use this Thread to bring your phone back alive. follow the instructions.
Thanks, This is how it went down I put it in backup and tried to restore it via. CWM and got md5 mismatch. Then deleted it and put it in again. Restored again and it worked I booted all the way up and everything worked fine. Then I reflashed the ROM and flashed the ICS Theme. Then I flashed 6.0.2 and bam everything is working again!. Thanks again, Chev for all your help I I love this ROM so much couldn't leave it!
Keep in mind guys that if you get a md5 mismatch error it usually means that you may have spaces or invalid characters in the backup folder name, also make sure that you don't have a folder within a folder in the clockworkmod/backup folder, that would cause CWM to not be able to find the files properly, just some friendly advice...
Most times I'll rename my backup folders to a name so I can remember what the backup is, for example with the MegaTron 6.0.2 backup I renamed the folder MegaTron602Backup, notice that there are no spaces and it works perfectly...![]()
CWM will recognize the backup as long as there are no spaces or /s in folder name...![]()
What system apps are safe to uninstall?
That's weird because the name of the file didn't have any spaces. Oh well
A space in the filename is just one reason CWM could have given a MD5 mismatch. The list of reasons why you get that error can get pretty long and ridiculous, especially if we're talking about a zip file that's been extracted. As for (advance) restoring a backup (especially if it wasn't touched), my guess is that either there wasn't enough room on the card to unpack the files needed to restore to the phone, or something interrupted the phone while it was making the backup in the first place. Just a guess.![]()
Delete the update.zip file from /cache folder, then go to system/etc/security and rename otacerts.zip to otacerts.zip.bak... if the notification is still up accept it, it'll reboot to CWM, then just reboot back into system, PROBLEM SOLVED!!![]()
I could probably dig up the ICS keyboard.apk for ya from my system, lemme know if ya need me to, ok?
Here ya go!!Keyboard.apk
Lol! np man, actually I'm not the one that came up with the system update fix, credit is due elsewhere, forget who it was that originally posted it, but glad it worked for ya, was just passing the info along so you could get it done quickly... but yeah I ran a benchmark @ 1.9 GHz and got a 5027 score, so not too shabby!! lmao!!
EDIT: I'm gonna run a benchmark @ 1.5 GHz with SmartassV2 and deadline, post screenshot in a few...![]()
I can't say enough about this rom, it is just absolutely sick!! Thanks again Chev and Mav...![]()
I don't know if you guys have ever noticed, but in the options of Goo Manager there's something about OpenRecoveryScript, Chev or Mav can either of you guys tell us if CWM is compatible with that function?? If I'm not mistaken I think that function is what tells our recovery to flash the zips we download from Goo Manager...
OK thx was just wondering cause it was asking to go find one that was compatible with my phone, but ok...
