Root Help Rooting LG Stylo 2
You can disable system apps but to uninstall them you'd need full root access as system apps are stored under /system/app/* under the filesystem. Disabling the wrong system package will soft brick you until you factory reset so be careful.
Rats, I was hoping the exploit would be enough to uninstall. Don't worry, I have a short list of bloat apps that I'm trying to disable, and I know the basics of what not to get rid of.
