Help Is there a way to permanently block an app from asking for draw over permission?
"Draw over other apps" is not one of the permissions that Google offer individual control over even in Android 10, so if it won't accept "no" for an answer all I can suggest is finding a different keyboard.
(My wife's phone came with Touchpal, and she's generally not that particular about things like that, but a few months ago even she got fed up enough with it to replace it. It's been getting worse for years, and if this particular straw isn't the breaking point all of the evidence suggests that they'll come up with something else soon).
pretty good phone for the price
Glad you like the J7 Crown!
My just replaced Moto G4 also has (I kept it) a 5.5" screen and 16gb of storage with 2 gb of ram. Before that I lived with a Moto G 2013 with 8gb. it's amazing how many apps you can keep on some devices.They worked very well.
If it has all the features you need and you like interfacing with a Samsung, I do, you did very well.
The cheaper end of the market has much better devices these days
Apologies to the previous poster who read perhaps too quickly. I wasn't being anal, I was just bored :)
SM-A305G PROBLEM WITH FLASH
Hello friends, I am from Latin America, I have the SM-305G device, the phone is bought from a telephone company, I had problems with FRP, I used ODIN, downloading the combination software, but the error is always the same: please get the approval to use factory binaries (pit), I have downloaded the pit file from a server, it has not worked, also extracted through MIRACLE BOX, but the problem persists always, I also used the Z3x tool, but I did not get results, now I come here to that can give me a hand and thus be able to solve this.
Photo link with a problem: https://drive.google.com/drive/folders/1HWtBkdf-mdjz9trDL_cDYgixDRYXLUyy?usp=sharing
Help Do Not Disturb
OK. Thank you. I will start using Silent mode.
This seems to be different from how it worked on my old Samsung S7 Edge. On that phone I just set Do Not Disturb manually and the phone did not ring if a call came in, but the settings description for the S7 specifically says that the phone will not ring while the settings description for the S10+ says no such thing.
Any way to show who message sent to other than conversation mode?
If you don't like the GMail app (and I don't particularly like it either) just use a different one. There are a lot to choose from, and there's no need at all to use Google's app for GMail, or for anything. I keep it disabled on my phone.
I'm currently using Nine, which allows me to turn Conversation view on or off, shows me the recipient name in the Sent folder. I've previously used MailDroid, AquaMail and K9, all pretty configurable even if I can't remember exactly which options each has. Just try a few and see what you like (remembering that the views are only one element of an email app: I personally won't use one where the app company passes my mail through their servers, no matter what benefit they claim I derive from that).
As for hoping Google will listen to you, good luck with that - their attitude (not uncommon amongst tech companies) is "we know best", and you are supposed to fit into their mindset.
Samsung Galaxy S6 laqing
Unfortunately the symptoms are not specific enough to identify the cause. Going into recovery and clearing the cache might help. A factory reset is more likely to, but you lose any data that aren't backed up. But nobody can be sure: it might be that there's one specific thing you need to do to fix it, but we don't have enough information to work out what. Or it might be a hardware failure that's not worth the cost of repair. Just the fact that it's rebooting isn't enough to tell.
If there were any other problems before this please tell us, as that might give a clue.
Pubg
I too used to face the same issue earlier while playing the game of PUBG then I lowered the graphics and FPS too. It works fine for me now. I won't say, its not like lagging at all but at-least the lag has decreased a lot from early time. Sometimes it's also due to the network connectivity or you can say slow network.
I would love to know if there's any other way to fix the lagging issue because this game is good but the lag issue gives a tough time.
Thanks.
Filter
