Bout to fix the script I posted in a few minutes
Did you upload the fix?
Should i clear cache/ dalvik
edit... cn thats wrote in script please dissregaurd
Uh oh....
I seem to have lost root
Opened TB & got this msg:
Could not acquire root privileges. This attempt was made by using the command "/system/bin/su"
Opened SuperSU & got this msg:
There is no su binary installed & SuperSU cannot install it
I went to /system/xbin/ and there is a file named su but I didn't try to open it as I would have no idea if it looked right.
Rebooted twice
I decided to uninstall/reinstall SuperSU to see that the app was in good shape. In App Manager, Uninstall is not a choice. In it's place the option is Uninstall Updates.
- I uninstalled updates. Got msg that SuperSU is restored to factory version
- Opened SuperSU. Same msg-- no change-- no root
- Reinstalled updates. No change
While re-updating I noticed these 2 items listed under What's New:
-- Binary denies root if PIN code set previously but GUI not presentHmmm... don't know if there's a PIN code. Don't know if it means some fundamental GUI that's coded in or whether superficial changes (like playing with icons) can affect SuperSU's ability to detect GUI (?) Of course the SuperSU error msg said: "no su binary installed", which is a step before the "binary denies root" (changelog), but then again the effect of denying root might make it appear that there is no binary ... [aimzzz pulls hair with both hands]
-- Fixed some devices losing root
If SuperSU update change re. GUI caused the binary to deny root, should root be reestablished when I reset SuperSU to the older version, or is a matter of once it's gone, it's gone? (Heh...it may sound like I know what I'm talking about but I only have a vague idea about it. More likely I sound like I don't know squat)
Is there another SU-like app I could install to test whether the problem is the result of SuperSU update?
If not, do I need to start over? If so, is it just a matter of reinstalling the root zip file?
Of course the problem might have a totally different cause ...![]()
Should I just reinstall the root zip then?I know Superuser by KoushikDutta had this issue, but not SuperSU... I'm not having this issue on my new test builds... but the test builds use the same supersu as the one in HaloBean8 so there should be no issues?
Uh oh....
Rebooted twice
That's how I bricked my Warp... messing around with it. I did bring it back to life after toying around for a day with it
Oh, I did to! We all like to play with it. And believe me, I'm not as savvy as you guys. And It all comes with experimentation, and seeing what we can do on our own. It's a learning experience. I'm sure she's a lot better at this than I am. But, I've learned, "ask first". LOL. Bless her heart, she's trying!
BTW, Good job my brother! And have a great holiday!
You don't sound inclined to believe me, but I haven't done anything I can think of that would cause such a problem. Definitely haven't messed with any scripts... I wouldn't know where to start.What the heck have you done?
Yeah, I tried both earlier. Also I did a restore which didn't help at all.... same error magThe root zip? No... that won't do it. Factory reset won't fix it either.
Since the 10th I haven't used anything requiring root, except I used root explorer, but only in the Storage section, not the root side. I'm not even sure exactly when the problem happened. This morning I decided to back up some stuff using TB. When I went to the Backup tab, I got the msg that it could not acquire root privileges.
Over the last couple of days, I DL'd some icon packs & played around with them using Holo launcher. I installed a couple of keyboards & tried them out. Reinstalled a scanner app that I hadn't gotten around to since rooting.... cant remember anything else
How do I reflash the rom?
Flash it again through recovery: just locate the zip file that you downloaded to your SD card in ClockworkMod, install like you did before, and that's it. Then you can go in titanium and restore your apps from a nandroid. In fact, make a nandroid before installing the rom again so you can restore the apps from the nandroid backup in Titanium Backup. Really cool feature![]()
It looks easy but, I'm not using the Warp-- am using the Flash, so I didn't use ClockworkMod. I rooted with Root_with_Restore_by_Bin4ry_v32 from xda.
To install it you extract the zip file onto the PC desktop. Then you run a .bat file from the PC (RunMe.bat). I'm trying to remember what I did earlier to get the recovery but I think I did recovery by running that file. I had done factory reset & I think .bat file did a recovery instead of re-rooting... arghhh! I can't believe I don't remember what I did just a few hours ago
Edit: I renamed the .bat as a .txt & am attaching it here: View attachment 65442. It shows the code that directs the recovery. If it's the equivalent of recovery through ClockworkMod, then I already reflashed. Maybe I'll try it again while waiting... (Used option 1 for my device)
Sorry everybody!!! I meant to stop posting in the HB8 thread about this problem if/when it got past the point of being a general problem & became specifically about my current phone (ZTE Flash). I managed to forget my intentions by the time I got to my last post.It may also be more helpful to you to post in the device-specific forum. Not telling you I or we don't want to help you, but you'd likely find more relevant help there.
Sorry!!!!!![]()
in a little different direction, but hroark posted return to stock b08c, but how do I return to stock b10? is there an update from b08c to b10, or ...?
thought I read you used to be able to update from stock rom to a newly released rom (all stock, without root), but that the method has since been shelved? color me confused, eh?
ps. really liking halobean and droidsmith so far. skinnyjeans, you mentioned halobean 9? holiest of cows, do we have a timeline?
