Bar under Home button
What do you mean by "app menu"? Do you mean the "app drawer" (scrolling list or pages of app icons for all installed apps), or a shortcut to settings? And have you had any system updates recently?
I ask because swiping up from the bottom of the screen to access the app drawer has been an option for Android navigation for a couple of years now, so it's possible it's something you've activated accidentally or where the default has been changed by an update. I've never heard of a vertical line, but that may be a Samsung thing. So I'd check your launcher's settings (anything "gesture" or "navigation" related), and also look at the system settings for gestures (these are under "Settings > System" on more stock devices, but Samsung change the Settings layout so I can't be fore where they'll be on your phone).
Root [Recovery] [Unofficial] Twrp Recovery Maze Speed (ssb504r) android 8.1 go edidion {Obama Phone }
Oy! Its been months and Im only now realizing I was trying to run stuff from the SDcard when I was in [ adb shell *~androidSDCard/*/*/* ].
I needed to be pointing at the files on the HDD of the machine whose terminal I am running. (DUH)
I only discovered this once I couldnt get f-droid.apk to install using the same mistake. :)
Now I forget what I was trying to even do back then.
This thing will still "phonehome" and do all sorts of spyware bullshiz if I am successful running this stuff right?
Solving THAT would be a matter of composing a new ROM from kernel right? Because the kernel CONTAINS the hardwares drivers?
Doesnt that mean we could literally run any distro installer and it would call the libs it needed?
(My brain is in magical theory land, where I dont understand what Im doing and now Im not even sure if what Im saying makes sense in theory)
Data recovery if I root
I don't think you've much chance. For one thing, Verizon have always been keenest on locking their phones to prevent rooting. But the big problem is that Android has encrypted the storage by default since Android 5, and the S7 was released with Android 6. So unless she specifically turned the encryption off any data recovery program will be faced with trying to recover encrypted data after the encryption key was deleted by the reset. Maybe there's some weakness in the S7's implementation that will let you recover the encryption key (which in modern devices should be in a special secure store, but just maybe they didn't do that properly), but I think the chances are very small.
If stuff stored on a removable SD card was deleted that's easy: those aren't encrypted by default, and you can just stick them in a card reader and run some file recovery software on a computer. But unless you changed the settings the camera was likely to be storing the data in the internal storage.
My app cannot pick customer location
Hi!
I have an online grocery app that was developed for me. The app suddenly stopped getting the customer location. The customer uses the app to buy products and at the end picks the delivery location. Now picking the does not work and the app keeps asking to select location. The IPhone version of the works well. Can you help? I have purchased the source code and have the admin web version transferred to my custody. I don't know what to do fix the problem.
Regards,
Samir
Filter
