GChild78
EDIT: Just saw your post GChildyou should answer questions for me when I'm not around
I try.
If you are using Clockworkmod to do so, then the answer is no. It will make a separate image. Keep in mind that it does take up a lot of space on your memory card.
Thanks GChild78. You know too much to have stayed lurking so long. Instead of waiting to see what's going on, I can't seem to stop myself from blundering into forums & annoying people.
I just did nandroid & it took ~ a gig of storage. When I got the card, the 32GB was maybe $5 more than the next smaller one, so WTH. I have 25GB left. I'm sure it's a weenie card size for a lot of people, but mine won't fill up too soon![]()
I'm not familiar with launchers. It looks like a tool to customize/personalize the look & behavior of countless interface parameters. (Is interface called UI on phone?) What does Holo Locker do? (I did read blurbs on PlayStation)
EDIT:
Probably asking the impossible, but is there some kind of feature that lets user store email addresses & paste them where needed, kinda like autofill?
32gb?!? That's pretty big in my book. I use a 16gb.
It's big to me too! I wouldn't have gotten so much storage, but the price difference was so little-- it didn't make sense not to get it despite being such a low-level user. I figure there must be people around here who would feel cramped with it.
Had to look up ICS lock screen. LOL.. I have a hard enough time unlocking the phone in time to answer calls as it is! Maybe I pass on that one ;P
HaloBean 8 must have broken again... damn damn damn...
Well 9 is gonna have to take longer so I can fix out more bugs that are appearing now... I'll have to start the rom from scratch again to get rid of issues that have appeared throughout releases then
You saying tether is broke then? Also, does mms work at all in 7?HaloBean 8 must have broken again... damn damn damn...
Hmm... depending on the phone and the development community I might consider it but not if there is little 4G in your area as 4G is just a waste off battery life in your case
And no iWireless--they're on Boost Mobile or Sprint
Yes. That is exactly what he said, unfortunately.You saying tether is broke then? Also, does mms work at all in 7?
Uh oh... started playing with Holo launcher & my drawer button disappeared. It might have happened for another reason... I don't have the the knack of moving screen icons yet & tend to stack them a lot of times when putting them on the desktop. I might have removed button trying to unstack icons
How do I get it back?
I did that once lol. I don't remember how it is I got it back but you might want to try clearing the data cache for Holo launcher. You're gonna lose any changes you made on it though. It's the only thing I can think of at the moment.
