bg4m3r
Android Expert
They take up 1.5 MB, at most, but your call, I suppose.I uninstalled root and super SU because they were taking up a bunch of internal memory, and because I didn't really need them anymore.
When I removed towelroot and super SU, it freed up about 500 mb of internal memory. Right now I have the following installed:They take up 1.5 MB, at most, but your call, I suppose.![]()
That's simply not right. I don't know what you removed to free up that space, but it wasn't SuperSU and towelroot. Also, towelroot isn't 'root'. It just installed the su binary, which it sounds like you probably still have installed, but now you have nothing controlling it.When I removed towelroot and super SU, it freed up about 500 mb of internal memory. Right now I have the following installed:
I'm not familiar with all those apps, but I'm a bit surprised that 16 apps are eating up 3.5GB, unless you are on ART runtime. Although I can see Hearthstone sucking up a good chunk of space. I have 82 user apps installed, 1.3GB free, 500MB worth of app data moved to the SD card with OBB2SD.Skype
Bnet app
Home Depot app
ES file explorer
Wells Fargo app
Double Twist (can't wait for Foobar2000)
Drastic
GTA: Chinatown Wars
Hearthstone
Imgur
Konundrum
My Boy
Osmosis HD
Plex
Smash Hit
SNES9x
UB reader
Plus the apps that come with Android, and I have 545mb free internally. I wanted to setup my external card to house some of the bigger stuff, but it seemed like too much work to get programs to install to the SD.
I'm basically a light gamer and don't really care about root (except to get rid of the crap that kept popping up like the Weather and Connections Optimizer).
Why wouldn't you have fixed the good one and sent the broken one back?I also sent back the replacement phone they sent me because it got stuck in a boot loop after trying to root it. Reflashing the rom would get it back to zv3, but it wouldn't take root, so I am still stuck with the phone that has the broken flash LED.
You have to move the obb AND data folders, as I mentioned... Did you install Xposed framework?So I tried the Link2SD thing and installed Xposed with Obb to SD module, and it didn't work. After I moved the OBB files for those two games to the SD card, the games wanted to download the content again. I still have root access and everything, I reinstalled towelroot, Super SU, and whatnot. I did not install TWRP again yet, is that needed? I thought it was just for backing up and recovering your roms.
Also, could you post a link to a zv4 rom/radio that isn't pre rooted? I'm assuming that's what I need in order to update?
We were able to install some rather bloated games that would not have been possible using only the internal storage. Over 3GB of obb files were moved to the external SD card. In my experience, games are the main culprits for having huge data or obb folders.
![link2sd[1].png link2sd[1].png](https://forum.earlybird.club/data/attachments/64/64676-b3d81cc8a96d77d5d743569d0e38172e.jpg?hash=s9gcyKltd9)
FYI,the author of Link2SD has revealed that the next version will include the ability to link data and obb folders to the external SD card. I currently use it together with FolderMount to move data and obb folders, but once that capability is built in to Link2SD, I'll say bye bye to FolderMount.
Nice, thanks for the info. I downloaded FolderMount but hadn't installed it. I think I"ll just wait for the update to Link2SK.
Do a factory reset.Hi-just got my phone yesterday and followed the steps in the guide. Downgraded from V4 to V3 and everything went well up until the last step of upgrading to z5. After upgrading to z5 through TWRP I rebooted and kept getting all sorts of popups saying various services have stopped working. Any ideas what went wrong? Fortunately I had made an earlier backup with v3 so I restored to that for now.
No, they don't. In fact, they shouldn't, unless you are going to copy it off and store it on your computer. You can change the storage location in the backup screen. Tap the available storage to change. You can enable compression for the backup too.I think the problem was that I had 2 backups in the TWRP folder and it was using up too much space because I was getting storage errors also. I deleted one of them and upgraded to z5 and it seems to be working. Does TWRP and the backups have to be stored on the internal storage? If not, how do I get it on the external card?
It does if you have a backup in the internal storage. You only have 4GB internal storage, 3.93GB after formatting.Right now, it says I have 1.39 gb free out of 3.93 gb on the internal storage. Does that seem right..this is a brand new phone that I just got yesterday so nothing on it yet? Seems like I ought to be able to have more than one backup stored without it having storage issues.
Linking of data/obb will only be available in the paid version of Link2SD. The free version of FolderMount will allow you to move up to 3 data/obb folders. If you are pinching pennies, you can use the free versions of both programs together.
Personally I think Link2SD is an essential tool for phones with limited internal memory. It adds so much value to the phone, that I don't mind paying for it and supporting the developer.
No, you won't. Why would you have to rebuy an app you've bought just because it updated?I agree with you, and I actually have the paid version now of Link2SD , but I'm assuming to get their new version I would need to buy it again, which I wouldn't have a problem with. I think this app is definitely worth supporting the developers.
Just start over and use the right mode.I think i accidentally bricked my phone.
Forgot to check BOARD mode now have factory reset 2 screen as the only thing i can access how do i proceed?
Try uninstalling all phone related drivers and software from the computer, including the ones you need for this. Reboot, reinstall the LG drivers, reboot. Try again. There could be a port conflict or something to that effect.Hello, first let me say thank you for everything. Here is my problem, everything runs smoothly until I have to unplug the USB cord from the computer and plug it back in. The LG Flash Tool says "Waiting for Connection, then I get a "Factory Model Check ERROR!!". The device says its a HTCEVOV4G, which is my old phone. I have read all the way to this point trying different suggestions and am completely at wits end. Any idea whats going on? Running Windows 7 Ultimate 64bit
