 0.322s
D:\fastboot final>fastboot erase userdata
(bootloader) has-slot:userdata: not found
Erasing 'userdata' OKAY [ 0.088s]
Finished. Total time: 0.294s
D:\fastboot final>fastboot erase ddr
(bootloader) has-slot:ddr: not found
Erasing 'ddr' (bootloader) Permission denie
d
FAILED (remote: '')
D:\fastboot final>fastboot oem fb_mode_clear
OKAY [ 0.118s]
Finished. Total time: 0.127s
D:\fastboot final>fastboot reboot
Rebooting OKAY [ 0.005s]
Finished. Total time: 0.009s
just googled "hard reset on vivo y19" and found this:Yes, I have google account info. Please guide me on how to factory reset the phone?
If you're not willing to sort this problem out with your carrier, you don't have a lot of options in this matter.My device is not in blacklist please help me
