What was your first car ?
My uncle owned an old Cadillac. A bit older than your grandfather's Caddy A 1929 I think. Pic from the net.
Oh my goodness...I LOVED Armour's corned beef hash--though I never heated it up in its can.This stuff I ate a LOT too while out at sea in the Pacific somewhere. I'd poke a small hole on top (to vent it so it wouldn't explode) and set the can on a steam valve and in 20 minutes it was hot.
Rather than an icon, you'll need to have a widget on the home screen, of the calendar app.
For date, OP actually can use dialog too.You have to make different activities for this. One for a date, second is for the name then for a video.
You may need to do a factory reset to fix the issue
Have you tried clearing the data and cache on the app that's doing it?
If you do a search for Google feedback or Google suggestions, there are a few avenues to try.Awesome no problem!! I have already set these setting though on my phone I have the two sliders but they only appear on the half way pull down so I'm assuming this is normal it's just a pain in the ass do deal with it on the lock screen anyways thanks guys!
Is there a website or something that people can write to Google for suggestions on improvements for the Android OS??
Samsung Members App
)I was pretty amazed that after submitting an application that required a credit inquiry... Seconds later I received a push from Credit Karma.
Pretty nice app overall... Very useful information.
