I have cm7 on my phone, can i use this stuff posted here?
You're roted with cwm and cm7. What else wouldyou like to add? You have to be more specific to get exactly what you need.I have cm7 on my phone, can i use this stuff posted here?![]()
I think this really should be sticky to top of this thread
Also, this guide is no longer maintained
Much of this was only for froyo.So does all of this still work in Gingerbread? I'm totally out of my depth here with phone lingo (give me legal software and esi issues and I'm all over it). And I assume I'll still be with Boost.
SSM would probably speed your phone up. This would be because the data for all your apps would be stored and run from the internal memory, instead of the sdext. You may want to think about repartitioning your card though, since the dalvik will be stored in the second ext4 partition and will roughly take the same space as your apps. With SSM you probably wont need more than 1gb (1024mb) for each ext4 partition since the internal memory will also be used in this mode
Appreciate your reply! So I should change my second ext4 partition to 1g? Do I leave all the other partitions the same? Are there any other steps I need to do or just go in my Koumamod and change from Data to SSM??? Thanks again, much appreciated
So....I am back. Got my SD card partitioned after factory reset. Kouma is now SSM. My SD partitions are FAT 12686, EXT4 1636MB, EXT 4 1100MB and SWAP 591MB. So why does my internal storage say it only has 106MB free and I haven't added back any of my apps??? Is this normal? I usually had about 1G of free internal storage.
df
SSM doesn't show the extra storage the same way that data more does. Since its not using the ext4 partition exclusively for data it doesn't show it as the available data.
Try installing a large app. I bet your available space won't go down by very much.
Also, to see how much space tpu have, open terminal emulator and typeit will show a listing of the partitions. /data/app is the first ext4 partition, /data/dalvik is the second ext4 partitionCode:df
You're right it didn't go down much! My phone is running much faster, at least for now and no force closures of facebook etc. Thank you! I can actually use my phone without wanting to throw it out the window everytime is slows down or force closes an app. Oh, where do I open terminal emulator??
I answered in the other thread. No need to double post we will see it.I rooted my prevail a couple years ago using this guide (in a different incarnation). I know NOTHING about phones, so literally I could not have done this without the guide.
I see theguide has changed and there's this new list of all the rooting options available. Everyone seems to be very excited about how condensed it is. Unfortunately, since I know so little about phones, I simply can no longer find what I'm looking for on that list.
I got a new SD card and I want to partition it and use part of the space for internal memory. Is there anyone who can point me to idiot level instructions for this? Preferably the same ones I used last time?
Thanks!!
