Unlock
A tool sounds interesting. What also sounds interesting is understanding where this MSL code comes from. Some info I've found talks about it being a hash generated from a unique id of the phone like the IMEI number. But I really don't know. It could be a number which is programmed into flash at build time or sent via OTA at activation. In any case, what this exercise is telling me is that the process to use a smartphone in a different way than what the provider intended is far too complex for the average user.
Help Can't Get Out Of Photo App Once I'm In Without Reboot
have you tried a factory reset?
Thank you, ocnbrze - factory reset worked! As my girlfriend pointed out, I'd bought this new phone after having the other one for 3 years (I dropped it and it shattered and fixing it would cost almost as much as buying a new phone) and transferring all the info off the old phone meant I had a few apps that needed to be updated.
So when I did the factory reset, I answered "Yes" to updating all apps, and now the phone shows me my arrows so I can close out of apps and go "home." Case closed.
Another thing my girlfriend pointed out is that phones for sale at a retail store may have sat there on display and in stock for over a year, meaning that when you activate the phone, you should make sure all apps have the most current version, so don't transfer, say, Instagram and Snapchat as they were - install new versions and sign in.
Cheers and best to all.
Looking For Suggestions: Calendar App With Snooze Button
Hi All!
I'm looking for either a calendar with adjustable snooze or an add-on app for the Google calendar. I was wondering if any of you know of a good one.
The Story-
I used to have Calendar Notifications Plus by Sergey Parshin on my Android 5.1 phone.
That app would show a notification when the Google Calendar event triggered. i could swipe down and pick a time to snooze from a list I could make. For example- I had 5 minutes, 1 hour and 4 hours.
Due to a crash, I had to reset the phone & re-install the apps.
Sadly, the app is no longer available. I tried using a legacy version from archive org. It did not work.
My biggest desire is to have adjustable snooze times. I searched all I could find on the Play Store and came up empty.
Do any of you have a recommendation for one you have used and liked? A replacement calendar would be OK if it syncs with Google calendar.
Thanks For Your Suggestions!
Paul
[APP] MathAlly Graphing Calculator
Hi Dave and all ;-)
I gave Mathally a try and did not found how to quit the full screen mode (Settings/Full screen). Then, settings seems no longer reachable, together with other parameters.
The only way I've found to get back to the original screen is to delete the Applications datas (Android menu "Parameters/Applications/Downloaded applications/Mathally/Erase datas").
Unfortunatelly, other settings as the apps theme choice, font size, etc... are erased at the same time.
I'd like to know how to reach the settings while running the full screen mode.
Thanks for any answer ;-D
Charlie
Roboball Challenge
Some screenshots and two facts about “ Roboball Challenge”. Just for fun (sorry for mistakes, English is not my native language)
1. I caught one funny bug during game development. Due to the turn timer bug, we started to play without turn changing. Moreover, there was no calculated delay implemented yet, so my opponent made hits one by one without any delays. It was running just like a clockwork toy. And the typical score was 10: 1 or 12: 2 with no chance for me. AI smashed me easy no matter how excellent I tried to play. I thought then that it could be a great feature. Now you can test it by yourself with the game difficulty setting to “Ultra”. Excepting one moment now opponent has got calculated delay before hit the ball. And it gives you a chance to win.
2. How I made a decision to create this game? One summer evening I was busy with my lodge (I started to build it this spring). I was hitting nails and thinking about soccer. I like soccer and I like to play soccer, but like many other people, I haven’t enough free time to play. After hitting my finger with a hammer I dropped wooden plank and at this moment I dream with all my heart about robot, which can help me with the building process. And then I hopefully will have a time to play soccer. And the robot will be my opponent. I’ve found this idea very funny. And I decided to make a simple mobile game, which I can play in a pause during lodge building. And if my game will be interesting for other people (and will give me some money to finish my lodge) so why not?
Touch Screen Unresponsive
if it got wet, you should try the rice in a bag trick.
also i would recommend you use google photos for your pictures. it automatically uploads your photos to the cloud. i never have to worry about my photos or videos. i can even take a photo on my phone. hop on my computer and my photos will be there. i do not have to hook up any cords or anything. it is all done via wifi.
Update WebView Component Alone on Asus Tablet ME172V
I have a pile of Asus Tablets (ME172V) that have Android 4.1.1 (max) installed on them (donated to our tiny private school by a university).
I'm developing a primitive browser app (locked to one domain) for school use, and I'm implementing the WebView component in Android Studio to do so.
Due to the age of the Android OS, the WebView component does not seem to support certain modern CSS functionality. This is causing me some serious issues.
I want to know if there's a way to manually "update" that functionality in place, by itself (just the WebView component). Is there are way to do this without needing to update the entire OS (which is probably impossible given the age of the tablets)?
Linux that will embarrass those other OSes
And Ubuntu has a very friendly forum
Years ago, when I was very active there, it had turned into a clique-ish, holier than thou, unwelcoming cesspool. They treated newbies like morons. And the funny thing--in my UNIX-since-1985 book--was that THEY were newbies, too! These were like 1- or 2-year Ubuntu users, self-proclaimed as Linux gods. Their treatment of new users really turned me off. That was...I don't know, maybe 10 years ago. I'm glad to hear it's friendly now.
Good post, though. :) If windows people who use and love Android just made the mental leap, they could be happily humming along in an all-Linux world like I am.
The same author as in the OP explained in another article 5 reasons you should switch from windows to Linux right now. I recommend reading it for anyone sick of windows, or just wanting a better OS.
Filter
