Stop shutting down
- Smartphones
- 1 Replies
Just do a factory reset and make sure you know the correct Gmail account and password
i wait you rom gamerrom eclipse for galaxy s5 klteWelcome to GamerROM ORION
GamerROM ORION is a all new OS designed by Cyberdev to bring faster gaming then our previous OS on the Samsung GALAXY S4.
This is not your ordinary OS to just not play games, you can use it as your daily driver and play games, surf the web, weekly security updates and features etc.
Features:
- Your In Control (Your in control on how you want your device to run)
Download: (COMING SOON)
- No latency & no space slowdowns
WE WILL UPDATE THIS THREAD WITH MORE INFO AS TIME GOES BY OR WHEN MORE INFO IS AVAILABLE!
I had Business Calendar for a while a long time ago, it was very nice and worked well.
Disclaimer: I am relatively new to this site, so i'm probably posting on the wrong forum page, lol
WARNING: As most people these days know, rooting your Android device WILL void your warranty. So if you do not want to obliterate your warranty, do not continue through this thread! Also if you decide to follow my tutorial(s) on how to root your device, do not point the finger at me for any damage that might be caused to your device.
The easiest way I can sum it up for you is this, root = jail break. Meaning you, as the user, now have FULL CONTROL over your device, with very very little limitations. With root you can receive so many benefits including, but not limited to, installing custom roms, recoveries, kernels, boot animations, and so much more!
Depending on if your device peaks the eyes of any Android developers, your device might not have a root method at all, its on its way to having a root method, or it a root method is available to install at your convenience.
If you are an Android newbie, there are many factors to consider before saying 'Yes' or 'No' to rooting your device. Your warranty and the well being of your device. What I mean when I say your devices well being is that you CAN NOT mess the rooting process up, doing so just might give you a HARD BRICK for Christmas.
Links to my tutorials involving root will be available when the tutorials are made public.
At first glance, rooting can sometimes appear to be a method of destroying your phone, but that's only if you don't know how root works. Rooting is actually really easy, I have rooted my Samsung Galaxy Tab 2 and my Samsung Galaxy S4 Sprint with no troubles.
But, in a nutshell, rooting is basically giving you COMPLETE ACCESS & CONTROL of your device, like I said, with very little limitations, the only thing that could be stopping you is either an error message from Odin, your device might not have a root method online right now or boot loops.
That's my basic explanation of what root is, if you liked this thread, please feel free to read my tutorials and other threads down below (when they become available)
Thanks for the suggestion, but way too cumbersome. It's easier to just restart the app everytime I clear the recent list. Also, I think the author has found a solution within the app. I'm testing it now.Easy workaround is to pin the app to the list.
Pin it. Clear all. Open it. Try It Out!
Thanks for your reply. I’m using galaxy 5. I was looking for application manager and clicked on Settings. Quick settings, network connection etc all showed, but the display stopped at Applications, showing only the header and would not scroll up to show Applications Manager. I tried this several times without success. I have just tried again and it has worked perfectly! Sorry!where are you looking? there are a few places where apps will show up in settings. there's settings>apps and also settings>notifications.
all this depends on what phone you have, put they should be there. maybe a screenshot? or a better explanation on where you are looking for them.
.... think i recall now why i switched back ... notifications are harder to read i find ... but shall try for a few days and see how i get on with itHi,
This is an ongoing problem with me. I receive blank text messages from the same 5 digit number. I don't know where it is from or what it is. I delete it and then a day or two later another one. Any ideas?
that's a great question i can't answer......plus i was kidding....LOLYeah, but HOW? Like coupon codes for shopping, financial/budget planning, or what?
Database db =new Database(Combiner.this);. I tried this but its showing Database(android.content,Context) in Database cannot be applied to (com.example.data.Combiner)I have created a Database class file to use SQLite db in Android app. Since I am beginner and I am having problem understanding what should i put in context when I instantiate Database class to another class The database code is as follows:
public Database(@nullable Context context) {
super(context,DATABASE_NAME,null,DATABASE_VERSION);
database=getWritableDatabase();
How can I instantiate it to an another class. When doing instantiation Database db = new Database(); what should be put under context
