mercury0x000d
The ultra-modern operator
http://www.ebay.com/itm/ZTE-Warp-Boost-GPS-Bluetooth-Android-5-0-MP-Camera-Cell-Phone-/170857211303?pt=Cell_Phones&hash=item27c7e225a7
...my, that link looks familiar lol
The milk got spilled on it over a week ago, I took it apart and cleaned it. it worked fine until last night. I rebooted and bam nothing, its completely dead
EDIT: Alcohol was a no go phone is still dead
Hey, just a thought... but since you've had your Warp apart before, would you consider uploading some high-res photos of the circuit board so that I can check for the existence of a couple specific chips?
So I am having a problem that is getting real annoying. Anytime I switch from wifi to 3g or vice versa I have to reboot my phone because I can not receive any data. I reboot the phone and I can then receive data from either wifi or 3g but as soon as I turn the wifi on or off I have to reboot the phone? Is there a fix for this I have fixed permissions 1,000, times . I am on the newer beta 3.
You have to edit the styles.xml in framework-res.apk and if you would like to donate the link is at the bottom of the op.
Kernel conflicts?
Consider it done. On another note I am having an issue I have not yet seen reported. When I open Google Music it FC's. Have tried uninstalling with TB but it will not uninstall it says Failed to locate the apk file. Not sure what to do here.
Music.apk in system/app/ if you updated it then it will FC. Not sure if you can update it but if it managed to then that would be the reason why.
I thought maybe that was what happened because I used TB to batch restore my apps after installing the ROM. Have always used Google Music so it was included in the batch restore. Of course it wouldn't update it so the batch restore froze at that point. After I initially noticed this wasn't working yesterday and figured out the above, I did a data and cache wipe, installed B08, did another cache wipe and installed Beta 3. This time when restoring apps I did not include Google Music. Result was the same it FC's and doesn't work.
If I delete the apk from system/app it still shows in TB app list and trying to uninstall results in the same message from before. Not sure why this is happening. Here is the real kicker. After deleting the apk file I can still open the app (as in it opens and I see the music files listing) and watch it force close
Donation for new phone has been sent. I hope you can get one. You have done some great work with this device and I would hate to see you not be able to continue. I urge everyone else using this ROM or any mod Shin has created for this device to donate as well. We are a strong community and when one of us needs help we should all pitch in.
Thats fine if you want to set up a new thread. I would but i have to go to sleep. Have to go to a temp agency early in the morning. Being unemployed sucks especially when you have a 1 year old to take care of.
Anywho, let me know if the newest update fixed the issues everyone was having before.
EDIT: Forgot to mention i added Xloud services and mobile bravia engine for Xloud
Re-Flash the rom with the new link to get the newest update ??
Which link is for the update/fixes?
