S Pen, Smart Select issue(?)
Hi, my Note 10+ is up to date as of today, 6 Oct. 2019.
I have a suggestion \ complaint regarding Smart Select with the S Pen.
I go to extract text to place in memory and that works just fine. I extract the text and am given a choice to Copy or Share. So far, so good.
I press Copy and the selected text is save to Clipboard. I am then forced to press Back on the Navigation Bar three times before I can proceed further. This issue also existed on my Note 9 as well. Smart Select functions as it should but it is always mildly annoying that I am forced to press Back three times. I trust I explained this well.
Is this a known issue ... or is it just me?
Help Make android think it has a SIM card?
I can believe their statement about them not knowing how to use it which would (in turn) cause the frustration to throw it
But anyway i got an email about 3 hours ago confirming no one has picked it up in the last 2 weeks and the offer of the phone came up so im going to pick it up later on...
below is a photo of it when i first found it (meizu m3s)
Yeh, send it for recycling. Quite frankly I don't think hardly anyone wants a rather busted China version Meizu.
Text detail on T-mobile bill
For the most part, Your phone number with area code will show on the bill as sender or receiver, regardless of where You are. As long as your ISP remains the same and/or use the same sim card. Now, other data configurations on your phone may or may not do what you are asking. For example if you use roaming, a 'mock location' setting or app, or if you reset your 'network operator', change apn and such.. Your bill will say, 'cellullar caller' , 'Tmobile user or tmo to tmo', it may also just say the devise's name. I've investigated this very issue on my own Tmobile bill earlier this year and those are my results. As to the specifics on how or why well, like I mentioned before, your phone settimgs as well as the device's settings of the party you are communicating with. Sorry, if my answer wasn't very straight foward. Hope it helps, though.
Seeing default Android files from a PC
Yes KingRoot already tried: it just doesn't go at the end of the process, keeps blocking at some point.
Will try iRoot right now, even if those are not trusted apps.
Actually the problem is bigger than that: the phones keeps randomly playing sort of a "notification sound" no matter if the phone is on plane mode or silent mode.
The phone keeps playing an annoying "beep beep" sound in the middle of the night without any reason.
That's why I want to mute the original audio file of this sound.
Installing software
androrat is a malware software from what i understand....which is not much....lol
just curious as to why you think that folks here would know how to run the program? maybe check reddit, 4chan or 8chan.
i still do not know why you need this info? android in generally pretty safe. as long as you are careful with what you download you should not have any issues with malware like androrat. just check permissions for the apps that you download....keep to apps that appear first when you do a search.
plus i just googled androrat and came up with tons of info on it.
Router Suggestions !!
Another thing I forgot to mention in my previous post that has worked out well for me was changing my DNS to CloudFlare. I noticed an instant bump in page load time over my isp's dns and even google's own.
https://1.1.1.1/dns/#explanation
In case you're interested, this is the primary and secondary dns for CloudFlare respectively.
1.1.1.1
1.0.0.1
I already use Cloudfare, but that doesn't change the fact of the Speed issue, only loading the pages
Unlocked Honor 8X
you can flash a firmware update, but that is different. i think you will need a pc to do that. i think that is what @mikedt is talking about. never heard of an update done over wifi straight to the phone before.
Every Android phone I've had, has had OTA updates downloaded and installed via WiFi. And I thought that was the default with Android devices, to download OTA updates via WiFi, Mainly because WiFi might be more reliable for large downloads, plus something like 2-3GB of Pie update, would really eat into limited data plans, and could cost serious $$$.
I've got a Samsung here, that's been receiving OTA updates and there's no SIM in it.
Some carrier-locked phones might require a carrier SIM and service for initial activation and registration, before they receive OTA updates. But the OP has an unlocked Huawei Honor, which should be okay.
The Beatles set new record!
Well, you can do it vicariously with this cute glimpse of 50 years of Abbey Road photos. Some even take their shoes off! :D
This article describes the photographer as a modest man, and explains how the photo shoot was done.
One of the articles says that thousands of people descend on that famous crosswalk daily to recreate the album photo.
Hey, Mike, can you answer this question? What do the zig-zag traffic lines on the streets in England mean? Examples are visible in some of the contemporary Abbey Road photos. My daughter lived in London for a year after college, and I remember asking her this...but I don't remember what she said. :eek: :D
The white zig-zags mean no parking and stopping. Intended to create a safe zone around pedestrian crossings where lines of sight for both pedestrians and drivers are not impaired by parked vehicles.
I believe they were introduced in the early 70s, after the original Sgt Pepper photo was taken.
Filter
