rbheromax
Android Expert
Yes I do
Which zip did you flash? The one from this thread or the modified one on our own forums?
Yes I do
Is this kernel compatible with 4.2.1 JB, if so I want to know if its possible to make a zip that can flash only the kernel and the files containing the open gl 3? Because that would make the Warp 4g's "stock from" run smoother and better in my opinion (it'd be a substitute for this beast build for now)
no
I basically had to make this kernel becuase the stock kernel does not support the newer adreno, and ION and stuff like that, and the stock kernel wont boot CM11, unless you use a bunch of CM legacy repos and stuff
so this kernel I made would not work with the gpu, and media libraries that are in the stock rom, probably would not even boot the stock rom at all
I am very eager to help get development on this particular handset... Maybe a little too eager, as I made contact with you in my spare time when I don't even have Internet!
first it has a locked boot loader, so the kernel and recovery need to be signed with ZTE's private key
second the system partition is write protected, so even if you get a root shell, you can not re-mount the system partition as rw
here is an expoit that will give you temp root access in adb shell, you will be able to do some stuff like make backups of your partitions and stuff, but since you can not remount system, you will not be able to install permanent root files
Never say never
Since the device is krait we can port loki
its quite possible. Ima need some partitions though
Boot, recovery, and aboot
Never say never
did bliss ever start on the patch workaround for the top tier lgs?
Hear anything in IRC?
Were you able to get your awe working with build 2, or the current 3a?Thank you guys for all your help! I did what you guys said and it worked. The WIFI and everything. It took me a while to find the right GAPPS, but I eventually found them. It is now fully functional. Going to start testing on it right away.![]()
Would love CM11 on my ZTE Grand S Lite testing. Can anyone tell me if that works. Thanks for the help
Nobody can help me?![]()
hroark13, I saw the post you did awhile back on porting this CM11 to the Hera (ZTE Source.) As I didn't see anything here or there, I wanted to know if you ever got anyone to test in on the Hera, and if so, is it functional?
