that's the last resort. try and uninstall the app first.Would a factory reset do any good
you can only hope. there really is no way in knowing what is going to get updated
Well, as I never have registered with my phone or logged in to download from Google, I would say there is no need to register.If this is incorrect, someone please enlighten me!
Yes, very strange. Since I removed that app the spam ads are not shown anymore at least.The fact that you're not seeing anyone else complaining about it, and its rating is high, suggest to me that it may not actually be the source of your problem. If others were experiencing what you were, they'd most likely speak up!
Considering everything Google does, from its own servers, to its cloud, to its laptops, to its mobile OS, is Linux, if they move toward anyone's style of support it won't be window$!whether Google are mofing to more of a Windows 10 style of support with ongoing security updates and yearly or half yearly 'feature updates'.
Okay, good! Nice to hear a happy ending.I have just found the app that I said I can't find on the Google play store.
Yep my note 10+ is locked down pretty tight..... there's no rooting this puppy unfortunately.I'd like to point out that Motorola is one of the root friendly brands still left. Just like a Pixel you can go to the Motorola website to get instructions on how to unlock the bootloader for your model. Rooting is easy from there.
It's been a long time since I've used a one-click app to root a phone. Those things are risky anyways. Some come with weird chinese root exploits and I just don't trust them.
Surely you must have a friend that will let you use their PC for a few minutes. By the way, you can go "big boy galaxy" and still be in the same predicament.
I've been especially pleased with the battery life on my V40, untill recently.
Battery stats indicate that "Held Awake" percentages are increasing.
No new apps recently to explain the increase in wakelocks either.
What do I look for to find out what's happening. I had thought I had my settings right.
Did I miss something?
adb devices
adb shell dumpsys power | grep -i wake_lock
I noticed an an App called " strings tuner" was using up high megabytes of background data, even though I only use it occasionally to tubne my guitar. Could it be evesdropping?
