I freaking LOVE your ROM! The only reason I would use bloodawns is because his doesn't have these little problems. I think you should continue on trying!
EDIT:
And just so you know, not trying to hurt you or anything, but I don't think you should try to go for what bloodawn has. Maybe after you finish up all the little glitches and release a fully (or pretty much fully) CM7 port you can make these little tweaks, but now I wouldn't think so.
Well when I originally started this I did not include gapps in the ROM
So now it basically just has market, and people can add what they want.
I seem to like the Zeam launcher more than the ADW
Having the ROM de-odexed, I am just not sure what is better, it only seems to make a difference on first boot, so I dont know.
The camera APK, should have been changed a long time ago
The data2sd kernel with smaller modules is something I came up with
Adreno200 egl config I learned from the net from some other phones ROM, it should improve performance
The init.d scripts are some of the ones other people are installing in other threads, and CTMOD has them as well
Lets see how it goes with beta 5
I am willing to make changes and put things back if you guys / gals want them back
I JUST WANT TO FINISH THIS FRICKEN THING ALREADY
THE MAIN THING IS THE MMS OVER WIFI
if someone can give me a list of issues that need to be fixed, that are not listed in the OP that would be great
The built in wifi hotspot is not gonna be fixed unless we get a new dhd.ko driver
The hidden menus and updating prl and profile will never be added, and you wont see too may CyanogenMod ROMs out ther that support these proprietary functions
