GODDDD!!!! THANK YOU SOOOO MUCH!!! IT WORKED!!! so i am back to stock..when data and stuff fully work without problem for the cm10 then i will flash it , but for now ill be PATIENT(which is nearly impossible for me) and wait till the fully working cm10 works. Ive waited 1.5 weeks without texting my friends and ive been impatient..so ill just wait till a fully working rom is done cause the people working on it are really hard workers. Thank you btw for all the help you have givin me 2Giga. Ill return to the forum in like a week (maybe two) to see is the rom is complete. If it getss complete can you email me at my email to notify me. Thank you very much.Looks like you're going to have to do a factory reset If I remember right, you turn off your phone, press and hold power and volume up until you see the LG logo then let go of power but keep holding volume up until you see an Android with a ball thing coming out of its chest. After that your phone will reboot. You will lose what ever you put on the internal SD, downloaded apps, ect...
GODDDD!!!! THANK YOU SOOOO MUCH!!! IT WORKED!!! so i am back to stock..when data and stuff fully work without problem for the cm10 then i will flash it , but for now ill be PATIENT(which is nearly impossible for me) and wait till the fully working cm10 works. Ive waited 1.5 weeks without texting my friends and ive been impatient..so ill just wait till a fully working rom is done cause the people working on it are really hard workers. Thank you btw for all the help you have givin me 2Giga. Ill return to the forum in like a week (maybe two) to see is the rom is complete. Thank you very much.
okay I did. But just remember the email and email me whenNo problem You may want to remove your e-mail now, don't want you to get spam
I didn't ask for an eta but the forum was told about a test rom being available for some testing and feed back but yet said rom wasn't delivered......my point is if its not ready you shouldn't post that it is that is all
Alpha 4 is up on UPP, and I get 3G on it
LG Motion CyanogenMod 10 Beta 1
So does texting work. And does the beta 4 come with the gapps package? Also 4g?
I have no idea what AOKP means...but it doesn't matter I'll just wait for the texting and 4g and all the other problems to work before downloading
You still cannot surf the web with blazing 4g speeds.
