Omg. I think I just got a woody!1 - Extract and copy the MAINROOT folder from the MAINROOT.zip to your desktop.
2 - Open Powershell or Command Prompt as administrator and change directory (cd)
to the MAINROOT folder.
EX: cd C:\Users\Owner\Desktop\MAINROOT (Instead of Owner it'd be your username)
3 - Type in step1.bat in command prompt or ./step1.bat in powershell and hit enter.
4 - You should now be in an adb shell prompt, type in run-as con and hit enter.
5 - You now have shell access and you can tweak the android system with these permissions but
tweaking the barebones of the linux kernel will be impossible without a full root. Selinux is the culprit.
6 - You can use the package manager (pm) to block apps and settings command (settings) in
this adb shell prompt to tweak the workings of android or use the activity manager to access
the hidden sprint and lg menus to change APNs and tweak CDMA radio control.
7 - In the adb shell prompt type in pm list packages and hit enter.
8 - From the list of packages find one that has system activities we'd be looking to access nad
tweak such as com.lge.hiddenmenu.
9 - Type in dumpsys package com.lge.hiddenmenu and hit enter and in the list you will activities which can be started, such as com.lge.hiddenmenu/.Power.TherDaeMitigation.
10 - Type in am start -n com.lge.hiddenmenu/.Power.TherDaeMitigation to start the activity.
11 - You'll want to disable thermal mitigation to boost the raw performance of the phone.
12 - Repeat steps 7 -10 to access any activity you find interesting and wish to tweak.
13 - Hint : am start -n com.lge.SprintHiddenMenu/.iot.IotHiddenMenuMain is a good one many people were hoping to access.
Can't wait, been looking up her skirt for too long. Lmao!Haha we're taking the panties off this phone. Lol.
Did the steps work for you? Hook up the phone to a usb port on your pc.So how do I get root?
I posted all the commands you'd need. Owner in C:\Users\Owner\Desktop\MAINROOT would be your Windows username.
Im new to the adb comands i will see if i can do it what version is ur software on ur phone im zv4I posted all the commands you'd need. Owner in C:\Users\Owner\Desktop\MAINROOT would be your username.
I'm on ZV6 roadkill42Im new to the adb comands i will see if i can do it what version is ur software on ur phone im zv4
wow and have full root and do u have twrp flashed?I'm on ZV6 roadkill42
This is not a full root it's just shell access to the android system components. We can not tweak the linux kernel or mess with any partitions yet but there's plenty we can do as I described in my post.wow and have full root and do u have twrp flashed?
Have u tried to use flash fire to flash the twrp after doing these commands or use kingrootThis is not a full root it's just shell access to the android system components. We can not tweak the linux kernel or mess with any partitions yet but there's plenty we can do as I described in my post.
Got the # but still could not get root so can put twrp onThis is not a full root it's just shell access to the android system components. We can not tweak the linux kernel or mess with any partitions yet but there's plenty we can do as I described in my post.
