CrimsonToker
Android Expert
Can someone explain md5 a little more for me? I understand that you check the md5 to make sure the download is right, but why is that? Do all downloads have md5 or is it something that has to be prepared first?
All files have an MD5. It is generated from the data content of the file. Exactly how, I don't know, some fancy algorithm. You can see the MD5 of any file at any time, but checking the MD5 of a download without knowing what the original files MD5 is useless unless you know that the copy you have is good.Can someone explain md5 a little more for me? I understand that you check the md5 to make sure the download is right, but why is that? Do all downloads have md5 or is it something that has to be prepared first?
You boot into download mode by holding volume up while plugging in the phone with the phone off. The drivers have nothing to do with this. Yes, progress is indicated on both the phone and in the flash tool. The phone will reboot when it's done. You will get errors from the flash tool after the phone reboots. This is normal, ignore it.Hi,OP and thanks for posting this. How do we know once the LG flash tool is finished?? Does it give any alerts?
Another issue I had is that I was unable to boot the phone into the mode that the drivers should have enabed it to. I held down the volume button but that did not work. Do you have any suggestions?
Is the LG flash mode supposed to show anything on its logs,or some sort of progress bar on the phone? Do we have any means of tracking the progress??
I've been wondering why it gives that error message even though it works. Any idea, bg4m3r?You boot into download mode by holding volume up while plugging in the phone with the phone off. The drivers have nothing to do with this. Yes, progress is indicated on both the phone and in the flash tool. The phone will reboot when it's done. You will get errors from the flash tool after the phone reboots. This is normal, ignore it.
However,no progresss was indicated on the boot mode even though I left it for quite a bit. How long on average does this take?You boot into download mode by holding volume up while plugging in the phone with the phone off. The drivers have nothing to do with this. Yes, progress is indicated on both the phone and in the flash tool. The phone will reboot when it's done. You will get errors from the flash tool after the phone reboots. This is normal, ignore it.
Did you read the instructions thoroughly? Did your phone look like the screenshot? I guarantee you missed a step and never started the flash.However,no progresss was indicated on the boot mode even though I left it for quite a bit. How long on average does this take?
My guess is it's a matter of timing. It's trying the verify the flash, but the phone isn't in the right place/status when it checks.I've been wondering why it gives that error message even though it works. Any idea, bg4m3r?
So towelroot doesn't work on zv4?
D; dammit! Oh well I see if I can borrow a laptop from someone to do this.No, unfortunately it does not.
Because the debloated ROM has Google Now Launcher, not the stock launcher.After following these instructions and installing the heavily debloated zv5 ROM (with radio), my home screen only has one screen and tapping on "Home screen" in Settings causes Settings to crash. Any ideas why?
Hard to say exactly what will happen. If you were using link2sd, then I would say you're going to have issues, but I don't know about this. You may also have to do a factory reset after updating. This is why I suggested going all the way through at once. Backup your apps and hope for the best?Okay, so it's been a minute since I posted here. I successfully got big apps moved to the external SD card after deleting Data, moving OBBs to the SD, and then moving the app to SD card in the app settings. Now I am curious about flashing to zv5 from my downgraded zv3. I understand that I need to make a recovery image, and that I should probably use the odexed zv5 rom instead of the deodexed one. The question I have now, is do I need to redo anything I've already done after flashing to zv5? Will my bigger apps continue to work from the external SD?
Or is it better to uninstall xposed and move everything back to the internal SD before I flash to zv5? Also, I've been having trouble getting CWM or TWRP to do anything on my volt. Neither one support the device directly (Volt does not show up in the device list) and backing up doesn't seem to be doing anything. I patched the SD like TWRP wanted me to, installed busybox like it wanted me to, and then tried to backup the current rom, but now I can't find it anywhere to verify that it actually backed it up.
It went through a reboot sequence and now I'm just kind of worried if I should proceed to flashing zv5 or not. I also installed flashify, which seems to be working better as a backup tool. Now it actually sees the backup I made of my rom.
That was my point. I don't know. The safest thing to do would be to get everything back on internal memory and make backups because you might have to do a factory reset after updating.I'm not using link2sd atm. I'm only using xposed framework and the obb to sd module. Is that still going to present an issue?
Still Running into the same problem. heres what I did, I did a LG Backup. Then I downloaded and installed everything required, Put the phone in download mode and began the flashing process. The flashing process worked and booted into MiniOS, held power and tapped normal boot. I dialed ##72786# and then it rebooted, however, after the phone powered off and began to restart, the only thing that would load is the first LG screen and had the message in the top left corner of the screen...Yes, those HTC backups might be the problem. It's strange, but perhaps something from old HTC might have written to the phone itself somehow. Malaci, disconnect your phone from the computer.
Do this on your computer and then your mother in law's HP without connecting the phone:
Make sure (very important) any and all drivers and software for LG and the old HTC are uninstalled. Reboot. Open from "Start Menu" and right click on "Computer" and then select "Properties". From the left side panel of the system window, click on "Advanced system settings" and then go down on the middle tab named "Advanced" to click on "Environment Variables". Now, under the "User variables" box at the top, click on "New" and type "devmgr_show_nonpresent_devices" without the quotation marks in the top "Variable name" text box and then the number "1" without the quotation marks in the bottom "Variable value" box. Click "OK" to close out each open window and finally close the system window. Now, log off the computer and then log on again. Open "Device Manager" from inside "Control Panel" and click on the "View" tab on the menu bar at the top of the device manager window and then select "Show hidden devices". Scroll all the way down to "Universal Serial Bus controllers" and expand it by clicking on the little triangle and you will see branches in the device tree. Look for the faded icons. These indicate unused device drivers. Right click on each one and select "Uninstall". Go up a few to "Portable Devices" in the device manager window and expand it if available. Look for faded icons and uninstall these as well. Close out device manager and reboot computer. Install LG drivers and software. Computers should now recognize your LG Volt if the phone was properly working.
Let's try and find the problem with the phone now. Can you back track all that you have done or tried to the phone in order? Take out the SD card and leave it out. Reboot the phone. What happens? Can you do a factory reset?
You're going to have to reflash. It probably didn't finish due to the power loss. You're lucky you still have download mode access or you would be completely hosed.While i was trying to flash z3 yesterday, the power went out and my computer went off, stopping the process. Now, my phone cannot get past the LG screen as it goes straight into download mode. I tried to factory reset it, but nothing changed. Can anyone help me as I am not sure what to do and I am afraid that I may have fully bricked it.
