Black spot on camera and in photos
- By JimKnuckles
- Smartphones
- 17 Replies
Nothing at all. The phone was still under warrantyHi, how much did Samsung charge you for it?
They seem to have stopped doing these promotions a couple years back. I haven't gotten one since 2016.Is the free 2 GB for real? Thank you, Val Elsberry
you will need to do a forget password. you can't do anything until you sign in with your account info. otherwise you will need to contact google to get your account fixed. there is no way around it regardless of what the internet says.My unknown sources is greyed out and won't download anything after a factory reset because I forgot my Google password
I was at Verizon store recently and in a corner among various cables, battery packs and assorted variety of things I found a LG G6. I bought one in January of 2017 through TMobile and by August the unit had disappear from the shelves. So I asked a representative about it his response wasbasically it was there for decoration no one was interested in buying it,
Hmmm alright.As I said, "...while scrolling through 'activities...'"
You can see some info/examples of them in my thread about ADW. I know other launchers can access them, too.
What did you mean with? I got my Huawei from a local Store?!the app store
Will I get all my stuff back if it's all backed up
So buried in location services is a switch for Wifi Scanning. In battery usage wifi used the same amount as RF while it was off. Switched it off and got a lot more battery life from my dying battery.I've checked the battery usage data and WiFi has used 15% but I never use WiFi. Why is WiFi being used when all my AP are switched off?
