Hey Hroark...i was able to send pics on mms over wifi..allthough it had taken about 40 minutes to get from me to reciver..also im having trouble geting theme chooser apk and theme manager apk installed using root explorer..would you reccomend another way to install those two files?
Getting Cheapo 16GB class 10 in mail on Monday. Let's see what it does.
Does the vibrate work on this version?
If your talking about the 4 main keysbon the phone..i would say no...well atleast i havent been able to enable it
my sediments EXACTLYHroark, you are a very humble guy. Without your work in CWM and Odin where would we be?
Nothing wrong with CTMOD. Impressive on many levels including the CIQ removal.
But, you have CM7! That is a prestigious ROM that is a true status symbol on this phone. It gets attention and legitimizes cheap prepaid phones for once. Nobody else did it. You did. I know you had help but it is an awesome accomplishment. Be Proud.
I love CM7 and have never flashed back to CTMOD or anything else since I put it on.
I could really care less about the wifi MMS thing. Don't get discouraged, find someone to delegate it to.
You have no idea how much I appreciate what you do. This stuff has made me much more productive which could translate into money.
I can not thank you enough.
okay tried the rezip thing with dspmanager and theme chooser and theme manager...no go didn't install in cwm and i mounted system and data beforehand just in case and they won't install in cm7 either..says "application not installed"
and i don't have any plans of going anywhere.
keep up the great work hroarkI'm with the rest here, CM7 is the best ROM going on the Prevail and we have you, Mr. hroark, to thank for that. Your efforts are greatly appreciated!
Now, having said that, I have found beta 5 to be somewhat of a misstep in some ways, even while it has advances, too. I do like the removal of a lot of the non-critical apps and I am totally cool with either ADW or Zeam launchers, makes no difference to me. I really do appreciate the technical advance and work involved in integrating the apps2sd functionality into the kernel. However, in my experience at least, it frequently lags in a major way, even though I have a good class 10 SD card. I suspect that this largely has to do with all of the /data directory being placed on the SD card. I was running beta 4 with S2E and I restored this configuration with a backup I made prior to trying beta 5. In my S2E setup I had left /data/data on internal memory and it does not suffer from lagginess at all; it just screams! In comparison, beta 5 is just not tolerable.
Hroark, do you think it would be possible to make the kernel in the ROM without the apps2sd functionality, then provide just the cwm flashable kernel with apps2sd functionality for those who want it? Or... and it's a stretch here, if my suspicion is true, can the implementation of apps2sd in the kernel be made to leave /data/data on internal memory somehow?
Hopefully I don't sound overly critical here, because that is not my intention at all. Just trying to provide an honest assessment based on my experience. Your work on this phone is simply amazing and has made this phone infinitely more usable for a lot of people! Thanks again.
Hey hroark i dont have alot of experience with unziping and reziping files..and i seem to be having alot of trouble with it..either that or im making something really easy really complicated..im using an evaluation version of winzip..would you reccomend someting different besides winzip ..maybe a different one that will unzip and rezip
There is going to be ALOT more kernels coming out soon, you should know why
for now try this, and tell me how it works
Prevail_cmbeta5_no_ext_BOOT_cwm.zip
Forgive me for asking, as it may seem obvious, but what does the above zip do exactly? Guessing "BOOT" is moved from sd-ext back to internal?
