SO it turns out I was running my phone at 1.4ghz min and max with smartassv2 and sio for the longest time... GREAT battery life great performance![]()
Are running both of those at the same time? And why does my voltage control say MHz instead of ghz? Ghz are way larger than MHz
Yeah sorry... still feeling the after effects of midterms -__- really tired from all those tests and assignments :/ On the bright side I have monday off so I can set my computer up to build the rom and have it ready on monday probablyI still need to reinstall Virtuous Ten Studio...
It shows active but non-functional. There is an occasional error but I can never recreate it to be able to logcat it. The other device shows that there's a connection to my Warp, but that the warp has no connection to the internet. It almost worked once when my laptop began to load Google.com, but then I saw my phones signal indicator change to white so something fishy is going on and blocking the phone from connecting. I don't think other roms have this issue though I remember something similar happened in CTmod
So... what is the first version that has tethering built in? I would imagine this was added with Jim's modifications to wifiservices.smali? I have copies back to 4.46 - Just don't remember when it was implemented...
Edit... Guess what I am asking is what is the first version it worked properly and what version did it stop. I really wish you had a detailed changelog or a git...
I tried to keep the change log detailed and git just never worked for me. But I do have when I added tether in the change log... from what others have said, HB6 is the last version to have it functional. I doubt the apns have anything to do with it, huh?
I don't think the APNs would be an issue but anything is possible... If MMS works, I wouldn't think the APNs would be the issue. I've been comparing smali files and haven't found it yet... but I'm still looking... As far as a detailed changelog I mean if you kept notes of what mods were done to which files by version - not just features, but the actual mods so we can track down what broke and when...
On a lighter note, stuff like this is helping me learn the file system betterThis week I'm starting Linux From Scratch (thanks DM for the tip) which hopefully will let me learn more about dependencies and structure...
So if others say it worked in 6, are we safe to assume it broke in 6.2? Which sprint apks did you remove in 6 or 6.2?
dunno if this will help but on warp oem if i used 3g/4g optimizer and ran the 3g tweak it would break it just would uninstall tweak to get back working .Everything is so damn easy to break on the Warp specifically with Wi-Fi... I compared the settings from both HB9 and the one from HB6 using Virtuous Ten Studio... not many differences aside from theme changes. But even reverting them doesn't fix it. No changes in smali either... so it has to be framework.jar or something else...
You should ask dm to add you to Team Osiris on GroupMe, you'd learn alot from seeing what they do on there. I have, even more than just Android and also a bit more about computers in general really
Its not something I removed, because after adding everything back in nothing would work... so it must be some code that was added thats causing the problem. Thing is, I'm not exactly sure where... I need to keep a really updated and detailed changelog, sometimes I forget what changes I make as I'm going through the rom :/
I was on phone...now I do not have internet on PC,unless I tether it through my phone with planet. So using my Pc that way would I be able to d/l it ?
