Help! I think I found spyware!
Status update:
I have carefully followed the expert advice of everyone in this forum and it has brought me to a new realization. I ran the 2 files I discovered in my Google Docs through the website to which svim directed me and within seconds they were both determined to be without spyware or malware. (So why were they planted there??)
I have been barking up the wrong tree! My phone is not, in fact, the target as MB or svim (forgive me, I can't see the conversation from this screen) said earlier in the forum. After following everyone's advice I realized that it was my Google account that may have been compromised. So, I went on YouTube an researched what to do. After going into the 'Sign In and Security' section I was able to see what devices had been signed in to my Google account over the past week. Two of those devices I didn't recognize. So I found the IP #s of those 2 devices, one of which was a Google 'switch' and plugged them into a program that geographically pinpoints devices based on their IPs. (It might be called 'Checkpoint' but I'd have to backtrack to be sure. I found many after searching for 'IP Geography') That's when I recognized that someone I know is right now traveling the same area as the switcher. PA, DC, and Tampa. So that took my ex out of the equation.
Upon gaining that knowledge, I went in to change my Google PW once Again when I noticed the option to access other accounts tied to my personal account. It was then that I discovered a 'Brand' account attached. I have never heard of such a thing, but I could not access the account. However, the security question specifically named one of the 2 people who are making that particular road trip as we speak.
The security question is 'where did you meet _______________'(one of their names), but the name is spelled incorrectly so I can't know for sure which one got into my account.
All that being said, I still have so many questions. Especially motivation!
Nevertheless, I am going to continue following the precise directions or my new and highly respected friends here at the Android Forum until I feel the last little possible bug is cleared from my entire system of communications!!
I am mentally EXHAUSTED, but well on my way to redemption thanks to all of You!!
Much Appreciation!!!
KaTastrophy92
Offline fm radio tuner app that allows recording
I am going to change phones and it seems some other phones have a radio app but only samsung has that radio app that allows recording of live radio.
Motorola phones also come with FM radio apps that can record live radio. I must say that Moto's FM radio app is the best I've used. It has a nice array of features, including light and dark themes.
Help Can't respond to group texts.
I am having the same issue on my Galaxy Note 9. I can't respond to group texts, but if I enter everyone's name as if I'm starting a new text it does send the message and it shows up in the thread with other messages from that group...so I guess you would say I actually can respond, but not without reentering everybody's name... I can't just type in a message and hit send. My message just turns grey and shows an explanation mark next to it.
ARcore - is it possible to make AR APP using powerful phone that is not listed in google officially
Hi guys
I have a question related to google ARcore supported Phones.
I have a Xiaomi K20 pro phone that has powerful specs to handle ARcore but it isn’t listed in google “ARCore supported devices” list.
I want to know, is there anyone here who has experience with developing a AR APP with ARcore with Xiaomi K20 pro (or any other powerful phone that doesn’t listed in the ARcore supported device list)
and is it possible to do that or not?
PS, Xiaomi k20 pro specs are exactly the same as Xiaomi Mi9 ( Mi9 is supported but K20 isn't )
Cheers.
Spinner not getting populated with database records in android
Hi. I am using Yii2 REST API. I have a table called studentrecords consisting of Id,FirstName,LastName, Class fields. I have a API which returns the json array containing stiudent FirstName and LastName. API is working fine. Now I have a android code where I use a spinner to display student names from the database.
Java:
package com.example.anitaa.studentapplication;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.widget.ArrayAdapter;
import android.widget.Spinner;
import org.json.JSONArray;
import org.json.JSONException;
import org.json.JSONObject;
import java.util.ArrayList;
import java.util.List;
public class UpdateActivity extends AppCompatActivity {
    Spinner spinner;
    ArrayAdapter adapter1;
    String url1 = "http://192.168.1.6/student/web/studentrecords/studentnames";
    @Override
        super.onCreate ( savedInstanceState );
        setContentView ( R.layout.activity_update );
        spinner = (Spinner) findViewById ( R.id.spinner1 );
        final List<String> list = new ArrayList<String> ();
        try {
            JSONArray jsonarray=new JSONArray(url1);
            for(int i=0;i<jsonarray.length();i++)
                JSONObject jsonObject = jsonarray.getJSONObject ( i );
                list.add(jsonObject.getString ( "FirstName"));
                list.add( jsonObject.getString ("LastName"));
        } catch (JSONException e) {
            e.printStackTrace ();
        adapter1=new ArrayAdapter ( this,android.R.layout.simple_spinner_item,list );
       // adapter1.setDropDownViewResource ( android.R.layout.simple_spinner_dropdown_item );
        spinner.setAdapter ( adapter1 );
When I run it then spinner is not populated witth records. How to do?
Supports-Screens
Hey I have been learning about developing games for Andriod and I just wanted check some information becuase it's not 100% clear.
Firstly the bellow two links from the Andriod Developer website both show declaring support in a different way.
The first one:
https://developer.android.com/guide/topics/manifest/supports-screens-element.html#compat-mode
Code:
<supports-screens android:resizeable=["true"| "false"]
                  android:smallScreens=["true" | "false"]
                  android:normalScreens=["true" | "false"]
                  android:largeScreens=["true" | "false"]
                  android:xlargeScreens=["true" | "false"]
                  android:anyDensity=["true" | "false"]
                  android:requiresSmallestWidthDp="integer"
                  android:compatibleWidthLimitDp="integer"
                  android:largestWidthLimitDp="integer"/>
The second one:
https://developer.android.com/guide/topics/manifest/compatible-screens-element#screenSize
Code:
<compatible-screens>
        <!-- all small size screens -->
        <screen android:screenSize="small" android:screenDensity="ldpi" />
        <screen android:screenSize="small" android:screenDensity="mdpi" />
        <screen android:screenSize="small" android:screenDensity="hdpi" />
        <screen android:screenSize="small" android:screenDensity="xhdpi" />
        <screen android:screenSize="small" android:screenDensity="xxhdpi" />
        <screen android:screenSize="small" android:screenDensity="xxxhdpi" />
        <!-- all normal size screens -->
        <screen android:screenSize="normal" android:screenDensity="ldpi" />
        <screen android:screenSize="normal" android:screenDensity="mdpi" />
        <screen android:screenSize="normal" android:screenDensity="hdpi" />
        <screen android:screenSize="normal" android:screenDensity="xhdpi" />
        <screen android:screenSize="normal" android:screenDensity="xxhdpi" />
        <screen android:screenSize="normal" android:screenDensity="xxxhdpi" />
    </compatible-screens>
Is there any real difference between the two other than that the first dose not specify density?
Second I wanted to just make sure I understand what exactly constitutes as a Small, Normal, Large and xLarge screen.
Please correct me on this:
A Normal screen is a HVGA 480x320 pixels screen. This value is the baseline for that other screen sizes.
A Large screen would be 1.5x the normal baseline.
A XLarge screen would be 2x that baseline.
and so on...
Unable to read SIM data on Samsung A50
Just purchased a new Samsung Galaxy A50.
No issues with the phone other then listed below.
It is a dual SIM phone. With SIM 1 - AT&T, SIM 2 - SaskTel.
I cannot get any SIM Data to read. My old phone (Samsung Galaxy S8) can read both SIMs perfectly fine. So the problem doesn't appear to be the SIM cards themselves.
The phone is completely functional otherwise (can place calls, text, browse, or write on this forum)
What I am trying to accomplish is migrating RoboKiller to my A50. It gives an error (see image) and I cant get it to function.
What I have tried:
Turned off data
Turned off SIM 2 (and vise versa)
Restart
Cleared SIM data (in settings)
Used 3G Mobile network
With or without WiFi (even turned off)
Is there anything I am missing?
Apps Android screen recording portion of app
I am creating a feature in an app in which the user can record their screen. So far, I've been semi-successful.
As a first pass, I tried recording screenshots then encoding them using JCodec. This worked, but the encoding was extremely slow on Android which made it unfeasible.
A second attempt was to use MediaRecorder but this records the whole screen, including the Android UI. The results are ugly and I haven't found a way to record only a portion of the screen using MediaRecorder.
So I'm looking for any alternative solutions or possibly a library that can crop video that isn't slow to process like JCodec. Any ideas?
Help Screen goes to sleep after 5 seconds
Have you tried restarting the phone? But could be a bug in the firmware though that Motorola needs to fix, because I had a very similar thing happen with an Oppo R11 once, the screen would go to sleep after 10 seconds regardless of settings, which was fixed with a subsequent OTA update
Yeah. Tried that. This has actually been ongoing for months. I really don't like this phone.
Is Poweramp hi res music player a relic to some, or do you favor Samsungs
I was never a Poweramp user. I've used Winamp through the years but it is no longer supported... at least I don't think it is. I stream SiriusXM so I don't really play my own tunes like I did in the past. I enjoy my own tunes but they were collected over a long span of time from many places. Some are so old that they are of lesser bit rate and they all have a problem of not being ripped at the same volume level. All that is eliminated with a streaming service but my library is larger than what they care to stream.
Geography. Quiz. Many tests
Install the application &#8220;Geography. Quiz. Many tests&#8221; - this is an entertaining game where you need to answer questions, guess the right answers, gain new knowledge and learn interesting facts!
Geography. Quiz. Many tests:
&#10004;&#65039; A free, smart app to test your knowledge of geography!
&#10004;&#65039; More than 2000 questions!
&#10004;&#65039; Simple and intelligible interface!
&#10004;&#65039; Questions include all geography topics!
&#10004;&#65039; Ability to choose the topic you are interested in!
&#10004;&#65039; A great way to relax and exercise your memory!
&#10004;&#65039; Interesting facts on the topic of our planet and geography!
You can study geography or prepare for the exam and assess your level of
knowledge of geography.
The questions presented in the game cover all topics and key areas of
geography.
Here you have to guess which state is located on the map, which state the flag belongs to and answer fascinating questions about the countries and states of the world.
How to play:
- Press the 'START' button and select a geography category you are interested in!
- Each topic has its own levels. Levels open when you pass and score points!
- Get points and coins for every correctly answered question!
- Points give you the opportunity to go to the next level!
- Coins give you the opportunity to use the tips when passing the quiz!
Tips:
At the bottom of each question there are 4 tips that can increase your chances of a correct answer.
&#10004;&#65039; &#8220;50:50&#8221; - use this hint if you want to exclude 2 incorrect answers to the question.
&#10004;&#65039; &#8220;Skip question&#8221; - activate this hint to get through without minus points.
&#10004;&#65039; &#8220;Audience survey&#8221; - use the audience to check, other users choose the answer option.
&#10004;&#65039; &#8220;Reset Timer&#8221; - resets the time if you need to think more!
In this quiz you will find questions from the following categories:
* Flags of the world
* Capitals of the world
* Country by contour
* World countries on the map
* Lithosphere, hydrosphere, atmosphere
* Geographical Discoveries
* Tests on the continents (North and South America, Europe, Africa, Australia, Asia, Antarctica)
* Country Population
* Currencies
* Sights
And also a lot of interesting facts about the world!
' Geography. Quiz. Many tests' - a quiz for those who want to study geography.
Have fun and you will have the opportunity to improve your general knowledge and memory!
https://play.google.com/store/apps/details?id=top.excellenceapp.engeography
Notifications
It's the fact that the tab doesn't know that you've handled them on another device. Not an android issue as such. And TBH I don't see a way of stopping it on the tab except by turning off notifications on it.
I don't know what apps you have this with, but with my tablet (also less used than my phone, and often inundated with notifications when I turn it on) I will receive notifications for new unread emails, but not for those that are read. Which is reasonable: the server tells the mail client which mails are read and which are unread, but it doesn't know which ones I've received notifications for on another device (it may know that another device has downloaded them, but it doesn't know that that device has notified me or that I've seen it). This also means that with one of my accounts both my phone and laptop will notify me of new mails unless I read it on one before the other downloads (i.e. it's the same with my laptop, not android, as with my different android devices).
With calendar apps if an appointment has a reminder set all devices it's synced with will notify me. So again my laptop and phone will both do so, and my tablet if it's on at the time (but it won't notify me of things that have been and gone in the meantime).
Without knowing what notifications you have I can't say what's reasonable. I'm just mentioning those as two examples of cases where I get multiple notifications and would expect to do so.
If you want an example of unreasonable notifications, then Facebook is exhibit number 1 (it does know exactly what you've done on any device, but is quite happy to notify you about something you read 2 hours ago on a different device or even using a different app. They don't care as long as it gets you to open their app again).
Filter
