blackdeath1029
Man wish I knew been trying to study java,C. With out access to a computer. Makes it difficult at best. How about a '," instead of '&" lol sorry, best I can see from knowing notta.
Anyone help me out ??
iam having an undefined reference in C
error: 35, Undefined reference to zte_oem_rapi_streaming_function
How's it running ?
Its decent but im not sure its ready for beta. Some settings wont stick til reboot. Google Search crashes upon reboot and 3g is terribly slow. However its still a huge leap forward. Good job.
I had gamed on previous builds just fine
So I've been using it since last night and I can not make it work properly, everything takes a while to load if not force closes, I have multiple reboots and lock ups, WiFi is the same, but the clock issue seemed to be solved, after the network update.
Not complaining, just reporting to see if it's my phone or the rom overall, this is a great job and effort! Thank you so much!
Ive been running it about the same amount of time, only had one lock up so far.
Seems to be the best build yet, smooth, pretty stable, I had to reboot a few times to get some settings to stick but overall, I havent had any problems yet.
I just removed the clock, didnt know about a network update, I did not flash gapps either.
Not yet anyway. Still playin around with it for now,
Yeah, when the network updated it's status the clock got the right time.
I guess mine was a gapps issue, I'll try again later without flashing it.![]()
Yeah, re-flash the rom, then just let it kinda stabilize for a day or two, reboot a few times charge the battery etc. Seems to be very stable for me.
I will flash gapps later on tonight. Umm, How did you or the network update? I have the clock removed from the status bar and the home screen for now, but would really like it back up their. And I have my battery icon changed to a circle with the stats inside it, Haptic feedback turned off, Kernel is jacked up and set to SmartassV2/Sio.
Definetly a gapps issue. i do not understand how or why. everything will run really nice. until you install gapps. once you do that.. all hell breaks loose. and ive had this on a few phones. not just the warp
I turned the automatic date and time off and reboot, then turn them on and reboot and always at the start has the wrong hour but after a few seconds along with the signal bar the clock updates to the correct hour.
Also I had GPS and Wi-Fi locations on.
Then flash the zip? Or try and sideload the apk.It wouldn't come with the next update since this is pure CM... if you go into the gapps zip and delete everything but phonesky.apk then it should work...
