For those that complain about having to close the landscape keyboard to send texts, there's an option in Handcent that lets you send messages by pressing the Enter key. Open Handcent, press Menu, and click Settings. There is an option labeled "Shortcut key to send." From there you can select the ability to click Enter to send your message.
....ion.I would send so damn many unfinished texts with that opt....
I've only read the initial post on this page so if this tip has been suggested elsewhere... :shrug:
While browsing, a long tap will bring up a window to copy / share /etc. whatever it is you clicked. To include more text to be quoted, simply drag and reposition the highlighted frame around your selection.
A pre-Alpha version of Fennec, the mobile version of Firefox, is available for Android. It can install extensions, like adblock+: Fennec on Android at Vladimir Vuki?evi?Question regarding the built in browser. Is there anything that can be downloaded to block ads?
Would love to have something like adblock plus for Firefox on my Incredible. Thanks.
Thank you! I read Copy/paste was improved, but I didn't see how. Moving back to default browser just for this.
anyone know if there is any quick way to change the media volume if your not in a media player. Sometimes I want to mute the media volume before I watch a you tube vid or something
Sure add Quick Settings from the Market and add that app to one of your screens. Then open the app and tap Volume Control and voila! All the volume controls at your fingertips.
Sounds perfect but I searched the market for "quick settings" and didn't find it
Quick and easy way to move a widget, app or file from one home screen to another one.
Instead of deleting a widget, app or file from one screen and then adding it to another, long tap the item you want to move to a different screen, then place that item over the top of another widget, app, etc. so that it can't drop into place. Instead the item is held suspended until you place it properly. At this point just swipe to the appropriate screen and your "suspended" item will stay suspended in the forefront. Then just drag the item to an open space on the new screen and presto you have quickly and easily rearranged your home screen.![]()
Download Appbrain and then do a search with that.
I think this link will bring you to the app.
Quick Settings - Android app on AppBrain
I found a blog on androidandme.com that has one of those scanable links.
Quick Settings: Manage system settings from anywhere
On their website they are saying they pulled it from the market because of issues with the Droid Incredible which is what I have so i'm a little weary until they have it definitely fixed. Maybe its the 'sense' UI thats conflicting
