Root [Boost Mobile] [ROM] Warp OEM 2.70
Wow Dude!! My personal best was 8171 on the Aliance 3.1Alpha. That's great:smokingsomb:
Thanks! I was a little surprised when 8197 popped up. Especially with a class 2 sd card and lots of apps... The tweaks really pulled the 3d scores up!
I could not pass 8k but this is the best still not bad though.
I've never hit 8k yet, but 7,600 is commonplace.
Depends on your sd card and how picky antutu is being. On alliance 3.1 I bench from 7400-7800. I have a class 10 32gb that I know from sd tools is up to spec. The best I've gotten in antutu is 9 megabytes write and 20 read, I've seen as high as 12 write and 30 read in sd tools. That particular bench is my best, just above 7800.
Yeah, I only have 2gig class 2 sd card, and I almost always get about 7600, both on WOEM and Alliance. It's a little odd to me that the card does somewhat decently compared to higher classes. I lost about 200 points on Alliance between 3.1 and 3.5, but I had a much more considerable wifi hit. Hear that's fixed. I tested it between two perfectly working connections. Turns out WOEM does the wifi best for me. Download speeds at my house tend to be around 1.5Mbps (not thoroughput). Anyway, back on topic! haha
I think comparing the benchmark is pretty on topic especially since the release of the flashable tweaks.
Keep in mind that a class 2 card only has to have a 2 megabyte per second write speed MINIMUM, it's perfectly allowed to be faster. And the class doesn't take the read speed in to consideration at all. Read performance is good on all but really crappy cards. So even if you only get 2 megabyte write speed, if your read is say 20 MB then your card is only losing about 80 points to my best bench.
First Rom I've tried since the last update of Noob Rom, works awesome. Just wondering if there is a quick panel setting, where I can change the order the quick panel like WiFi, Brightness Airplane mode in the status bar?
Good question,:) Doesn't seem to be:(
No, sadly there's no easy way to do that. The original implementation of the toggles had that feature, I believe, which was to my knowledge an exclusive to Cyanogen. But as they got ported from phone to phone, it seems the necessary arrays and such were stripped out. In theory, it could be done... but it's far enough above my Smali ability that it probably won't get done by me.
That being said... anyone else up for it? I simply don't have the kind of time it would take to learn how to (re?)implement such a feature.
And with all that said (lol) there is one thing I can think of which would maybe be good enough. A flashable could be made which would set the toggles in a custom order, but again... time, time, time...
This looks like a job for an awesome themer... hey Skinny! :D
Who's skinny? He sounds like an awesome guy! :D
mmm why couldn't it just be ported from another rom? Isn't he talking about just changing the order of the widgets? Its in most of the roms here...
