What is reason for purging dalvik cache? Is it OK to delete contents via root explorer or is there a particular way it's supposed to be done? How often?
@skinny, I'm trying to make a custom boot animation and I was just modifying your bootanimation.zip. I take the actual png, clear it out and add my own to it but it doesn't work. Could you possibly help me with this? Are my files possibly too big? Thanks.
It's probably your compression method. Unlike the rom zip which is compressed to the best possible level, the boot animation has to be compressed at "store" using WinRAR. That was my problem before. The compression method is one of the biggest problems when you're making a boot animation the first time... I was trying for months to do it... once that problem was out of the way I had to edit the desc.txt file (I think that's what the name is inside the zip). If it's done incorrectly, you'll end up with a bad boot animation again.
That was exactly the problem. I use Linux and couldn't find a program to store the data in an archive, although I am sure there is one, so I had to use my windows partition lol Thanks a lot man!
Just a FYI for i-wireless folk...
HaloBean 8's browser requires some kind of sign-in, so I don't think it'll work on i-wireless. Personally it doesn't matter to me bec I'm an Opera fan. [Aside for Opera folk.. the current beta build (11/29/13) isn't working on this rom, but the Mobile Classic version is fine & fast. Haven't tried the Mini. (The "Opera browser for Android" sez incompatible w/ our device)].
There's a lot of talk about Dolphin, so I took this opportunity to check it out. It seems more geared to social networkers, which I'm not. Not that I gave Dolphin a fair shot... Staying w/ Opera because, well, I just like it-- have used it on PC for over a decade so I'm prejudiced![]()
I've got a nearly full 32gb in mine. Apparently our Warp will support a 64gb sdxc. But that may just be in CM10. I don't know if anyone has tried it on this ROM yet.
A sign in? That shouldn't be necessary... I'm gonna have to change the browser settings so it loads Google or a blank page instead of that other Boost sign in page. You should've been acme to just open another window and close the old one though.
4G isn't in Knoxville yet. According to Sprint site it's already available in several smaller TN towns within a 100 mile radius, so it's creeping close... probably a matter of months.
4G LTE is already showing up all over Knoxville TN even though Sprint has not officially launched it there yet. Check out the maps on sensorly.com to see where people are picking up LTE. You will see that the rollout is well under way.
I know how to change Phone ringtone & Notifications, but never could find a way to change Alarm ringtoneHaloBean comes with the ringtones in Cyanogenmod 10 which is jelly bean, so there are different alarm ringtones than in gingerbread
You should be able to change it through the HaloBean settings menu like in stock![]()
I have NO idea what stock feels like unless its on my moms Warp.
Thanks...well now I know.
How have you kept your hands off of it? Root it for Christmas while she's napping... Tell her Santa did it![]()
I think I'm going to make an 8.5 to fix issues such as Wifi tethering not working, and with enhancements for wifi and the powernap script... neither v1 nor powernap v2, more like a HaloNap (its actually called SleepyHaloz in the rom)
