mercury0x000d
The ultra-modern operator
Anyone help me out ??
iam having an undefined reference in C
error: 35, Undefined reference to zte_oem_rapi_streaming_function/*
* WCN1312 libra WiFi Loader
* Updated for Jellybean By DM47021
* This binary will load the wifi drivers, set mac address and
* enable / dislaple polling on sdcc.3 for msm7x30
#include <stdlib.h>
#include <fcntl.h>
#include <errno.h>
#include <string.h>
#define LOG_TAG "LoadLibra"
#include "cutils/log.h"
#include "cutils/misc.h"
#include "cutils/properties.h"
#define WIFI_DRIVER_LOADER_DELAY 1000000
static const char DRIVER_MODULE_PATH[] = "/system/lib/modules/libra.ko";
extern void zte_oem_rapi_streaming_function(int n, int p1, int p2, int p3, int *v1, int *v2, int *v3);
extern int init_module(void *, unsigned long, const char *);
extern int delete_module(const char *, unsigned int);
void getmac(char *mac_param)
char x[6];
int y;
memset(x,0,6);
y=0;
zte_oem_rapi_streaming_function(3,0,0,0,0,&y,x);
ALOGI("zte_oem_rapi_streaming_function %p %x %x",x,x[1],y);
sprintf(mac_param,"mac_param=%02X:%02X:%02X:%02X:%02X:%02X",x[5],x[4],x[3],x[2],x[1],x[0]);
ALOGI("Got MAC Address: %s ",mac_param);
static int insmod(const char *filename, char *args)
void *module;
unsigned int size;
int ret;
ALOGI("Loading module");
module = load_file(filename, &size);
if (!module)
return -1;
ALOGI("Init module");
ret = init_module(module, size, args);
free(module);
return ret;
static int rmmod(const char *modname)
int ret = -1;
int maxtry = 10;
while (maxtry-- > 0) {
ret = delete_module(modname, O_NONBLOCK | O_EXCL | O_TRUNC);
if (ret < 0 && errno == EAGAIN)
usleep(500000);
else
break;
if (ret != 0)
ALOGD("Unable to unload driver module \"%s\": %s\n",
modname, strerror(errno));
return ret;
static int write_int(char const* path, int value)
int fd;
static int already_warned = 0;
fd = open(path, O_RDWR);
if (fd >= 0) {
char buffer[20];
int bytes = sprintf(buffer, "%d\n", value);
int amt = write(fd, buffer, bytes);
close(fd);
return amt == -1 ? -errno : 0;
} else {
if (already_warned == 0) {
ALOGE("write_int failed to open %s\n", path);
already_warned = 1;
return -errno;
int main(void)
char mac_param[128];
write_int("/sys/devices/platform/msm_sdcc.3/polling", 1);
getmac(mac_param);
ALOGI("Loading Libra.ko");
if ((insmod(DRIVER_MODULE_PATH, mac_param)) < 0){
rmmod("librasdioif");
} else {
usleep(WIFI_DRIVER_LOADER_DELAY);
property_set("wlan.driver.status", "ok");
write_int("/sys/devices/platform/msm_sdcc.3/polling", 0);
return 0;
It looks like there's an issue with the extern function call to zte_oem_rapi_streaming_function. If I remember my C correctly, extern basically tells the compiler that, even though the specified function may not be declared in the current file, that it has been elsewhere in another file in the program and that it's okay to go ahead and compile without seeing the actual function present in the current file. My guess is that there is no such definition for zte_oem_rapi_streaming_function elsewhere in the other files in the program.
